BS2/VB connection problem
I am working on a data collection project using VB6.0.
When I try to compile my VB program, I get an "Object required" error
for any any "mscomm..." statement. Any help would be appreciated.
Marylou
  • 10 Comments sorted by Date Added Votes
    edited January 2004 Vote Up0Vote Down
    > Marylou
    Have you added the MSComm activex control to the project, and dropped
    it on the form?
    -Bruce
    tech@r...
    http://www.rentron.com
    Sounds like you need to add MSComm to your project. Go to Projects |
    Components (or Control+T) and see that MSCOMM32.OCX is checked. If you don't
    have it at all, you need to install it or register it. There are some
    replacements referenced at http://www.lvr.com
    Al Williams
    AWC
    *NEW: Universal PCB fits Stamp, SX, more
    http://www.al-williams.com/gpmpu40.htm
    > From: astumpf999 [noparse][[/noparse]mailto:astumpf999@y...]
    > Sent: Friday, January 09, 2004 3:55 PM
    > Subject: [noparse][[/noparse]basicstamps] BS2/VB connection problem
    > Marylou
    > from the same email address that you subscribed. Text in the
    > Yahoo! Groups Links
    > To visit your group on the web, go to:
    > http://groups.yahoo.com/group/basicstamps/
    > To unsubscribe from this group, send an email to:
    > Your use of Yahoo! Groups is subject to:
    How do I install or register mscomm32.ocx? I checked it in the
    components box, clicked on the "Apply" button and still get the same
    error message.
    Marylou
    ________________________________
    you don't
    some
    > Al Williams
    Well if it is in the list and checked then I suspect you already have it.
    You could find the ocx and run :
    regsvr32 mscomm32.ocx
    That will cause it to self-register. And you do have it dropped on the form
    with the right name, right? You can see an example, btw, at
    http://www.al-williams.com/stampcom.zip
    Al Williams
    AWC
    *NEW: Universal PCB holds Stamp, SX, more...
    Sent: Friday, January 09, 2004 8:55 PM
    Subject: [noparse][[/noparse]basicstamps] Re: BS2/VB connection problem
    error message.
    Marylou
    you don't
    some
    > Al Williams
    Yahoo! Groups Links
    Your use of Yahoo! Groups is subject to: http://docs.yahoo.com/info/terms/
    Al,
    Thanks for your help. I looked at your program and found the
    mscomm32.ocx object entry. My question is how did it get there or how
    do I "drop it in the form"? Could you get a bit more specific?
    This may be a simple thing to a professional programmer. My only
    previous experience was quickbasic for hobby projects and I find VB
    somewhat overwhelming.
    Marylou
    ______________________________________
    have it.
    the form
    > Al Williams
    > AWC
    same
    > error message.
    > Marylou
    Projects |
    > you don't
    > some
    > > Al Williams
    Subject and
    > Yahoo! Groups Links
    Marylou:
    You must have VB Professional to use the MSComm control in your own
    projects. If you don't have VB pro, you'll need to find an MSComm
    replacement. A couple people have built wrappers around the MSComm
    control do that it could be released and used all users.
    If you do have VB Pro, you can make the MSComm control available to your
    project by going to Porject | Components, then selecting MS Comm Control
    and clicking [noparse][[/noparse]Apply].
    -- Jon Williams
    -- Parallax
    Sent: Saturday, January 10, 2004 12:49 PM
    Al,
    Marylou
    have it.
    the form
    > Al Williams
    > AWC
    same
    > error message.
    > Marylou
    Projects |
    > you don't
    > some
    > > Al Williams
    Subject and
    > Yahoo! Groups Links
    Yahoo! Groups Links
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    Yes, when you add the component it should show up on your palette. Then just
    double click it to put one on the form (or drag it out like a button, but it
    will stay the same size). This control only shows up at design time not run
    time.
    If you need a replacement, look at http://www.lvr.com for more.
    Al Williams
    AWC
    * Easy RS232 Prototyping
    http://www.al-williams.com/rs1.htm
    Al,
    Marylou
    have it.
    the form
    > Al Williams
    > AWC
    same
    > error message.
    > Marylou
    Projects |
    > you don't
    > some
    > > Al Williams
    Subject and
    > Yahoo! Groups Links
    Yahoo! Groups Links
    In the 'Files' section, see AlDemo\BS2_VBDemo.zip
    This file has:
    1. A complete example, both VB side and BS2 side.
    2. A 'readme.txt' file, which tells you how to
    create the application on VB from scratch.
    See the .TXT file for exact drag-and-drop instructions
    on how to use the MSCOMM control. It DOES assume
    you have the VB5 PRO or VB6 PRO versions.
    --- In basicstamps@yahoogroups.com, "astumpf999" <astumpf999@y...>
    error
    > Marylou
    Thanks guys for all the help. My stamp is now talking to VB!
    Marylou
    --- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
    > This file has:
    > error
    > > Marylou
