need help with using 2 stamps at once — Parallax Forums
betaboybetaboy Posts: 8
edited 2005-03-02 21:21 in Learn with BlocklyProp
how do u connect 2 BS2 stamps together, so they are being used in one program, but you increase the # of I/O
pins that are able to be used?
    edited 2005-03-02 14:31
    User SEROUT on your "master" Stamp to send command messages to the "slave" (that uses SERIN to receive them).· Our help file shows how to user SEROUT/SERIN between Stamps with flow control so that messages don't get lost if the slave is busy doing the last task.· And this article from Nuts & Volts gives a specific master/slave example:
    http://www.parallax.com/dl/docs/cols/nv/vol3/col/nv81.pdf
    Jon Williams
    Dallas, TX· USA
  • Jim McCorisonJim McCorison Posts: 359
    edited 2005-03-02 16:27
    Betaboy,
    You can't directly connect a second stamp and have more IO pins. You have to write a program that runs in the second stamp and manages the IO lines and sends the data to the a program running on the first stamp.
    If you just want to have additional IO lines you'll want to use a decoder like a 74HC138 which will allow you to control 8 IO lines from 4 pins. You can cascade them to have even greater expansion, such as using only 5 pins to control 24 IO lines.
    Jim
    If you're looking at "dumb" expansion chips, consider the 74HC595 (outputs) and the 74HC165 (inputs). Very easy to use, stout, and we have lots of demo code for them.
    Jon Williams
    Dallas, TX· USA
