scenix 28 in pcb123 parts library?
detectordetector Posts: 1
Does anyone know of a download for a scenix 28 part or a pic 16c57 for the PCB123 parts / schematic library? It seems this would be a common need. There must be something similar for Eagle. I am still using version 1 of PCB123 but may get to version 2 soon.
  • 4 Comments sorted by Date Added Votes
    edited January 2005 Vote Up0Vote Down
    Shouldn't you check with the folks who make PCB123?...
    Jon Williams
    Dallas, TX· USA
    You can add anything you want to their library (on your own computer) through the provided software. 28 pins is not much to handle, 52 pins is a bit of a job.
    The advantages with this approach are that you can use proprietary designations for key components if you don't want others to simply copy and populate your board.
    Actually, the correct design is your responsiblity, so they just care that you provide files that make manufacture doable. They do provide proto-typical packages to work from.
    And once you have the SX-28 in there, it will save time in the future.
    G. Herzog in Taiwan
    Hwang Xian Shen, Puddleby-on-the-Marsh.
    All things considered, I can live and thrive without Microsoft products. LINUX is just fine.
  • Guenther DaubachGuenther Daubach Posts: 1,321
    For EAGLE, you can find SX-related component libraries on Cadsoft's site at
    ftp://ftp.cadsoft.de/pub/userfiles/libraries/scenix4.lbr
    ftp://ftp.cadsoft.de/pub/userfiles/libraries/ubicom.lbr
    ftp://ftp.cadsoft.de/pub/userfiles/libraries/ubicom_v2.lbr
    Greetings from Germany,
    G
