Help Help — Parallax Forums
Help Help
WAWAWAWA Posts: 5
edited 2005-03-23 16:33 in Learn with BlocklyProp
I am a newbie foe this program~
I want to know how to connect the BS2 with my computer~
Acutally i have a serial cable to connect both of them ~
But the program BASIC STAMP seem no respone to detect the BS2~
Can you help me to solve this problem???
    edited 2005-03-22 13:43
    Do you have the BASIC Stamp powered? Is the serial port "busy" because it's being used by something else?
    Jon Williams
    Dallas, TX· USA
  • WAWAWAWA Posts: 5
    edited 2005-03-22 16:37
    Yes, I have already offered the electricity , but still fail to use and add, I confirm and has not used in the port location of the computer.
  • WAWAWAWA Posts: 5
    edited 2005-03-22 16:46
    In fact I hope to know how to establish my b s 2 to the computer, because I use basic stamp programe of RUN > Identify to detect my port, but it's still show that no.
  • dandreaedandreae Posts: 1,375
    edited 2005-03-22 16:50
    Make sure that you do not have any software that uses a com such as a PDA or Palm Pilot.· If you have one of these devices you'll need to turn off the "Hot Sync" button down by the clock.
    Dave
    Dave Andreae
    Tech Support
    dandreae@parallax.com
    www.parallax.com
  • WAWAWAWA Posts: 5
    edited 2005-03-22 17:10
    Could you tell me (" Hot Sync " button down by the clock) where can be found ,and a method to know it's be already close?
    Thank you~~
    edited 2005-03-22 18:22
    You should be able to Right-Click on your Hot Sync button and close that application. That program is holding the com port open so the BASIC Stamp editor is not able to use it.
    Jon Williams
    Dallas, TX· USA
  • edited 2005-03-22 20:17
    There are lots of suggestions in Appendix A of Robotics with the Boe-Bot v2.2.··Click the link at the bottom of this post to view it.·
    The entire Robotics with the Boe-Bot·text is available from www.parallax.com -> Downloads -> Stamps in Class Tutorials.
  • WAWAWAWA Posts: 5
    THX~~
