Serial programming tool parts. — Parallax Forums
FORDFORD Posts: 221
edited 2006-04-08 03:30 in Propeller 1
I have the diagram to build the serial programming tool so I can play propellers while I wait for my USB2SER, can I use·general purpose transistors instead of the actual part numbers specified ?
I was thinking BC337 and BC327, so that I can source them at our local component shop.
Cheers,
Chris
West Oz.
    edited 2006-04-08 01:27
    Probably -- it's a simple level-shifting circuit.
    Jon Williams
  • FORDFORD Posts: 221
    edited 2006-04-08 01:35
    Thanks Jon,
    I just wanted a bit of re-assurance before I fried one of my 2 props.
    Cheers,
    Chris
    edited 2006-04-08 01:36
    They're not that delicate -- if you're worried at all, though, wait for your USB2SERs.
    Jon Williams
    edited 2006-04-08 01:41
    I'll knock one up, I have 3.3v regs·in stock·so it will be simple.
    As always, Thanks for your replies here.
    Cheers, Chris
  • Brian RileyBrian Riley Posts: 626
    edited 2006-04-08 03:26
    FORD said...
    I have the diagram to build the serial programming tool so I can play propellers while I wait for my USB2SER, can I use general purpose transistors instead of the actual part numbers specified ?
    Cheers,
    Chris
    West Oz.
    The 2N3904 and 2N3906 are the epitome of "general purpose transistors" I think the 337/327 are more or less counterparts to them.
    cheers ... brian riley, n1bq, underhill center, vermont
    Thanks Brian, much·appreciated.
    building it now.
