Question on 3 wire stepper motors. — Parallax Forums
edited 2003-10-20 18:24 in General Discussion
I've not been able to find any info on this type of stepper. Most
commonly seen in old drives. Could someone post a quick explaination
on how these drives work?
Atomix
    edited 2003-10-18 17:19
    The little Switek synchronous motors are three wire steppers like the
    synchronous motors your talking about. These motors today have 5 or 7
    coils and use fancy synchronous motor controllers. These motors are
    common in hard disk drives nowadays.
    www.didel.com has some basic Stamp code examples for actuating these
    motors. You can scale it up using more powerful driver half-bridge
    circuits. Go to their Documentation section to see their info about
    them.
    Basically, you have three wires. You alternately pulse each pair in a
    pattern so that it causes the motor to rotate. The pattern can overlap
    to achieve higher speeds too. You have to use a half bridge transistor
    circuit as one wire is driven high and the other wire is driven low at
    the sametime.
    From: Atomic Nixon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-jn9GzTGmC9Ksfb_2eirOTW1EBzdsuDxGxdR6wXcNteEiO7rowMWCaEimZyRZRYNyAYTOi2xCZTQL8qVqQGD]atomicnixon@h...[/url
    Sent: Saturday, October 18, 2003 3:14 AM
    Subject: [noparse][[/noparse]basicstamps] Question on 3 wire stepper motors.
    Atomix
    Your use of Yahoo! Groups is subject to
    edited 2003-10-18 17:35
    >Thanks
    >Atomix
    Atomix -
    Is this a motor from a floppy drive, or a hard disk ? If it's from a hard
    disk,
    it may be a 3 phase motor, and you'll have to find an appropriate driver chip.
    If there is a nameplate on it, the information from that may be helpful as
    well.
    Also, what type of computer was it removed from ?
    Bruce Bates
    edited 2003-10-19 23:00
    a hard
    > disk,
    driver chip.
    helpful as
    > well.
    These motors were from older HD's, 40 to 120 meg range (and whatcha
    gonna do with a drive that size eh?). They have three wires, Red,
    Black, Green. It seems three-wire steppers are an anomaly... Euch!
    By the way, how useful do you think THIS post is -->
    http://www.eio.com/public/stepper/0358.html
    Euch! Buddy! Could you possibly post ONE sentence on each wire?
    That would be three sentences... <sigh> Whadda yutz!
    So, these things are described as AC steppers... Hurm... been trying
    a couple o variations on how it could work. Eg: Neg on one wire, Pos
    on other wire, AC signal on third. I just hate the fact that there's
    NOTHING online on these suckers. Oh, and nothing turns up as far as
    searches are concerned, numbers/codes on the motor.
    Here's another one for those who know motors.... For figuring power
    draw... since it's a DC device, can you measure the resistance over a
    set of coils and use that to calculate amps drawn?
    Atomix
    edited 2003-10-19 23:24
    --- In basicstamps@yahoogroups.com, "Earl Bollinger"
    the
    7
    > them.
    a
    overlap
    transistor
    at
    > the sametime.
    Hey!!! Thanks loads! I belive the document yer talking about is
    this one --->
    http://www.didel.com/picg/doc/DopiSmoo.pdf
    Should be able to get it working now. Thanks.
    Here's another one on steppers... I'm using ULN2003's I scavenged
    from this digital display unit. Ran across this circuit which should
    double the number of motors I can control off the pic. Only needs
    two inputs. For some reason I can't get this sucker working, anyone
    know what I should be looking for?
    http://www.doc.ic.ac.uk/~ih/doc/stepper/control2/connect.html
    The diagram I'm talking about is about 1/3 of the way down and shows
    outputs from the 2003 being used to invert a couple of other pins.
    What's the limiting factors for drive speed? Would smoothing out the
    pulses (more sine, less square) give more speed? How the hell do
    they get these things running so fast?
    Atomicat
    edited 2003-10-19 23:51
    --- In basicstamps@yahoogroups.com, "Atomic Nixon" <atomicnixon@h...>
    from
    > a hard
    > > disk,
    > driver chip.
    > helpful as
    > > well.
    Euch!
    trying
    Pos
    there's
    as
    power
    a
    > Atomix
    I'll be happy to offer more incomplete answers.
