Hitachi H48C Tri-Axis Accelerometer Module Available — Parallax Forums
Lauren DavisLauren Davis Posts: 313
edited 2006-02-10 21:48 in Announcements
The Hitachi H48C Tri-Axis Accelerometer Module·is now available for purchase!
The Hitachi H48C Tri-Axis Accelerometer Module is an integrated module that can sense gravitational (g) force of ±3g on three axes (X, Y, and Z). The module contains an onboard regulator to provide 3.3-volt power to the H48C, analog signal conditioning, and an MCP3204 (four channel, 12-bit) analog-to-digital converter to read the H48C voltage outputs. All components are mounted on a 0.7 by 0.8 inch module. Acquiring measurements from the module is simplified through a synchronous serial interface.·
We do not recommend using this module with a breadboard. The design has fairly short pins with components on both the top and bottom of the module. A permanent mounting location on a through-hole board like the Parallax Super Carrier Board is the only mounting solution we support for the Hitachi H48C Three-Axis Accelerometer.
·································· attachment.php?attachmentid=40574
Sincerely,
Lauren Bares
Lauren Bares
Product Marketing Manager
Parallax Inc.
916-624-8333
lbares@parallax.com
Post Edited (Lauren Bares (Parallax)) : 2/23/2006 1:29:10 AM GMT
450 x 373 - 71K
