serial cable color coding
Would anyone happen to know of a resource that lists the standard serial
cable color coding?
_________________________________________________________________
Send and receive larger attachments with Hotmail Extra Storage.
http://join.msn.com/?PAGE=features/es
  • 16 Comments sorted by Date Added Votes
    edited September 2003 Vote Up0Vote Down
    Yea, It's call an OHM METER. Would that be CHINA STANDARD or KOREA STANDARD
    or JAPAN STANDARD or CANADIAN STANDARD or USA STANDARD ?
    From: Christian Wentz [noparse][[/noparse]mailto:cwentz86@h...]
    Sent: Saturday, September 13, 2003 7:19 PM
    Subject: [noparse][[/noparse]basicstamps] serial cable color coding
    cable color coding?
    I don't think there is a standard, but an old tech who used to work for
    me would do them (at least the first 10) in resistor color code, black,
    brown, red, etc.
    Al Williams
    AWC
    * Control 8 servos at once: http://www.al-williams.com/pak8.htm
    > Sent: Saturday, September 13, 2003 6:19 PM
    > standard serial
    > cable color coding?
    There is no general standard for wire color on PC cabling, with the
    exception of marking pin 1 on ribbon cables, and the color of power
    supply and fan wiring. Everything else is probably gonna be factory or
    manufacturer specific.
    What Jim is trying to say is that because everyone has a different color
    code, you need to use an ohm meter or continuity tester to figure out
    what color wire goes to which pin on the cable that you have.
    > cable color coding?
    It may depend on if they use the metric or US color code as well? <grin>
    And don't get me started on the metric versus US electricity.
    > brown, red, etc.
    > > standard serial
    > > cable color coding?
    In a message dated 9/13/2003 6:27:55 PM Pacific Daylight Time,
    alw@a... writes:
    brown, red, etc.
    Al Williams
    AWC
    I do the same, and think it is a good idea. If you are consistent with this
    method, at least one knows number 1 through 10
    I do not think the color coding of cables is arbitrarily.
    If you look a telephoneman splicing hundreds of wires , they follow
    a color code scheme.
    Perhaps there is an ANSI standard (they have standards for almost
    everythinng).
    If you are a telephone man, with a 50-pair telephone
    cable, you'd better have a standard for what pair
    of wires goes where. If you're installing a
    50 foot 8-wire cable between a PC and a Modem, you have
    a lot more lattitude.
    If you are installing an "RS-232" "Standard" cable
    (ansi standard RS-232, RS-232b, RS-232c) well:
    You could install a DB25 with all pins connected,
    all pins defined -- but I don't think they spec
    the color.
    You could install a DB25 with only the common 8
    lines -- RX,TX, CTS,RTS, DCD,DTR,DTS, and Ground.
    Oops, forgot 'RI' (ring) used by the PC as IRQ input.
    Or you could do DB9. Or you could do RJ45 (like
    DEC and Stallion did). Or you could do 'three-wire'
    (TX, RX and Ground).
    The point is: the RS-232 'Standard' came out so
    early that it's evolved quite a lot, and been
    used in MANY form factors. It's amazing
    that it's as portable, and still works, as it is.
    There IS a specification, but I really don't think
    it calls out wire colors.
    --- In basicstamps@yahoogroups.com, "Albert Catano"
    follow
    > everythinng).
    Well I would think there would be a standard ! if nothing more than just pin
    to color standard ! But I can't find anything. I have used wire color to pin
    numbers, but can't find the chart, and it wasn't specific to rs232.
    Larry Gaminde
    To: "Basic Stamp List" <basicstamps@yahoogroups.com>
    Sent: September 13, 2003 6:28 PM
    Subject: RE: [noparse][[/noparse]basicstamps] serial cable color coding
    STANDARD
    > > cable color coding?
    Now I lay me down to sleep
    With a roll of cable at my feet
    If I should die before I wake
    White, Blue, Orange, Green, Brown, Slate.
