110vac to 5vdc — Parallax Forums
110vac to 5vdc
nick bernardnick bernard Posts: 329
edited 2005-02-25 01:52 in General Discussion
does anyone have any experiance with small scale ac dc conversions? i only need about 200mA. i know i can get a wall mount power supply but i would much rather incorporate the supply into my application.
League Bowling.... it's not a sport, it's a way of life
  • Robert SchwartzRobert Schwartz Posts: 141
    edited 2005-02-24 16:04
    I think that one of these transformers should work. Takes the volatage down to about 10V. Tie that into a 5v regulator, and you got 110vAC down to 5vDC
  • nick bernardnick bernard Posts: 329
    edited 2005-02-24 17:03
    thanks robert
    edited 2005-02-24 17:10
    Nick,
    ·· You didn't specify voltage, so I'll guess you meant 5V.· If you want to build your own on-board supply, you could buy the following at Radio Shack (Or pilfer them from something else):
    • 12.6V 300mA PCB Mount Mini-Transformer (273-1385)
    • PCB Mount Full Wave Bridge Rectifier (276-1152)
    • 100uF Radial Electrolytic Capacitor (272-1028)
    • .1uF Ceramic Disc Capacitor (272-135)
    • 7805 Voltage Regulator (276-1770)
    • 1000uF Radial Electrolytic Capacitor (272-1032) Almost forgot that one!
    About $15.00 in parts and could easily be mounted on a PCB taking up very little real-estate.· If you think you might ever need more than 200mA, for just a couple of dollars more you could use transformer (273-1365) at 450mA, or (273-1352) at 1.2A (The regulator will only give you about 1A though, and you'll need a heat sink).
    If you have any questions about how this all gets hooked up, let me know.
    --==<{Chris}>==--
  • MacGeek117MacGeek117 Posts: 747
    I would suggest getting those from www.goldmine-elec.com.
    bugg
    Geordi: "It's like the laws of physics went right out the window!"
    Q: "And why shouldn't they, there so inconvinient!"
    Geordi LaForge, Chief Engineer, USS Enterprise, NCC 1701-D
    Q, Omnipotent Prankster