    I'm of a mind that you really have a servo motor (the one that spins
    the disk as opposed to the one that moves the arms) and that it is
    just a simple DC motor with feedback for speed so the contorller can
    regulate the speed.
    but, generically speaking, you can ohm the coil and then using the
    manufactures recomended voltage, calculate the current.
    no manufactures recomended voltage ? check to see if the origional
    driving circuit has limiting resistors and what the voltage was.
    trashed the old boards ? shame on you, you also tossed a working
    drive circit and clues to how it was wired....but all is not lost.
    the motor wires will lead you down a path that might work. wire size
    of the coils cannot be less than the current carrying of the coils.
    ergo you can take a wild guess at the motor current based on the coil
    wire size. I'd say to de-rate by 50% to start, but you might be
    able to get up to about 100% of the current in that coil. remember
    steppers are pulsed so may be able to handle higher amps in pulses.
    one method is to run the motor till it gets warm. that is a sign it
    is near the limit..... most of the time. A larger stepper is often
    rated for 85degC which is HOT to you and me.
    did you ohm out the motor ? did you include the case as a possible
    4th connection ?
    Like I said, more incomplete stuff.
    Dave
    edited 2003-10-20 03:17
    You really should use CMOS FETS and not Darlingtons like in the ULN2003,
    as you have to create 1/2 of an H-Hbridge (half bridge) A n-channel and
    a p-channel MOSFET. Usually everyone uses square waves with MOSFETS as
    you want the on/off transition time to go through the analog range as
    fast as possible to limit heat buildup. MOSFETS are good at that. The
    problem with the darlingtons is they are all NPN thus you either have
    them all on or all off but not one on and one off.
    What you have to do is drive one motor wire both high and low
    alternately, and do this for all three motor wires in sequence. With the
    darlingtons (ULN2003) you can't do this properly. You can use either NPN
    and PNP transistors or N-channel and P-channel mosfets to make up
    half-bridges.
    If you study the internals of the PIC micro chips in the Didel.com
    articles, you'll see that the I/O ports are all MOSFET half-bridges
    which work Ok for the tiiny motors they are driving. For you to increase
    the power, you need to hook a PNP and a NPN transistor up to an I/O pin,
    so that when the Pin is low one transistor is On while the other is off
    and vice versa.
    The other thing is you have to start up the motor slowly at low speed
    RPM. Then ramp up the speed by increasing the pulse rate slowly. If you
    go too fast the motor sits there and vibrates and stops rotating.
    Usually they drive current more than voltage through the motors. As they
    want a strong electromagnetic pulse to get the rotor spinning. Once you
    get the motor up to speed you can reduce the drive current as you only
    need to maintain the speed steady at that point. As the speed increases
    they change the pulse rate and width and overlap as needed to match the
    motor to get it spinning at a good clip.
    The hard disk motors spin up to about 3600 RPM or so, depending on the
    hard drive model, new ones can run 10,000 rpm or better.
    The next thing is these are really low torque motors, so don't expect a
    lot of power from them.
    They use a special synchronous motor controller IC that has all these
    things built in, so the IC chip controls the motor and ramps up the
    speed et cetera automatically. Unfortunately these chips seem to have no
    documentation on them at all. R at least all the ones I looked at don't.
    Mostly Hitachi chips, they all seem to have part numbers thatdon't match
    up with anything that I have found.
    this one --->
    Atomicat
    should
    anyone
    shows
    the
    > Atomicat
    The step ON pulse needs to be set for the time it takes for each
    componet to react, but some overhead. if it takes the Stamp 1uS to
    reach a 5V output, then the darlington another 1uS, you need to have
    a minimum of 2uS 'ON' time, and doubling that would not hurt. once
    you get into the longer response times, you can reduce the overhead
    to just a little more.
    OF course you need to find out if the switching in on the rising edge
    or trailing edge for each component to really contorl what is needed
    for each chip.
    Then speed of a stepper is based on how fast you can charge the coils
    in the motor. remember it is an inductive load.
    The higher the voltage, the faster you can deliver the amps, but #1
    you must limit the amps with a chopper if you want really high
    performances.
    To get fast outputs you can just pulse fast.
    A note on steppers is that they have more power at low RPM's and get
    very weak in the high rpms. very weak.
    if you find you are not getting a high top end, but rather stall
    abruptly, but have gravel digging starting power, you can gear up the
    motor so make it run slower with a faster gear ratio.
    Dave