    Sent: Sunday, September 14, 2003 8:23 AM
    Subject: [noparse][[/noparse]basicstamps] Re: serial cable color coding
    > the color.
    > follow
    > > everythinng).
    As Allan and others have said, there is not a standard for wire colors.
    Each factory lot will use the same color sequence, but different
    factories/lots will vary. We use a M-F DB9 cable for a commercial
    device, by cutting the cable at one end, discarding the connector, and
    wiring the cable to our circuits, using a few hundred per year. We try
    to buy from the same place, but periodically check the colors and pins
    to avoid circuit disasters. We like and use black cables from Jameco,
    to match our black instrument cases.
    Dennis
    From: Allan Lane [noparse][[/noparse]mailto:allan.lane@h...]
    Sent: Sunday, September 14, 2003 8:24 AM
    the color.
    follow
    > everythinng).
    Speaking of that, does anyone still make a cable with removeable shells?
    Most everything I see has molded ends, which means you have to chop off
    one end and put on a fresh connector if you need to make a custom cable.
    Bad -- Black -- 0
    boys -- Brown -- 1
    race -- Red -- 2
    our -- Orange -- 3
    young -- Yellow -- 4
    girls -- Green -- 5
    behind -- Blue -- 6
    victory -- Violet -- 7
    garden -- Gray -- 8
    walls -- White -- 9
    Above is a non-bawdy version of the resistor
    numbering color sequence, which DOES NOT apply
    (necessarily) to RS-232. ("Bad boys rape our
    young girls, but violet gives willingly" is
    the 'PG-13' version)
    Note that CAT-5 cable has Orange/Orange-Stripe,
    Blue/Blue-Stripe, Green/Green-Stripe,
    Brown/Brown-Stripe. This CAN be used for
    RS-232 also.
    --- In basicstamps@yahoogroups.com, "Stephen H Chapman"
    > From: "Allan Lane" <allan.lane@h...>
    > > the color.
    > > follow
    almost
    > > > everythinng).
    Subject and
    I collect these.
    There are many variations on the Bad boys... I have also heard Bad Beer
    Rots Our Young Guts but Vodka Goes Well.
    Bad Betty runs over your garden but Violet Gray won't
    Billy Brown Revives On Your Gin, But Values Good Whisky
    Better Be Ready, Or Your Great Big Venture Goes West
    Black Beetles Running On Your Garden Bring Very Good Weather
    The one about batman is unrepeatable but the clean version is
    Batman Bests Robin On Yonder Gotham Bridge; Very Good, Will Get
    Superman Next
    Al Williams
    AWC
    * Add floating point math to your Stamp program:
    http://www.al-williams.com/pak1.htm
    > Sent: Monday, September 15, 2003 10:09 AM
    > Bad -- Black -- 0
    > boys -- Brown -- 1
    > race -- Red -- 2
    > our -- Orange -- 3
    > girls -- Green -- 5
    > behind -- Blue -- 6
    > garden -- Gray -- 8
    > walls -- White -- 9
    > RS-232 also.
    > > > the color.
    > arbitrarily. If you
    > > > follow
    > almost
    > > > > everythinng).
    > Subject and
    Could you send me the R or X versions off list.
    Larry Gaminde
    Sent: September 15, 2003 10:31 AM
    Subject: RE: [noparse][[/noparse]basicstamps] Re: serial cable color coding
    > I collect these.
    > Superman Next
    > Al Williams
    > AWC
    > > Bad -- Black -- 0
    > > boys -- Brown -- 1
    > > race -- Red -- 2
    > > our -- Orange -- 3
    > > girls -- Green -- 5
    > > behind -- Blue -- 6
    > > garden -- Gray -- 8
    > > walls -- White -- 9
    > > RS-232 also.
    > > > > the color.
    > > arbitrarily. If you
    > > > > follow
    > > almost
    > > > > > everythinng).
    > > Subject and
    Just remember, B is blue, while black is K on alot of diagrams.
    > I collect these.
    > Superman Next
