computer vision: video camera alternatives
lipservicelipservice Posts: 4
edited 2005-01-28 - 15:25:57 in General Discussion
low cost electronic sensor alternatives are there to video cameras?
ie
photosensitive transistors?
essentially i would like to be able recognize the area of an object (hand, paper cutout) placed directly above an array of sensors, and display a low res image (silhouette) of the object on an lcd.
    edited 2005-01-28 - 09:41:41
    Well, in a robot-building book they mentioned taking an old 2114 or similar RAM chip with the metallic top, carefully remove the lid and using the chip as a CCD...
    I have no idea how good it is, or where to get hold of the chips...
    edited 2005-01-28 - 14:33:54
    You could also look for one of those cheap 'keychain' digital cameras and hack it apart to get the lens and CCD chip.
    (But where to find the data-sheet?)
  • steve_bsteve_b Posts: 1,563
    Those keychain cameras are nice and cheap....got me a couple for some future projects....but what then you'd need is a way to convert it from it's digital (file-like) format in to a video signal for an LCD.· Assuming you'd have some sort of component input, you'd have the image to that....
    The CMUcam will track colour blobs for you.· but I don't know how you might output that signal to a display.
    There is this method from seattle robotics: http://www.seattlerobotics.org/encoder/200110/vision.htm
    Steve
    http://members.rogers.com/steve.brady
