Simple Problem with Breadboard Connections — Parallax Forums
John KauffmanJohn Kauffman Posts: 653
edited 2006-04-22 16:29 in Learn with BlocklyProp
This is almost trivial...
I have a peripheral that I want to connect to my Homework board's breadboard. The peripheral interface is 20 pins in a double row (te pins per row). 1 is across from 11, 2 from 12, etc. Each pin has in independent function.
The problem is that if I stick the peripheral's pins straight into the bread board (like and App Mod), then the pairs of pins (1-11,·2-12 etc.) are shorted through the breadboard.
The double row of pins is not wide enought to span the breadboard's central channel.
The best I've come up with is to use an old PC ribbon cable with three sockets (used to connect two hard drives to the·mother board).
One end (the start) I connect to the peripheral
The middle socket·I connect just the left row to a single strip of header pins
The other end (finish) socket I connect just the right row to a single header strip.
I then loop the cable so the middle socket and its single row of pins goes to one side of the breadboard and the finsh socket with its single row header pins go to the other side of the bread board. Then I add the remainder of compnents in the tunnel. I won't post a picture becasue you will just laugh.
Am I crazy? Is there some commercial cable or other product that splits double-row header pins into single rows so they can be used on a breadboard?
Thanks.
    edited 2006-04-20 20:00
    No, your solution sounds pretty good, actually. Others might make an 'adapter board' to do this, but I haven't seen one off-the-shelf.
  • John KauffmanJohn Kauffman Posts: 653
    edited 2006-04-20 20:05
    I can' t keep this solution past next week when my brother-in-law returns from a business trip. His computer technician might actually explain to him why he gets a message that his BIOS can' t find a bootable drive.
    Shhhh...
    edited 2006-04-20 20:45
    You might try something like this -- http://www.jdr.com/interact/item.asp?itemno=gr-idh10w
    As I recall, I DID build an interface to a bread-board out of one of these. You spread the wire-wrap pins enough to span the 'gutter' in the board and plug it in, then plug your interface cable into the other end of the connector. Getting the right part (with the right sex) can be difficult without good pictures.
    Oh, yes, and you might be able to use one of the following:
    http://www.jdr.com/interact/item.asp?itemno=gr-idp08
    There's a 40-pin DIP connector in there.· Put that on one end of a ribbon cable, put the two-row x 20 socket connector on the other end, figure out what the pin-outs are, and you should be good to go.
    You might need a 40-pin socket to plug the 40-pin DIP into, so you can use a vise to 'squish' them together without damaging the 40-pin DIP, though.
    P.S. Oh, and now I see you have a 2x10, not a 2x20, so it's even easier.· You can use a 20-pin DIP form-factor on the protoboard.
    Post Edited (allanlane5) : 4/20/2006 8:51:23 PM GMT
  • John AbshierJohn Abshier Posts: 1,116
    edited 2006-04-21 03:45
    The BreadBoard Adaptor for TiniControllers at http://www.newmicros.com/·may be what you want $4.50. It is 24 pins.· I am not sure if the following would work but may and is not as wide:
    http://www.technologicalarts.com/myfiles/t3.html#ADHDR·look down for dual row receptacle adaptor.· $9.00 Canadian.· They also have a right angle version.
    edited 2006-04-21 13:42
    Hey, John Abshier,·newmircro's BBAdaptor (sic) looks pretty darned snappy.· And if you stuff it with SIP headers you can park a connector/s on it, too.· The other one is 0.3in wide, so it could straddle the gap on a solderless breadboard as well.
    edited 2006-04-22 11:22
    Corrected per message below
    Both are good.
    The BBAdaptor IDC adaptor is 'male gender' and great with a ribbon cable.
    The Tini Adaptor [noparse][[/noparse]or BBAdaptor] is 24 pin 'female gender' and useful for the mechanical support.
    I really like the idea of being able to bridge breadboards with a ribbon cable.
    Post Edited (Kramer) : 4/22/2006 4:26:45 PM GMT
    edited 2006-04-22 12:59
    Kramer said...
    The BBAdaptor is 'male gender' and great with a ribbon cable.
    The Tini Adaptor is 24 pin 'female gender' and useful for the mechanical support.
    Baking powder?· Ex-squeeze me?
    We need to talk.
    590 x 285 - 23K
    200 x 204 - 7K
    Oops. I clicked the wrong web site.
    Have corrected my message. It is the IDC adaptor that is 'male'
    BBAdaptor and Tini Adaptor are one in the same.
