BS2, PULSOUT, and servo question
hi....newbie here,
connection a modified servo to the BOE and bs2 , i tried to vary
the "pulsout pin, rate" from pretty much zero to well inot the
900's,....and it always turns the same way.
the only way i can get it to turn the other direction is to use
smaaaalll negative fractions... like (-1/32)
what am i doing wrong and/or what values do you guys use?
thanks fer the help!
Greg
  • 3 Comments sorted by Date Added Votes
    edited July 2001 Vote Up0Vote Down
    Depending on which BS2 you have, the value could be in the thousands. I
    can't remember what I use for the BS2SX, but its somewhere in the 1000 range
    for neutral, and the BS2E is around 320 using a Futaba servo.
    Are you using a variable for the PULSOUT statement? If so, you are proabably
    using a byte-sized variable (holds value of 0-255) instead of a word-sized
    variable (holds value 0-65525).
    Greg,
    You may not be going high enough to get it to go the other way. Try using a
    larger value. An older pair of servos I have takes 1200 and 650 for forward
    and reverse.
    - Brice
    Educational & Personal Robots
    http://www.cyberbound.com
    Sent: Thursday, July 12, 2001 5:14 PM
    Subject: [noparse][[/noparse]basicstamps] BS2, PULSOUT, and servo question
    > hi....newbie here,
    > Greg
