USB module DLP-USB232M not working? — Parallax Forums
SZSZ Posts: 3
edited 2005-02-24 02:44 in General Discussion
Just got module DLP-USB232M
How can I test it is working?
When I connect it to USB port - nothing happened...
I expected it should·show message·"New device found" under winXP
Am I doing something wrong?
  • Jim McCorisonJim McCorison Posts: 359
    edited 2005-02-24 00:03
    Did you wire up pins 3, 10, 11, and 12 per the data sheet?
    You might also read the FAQ on DLP Design's web site: www.dlpdesign.com/usb/faq.html
    Jim
    Post Edited (Jim McCorison) : 2/24/2005 12:09:51 AM GMT
  • SZSZ Posts: 3
    edited 2005-02-24 01:42
    Thanks! This web site was helpfull
    I wired pins 13 AND 14 and it got alive...
    Are you sure I should wire all pins you mentioned? Pin 3 is RESET
    Beats me. I didn't design it. But since the datasheet is written by those that did, and it states that you should do so, I'd be inclined to follow their instructions.
    Jim
