EMI and the SX52 — Parallax Forums
EMI and the SX52
Paul BakerPaul Baker Posts: 6,351
edited 2005-01-25 22:29 in General Discussion
I was reading through the EMI literature for the SX52 (http://www.parallax.com/dl/appnt/sx/An34Sx52Emii.pdf)
and came across this passage:
4.2 Reducing the Power and Ground Loop Area
The long supply lines with the relatively large areas that these lines surround may form an effective antenna. At the frequencies present, an unacceptable level of interference may be radiated. A grounded area under the SX device must be connected to the Vss pin. In addition, the ground area should be tied to the ground plain with multiple vias. This ground area ensures that the major part of the field lines emanating from the SX are concentrated between the SX and the ground level.
Does this mean it is suggested that we place a ground plane on the same side as the SX52 (fitting within the solder pads) and connect it to the ground plane on the other side of the board through vias? Is routing signals directly underneath the chip a frowned upon practice? I am commiting my design to PCB and wish to avoid any issues (especially in the black art of EMI), since this is the first time I'll be pcb'ing a system running at this frequency.
Paul
for a photographic explanation of what I'm talking about look at figure 4.3 (pg 9) of this document: http://www.sparkfun.com/datasheets/IC/CP2101Rev1_5.pdf·the center landing connected to the ground pin through the hatched gray area, and vias in this rectange connecting it to a ground plane the other side of the pcb
Post Edited (Paul Baker) : 1/22/2005 9:06:23 PM GMT
  • steve_bsteve_b Posts: 1,563
    edited 2005-01-24 01:21
    In school, for what I remember (which isn't much), the ground traces were a lot larger than the signal traces.
    I would say that try to route your sensor paths away from paths that would contain some AC/noise.· Certainly don't route them parallel to them if you don't have to....they say if you must cross paths, do it at a 90deg angle.
    It really depends on how 'tight' your design is supposed to be....are you measure .Nths of volts on an A/D? then yes you'd definately want to have a 'quiet' board.· Also, you'd want to 'couple' any inputs and outputs on to your board.· Again, dependson how tight you want it!
    the via's they are talking about are throughboard interconnections (little holes in the board that go to a trace on the other side; they're usually filled with solder for electrical conneciton)....
    Steve
    http://members.rogers.com/steve.brady
  • mojorizingmojorizing Posts: 249
    edited 2005-01-24 17:12
    Hi Paul,
    Like you, this is my first time using a SX52 and the third time I've used ExpressPCB to make my boards. I used the 52 Con Carne
    as a proto type on a bread board and I had no noise problem, so on my circuit I modeled the area around the SX52 similar to the layout of the 52 Con Carne. Prior to designing the board, I also read the article you mention. It's got some good points to follow ; however, that evaluation board they used to test the SX52 is no longer around, so I'm not sure of the layout of ground planes, traces, etc.
    My circuit operates at 20mhz and uses no analog signals so that unto itself lends it to a more robust environment. The 52 Con Carne
    has one ground plane on the bottom layer that pretty much has the same profile as the chip except for a few spots on the edges where vias are used to bring some pins down and out to the DIP pins. I think because of the nature (SMT to DIP) of the Con Carne, the traces radiate out from the chip, there's no need to pass under the chip on the top layer.
    Obviously, I can't see what's going on on the top layer below the SX52, but it's apparent that the Vdd and the Vss traces come in to the chip as two lines with one by-pass capacitor. The Vdd and Vss traces then branch out on the top layer under the chip connecting all the Vss and Vdd pins respectively. I did my board likewise; the Vss and Vdd pins all respectively connect on the top layer beneath the chip and my by pass capacitor (0.1 mf tantalum, not SMT) is mounted on the opposite side of the chip with the leads that poke out towards the chip cut flush so that they don't protrude. The open real estate is filled in with ground planes on top and bottom and inter connected with vias. I have 5 other digital chips on the miniboard (3.8"x2.5") all with their own by pass capacitors plus a couple of caps on the 7805 voltage regulator. All in all, the Con Carne PCB isn't that elaborate, one by pass cap and a small ground plane. With it's long leads and stuck into a proto board with it's associated noisy environment it worked well.
    As far as passing signal traces under the chip, I have one that loops from one pin to a pin further down the same side of the chip. I needed the MIWU capability of a pin on port B but needed to read in the complete byte on port c, hence the splitting of an input signal to 2 pins. I don't anticipate any false signals due to any noise, but that remains to be seen. My boards are expected to arrive on wednesday. I hope this helps but I can't be any more scientific... my "semi-anechoic chamber" happens to be the corner of my garage where I have my electromnics bench.
    later, Kevin
    There are 10 kinds of people in the world.... those that know binary, and those that don't.
    edited 2005-01-24 18:10
    Thanks alot Kevin, you mind posting a digital photo of the underneath of your con-carne? Or perhaps someone from parallax can *gentle nudge*. I can get enough of a feel of what the top surface is by looking at the photo on the site. My layout will use as much smd as possible and I likewise plan on the bottom surface being reserved for power and ground (I haven't looked if they exist yet, but if they do, I plan on trying to use zero ohm smd resistor chips for jumps on the top surface, giving trace priority to high frequency lines to minimize reflection source effects) My design is at 50MHz, and I am designing it so that it could be scaled to 75MHz by just swapping the oscillator (it would require tweaking state machine design too, but thats a simple mod).
    Paul
    edited 2005-01-24 20:03
    This is the backside. Pin 1 is in the upper right, The left most bigger trace on the top is Vdd. the next small trace to the right of that is MCLR. The 2 traces on the right side ( next to the single via connected to the ground plane) are OSC2 and OSC1 from top to bottom. The 3 traces on the right below those are RA0, RA1,RA2.
    later, Kevin
    edited 2005-01-24 22:03
    Thanks Kevin, That gives me a good understanding of what they are doing
  • John BJohn B Posts: 82
    edited 2005-01-25 01:35
    Hi there.
    ··· A very interesting topic indeed.· As we·design boards·for the SX, we try stick to these guidlines:
    1)· All four SX48/52·VSS connections connected to a ground plane.
    2)· All four SX48/52 VDD connections connected to a power plane or fat supply line >30mil wide for 1/2 oz Cu.
    3)· SX chip should be located as close as possible to the power source.· The oscillator/crystal/resonator should be located as close as possible to the SX chip.
    4)· Power connection traces, both VSS and VDD, should be short and fat.
    5)··Place a decoupling cap (o.1uF or so), at each VDD pin.
    6)· The smaller the via that you use, the more of them you should use when you connect something down to the ground plane.· Larger vias are better.
    7)· Flood ground liberally and use many vias to connect to ground planes on other layers.
    8)· Try to flood ground around high-impedence circuits.· This practice can help cut cross-talk and noise on sensitive lines.
    If you have a design that you would like to have reviewed, you are welcome to send it to me for comment.· Just use the contact info below to send a JPG, BMP, or·a PDF of your layout if you are interested.
    John Barrowman
    Engineering
    www.parallax.com
    jbarrowman@parallax.com
    edited 2005-01-25 02:47
    Thanks for the tips John. I'm using Eagle PCB which I don't think outputs to any of those formats, but I can always use a screen capture program. I plan on doing as much of the underside with a ground plane as much as possible with power dissecting (with fat traces) to provide power to the needed circuits, and decoupling capacitors place sporadically (in addition to caps near vdd/vss of chips), and ultra low resistance (.02 Ohm) bridges from ground to ground across vdd traces where ground loops are longer than should be (ground return·of any chip must circumnavigate a vdd trace to return to source). Do you suggest a ground plane (as shown in Kevin's photo·of the backside of the SX52 con carne) on the front side underneath the SX52 as well?
    Paul
    P.S. I have noticed a greater number of Parallax employees participating in the forums and I am thankful and appreciative for it.
    Post Edited (Paul Baker) : 1/25/2005 2:50:27 AM GMT
    edited 2005-01-25 16:57
    Hi Paul,
    I like to flood ground where ever I can. However, considering the SX's pin-out, I typically flood a VDD plane beneath the SX chip on the top layer and connect it with several vias to a really fat supply trace on the bottom layer. This helps afford room for decoupling caps on the top layer at each VDD pin. With ground flooded liberally on the bottom layer, it is then easy to plant vias near each VSS pin.
    If you are more concerned with dissipating the heat of the SX chip you can flood ground below the SX chip on the top layer and use plenty of vias to connect it to the ground plane on the bottom layer.
    A ground plane is no substitute for a heat-sink, but in some circumstnces may make the difference between using a heat-sink or not.
    John B.
    edited 2005-01-25 18:18
    Gotcha, I think I may go with ground plane on bottom, power plane on top, it will reduce the resistance of the Vdd lines since it will be imported via thick traces instead of a plane as the ground is. Plus this would serve as an additional decoupling cap (albiet a pretty weak one). Do you suggest low ESR (<.3 Ohm @ 100kHz) tantalum caps for decoupling when operating at 50MHz+, and is a 10uF 6.3V (8V surge) sufficient or should I increase the value or voltage? I plan on placing a smd electrolytic (100uF 16V) at the power jack (The wall wart is regulated so there is no on board regulation, except for 3.3V components).
    Paul
    Post Edited (Paul Baker) : 1/25/2005 6:23:07 PM GMT
    edited 2005-01-25 21:35
    Hi Paul,
    Low ESR caps are a good idea for 50M+ operation. When you stuff the board for the first time, check the VDD rail for oscillation. Fine print: some regulators cannot handle low ESR caps on their output and may oscillate, so test it before you put it in concrete.
    John B.
    edited 2005-01-25 22:03
    Unfortunately I do not have access to an oscilloscope at this point in time, will the electrolytic mask the regulator from oscillation effects caused by low ESR caps? My supply is http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F009%5F001%5F001%5F002&product%5Fid=273%2D1696
    It says it has an EMI filter, will this help the regulator from oscillation due to low ESR caps or is this just to prevent EMI injection from/to the AC power?
    edited 2005-01-25 22:25
    Hi Paul,
    That power supply should do fine. Don't worry about oscillations. The EMI filter will prevent high-frequency noise from propagating in both directions. Go ahead and use low-ESR caps to decouple the SX.
    John B.
    Thanks John for all your help.
    -Paul
