Adding Words — Parallax Forums
Adding Words
edited 2000-10-07 19:30 in General Discussion
I was passed along the following code to add 2 words, data(1) and
data(2), together:
work var word
work=0
work=work+data(1) 'Load first byte
work=work+work<<8 'Shift to High byte
work=work+data(2) 'Add in Low byte
My question: Where in the STAMP users manual is this shown on how to
shift to the High byte ("work+work<<8")
..or is there something in the public domain on programming with the
STAMP besides what Parallax offers?
Thanx
Jay
    edited 2000-10-07 19:05
    In a message dated 10/7/00 12:03:10 PM Central Daylight Time,
    pcb4u@e... writes:
    > data(2), together:
    > work var word
    > work=0
    There seems to be a lot of unnecessary work here. If the point is to move to
    bytes into one word-sized variable, it's pretty easy:
    work = (highByteVar << 8) + lowByteVar
    or, if you want to deal with the bytes individually:
    work.HIGHBYTE = highByteVar
    work.LOWBYTE = lowByteVar
    If, indeed, you want to add the value of the two seperate bytes (perhaps they
    are independently modfied by your program) to a word-sized variable, one way
    is to alias your byte variables to a word variable, then it's simple addition.
    Note that the Stamp considers all of it's memory an array -- in fact, the
    array index is just an offset (same size as target) from the target variable.
    The point is, you don't have to declare an array to use one. Take a look.
    work1 VAR Word
    work2 VAR Word
    byteVar VAR wordVar2.HIGHBYTE ' can be called byteVar(0)
    byteVar2 VAR wordVar2.LOWBYTE ' can be called byteVar(1)
    work1 = work1 + work2
    This technique does not use any more memory than your example and it's
    certainly easier to understand. BTW, the discussion of the shift operators
    is on page 244 of the Stamp manual (Version 1.9).
    -- Jon Williams
    -- Dallas, TX
    edited 2000-10-07 19:22
    You are using the Stamp II or IISX and not a Stamp I, right?
    The << operator is documented with the rest of the operators (page 239 of
    the printed manual I have). You can also read about it on page 140 of my
    Microcontroller Projects with Basic Stamps which organizes functions and
    operators by function instead of alphabetically.
    However, I'm not clear what your code is trying to do. You imply that
    data(1) is a byte. since work=0 then work+data(1) is just data(1). So a
    simple transliteration of your code could be:
    work var word
    work = work + (data(1)<<8) + data(2)
    If work did not have zero in in, then your code doesn't add at all. Because
    adding the high byte to the low byte would be a bad idea. In other words,
    work=$80AA data(1)=$01 data(2)=$00 (you know arrays start at 0 right?). So
    work+data(1)=$80AB, after the shift you have $AB00 and then adding zero
    leaves that as the answer instead of $81AA.
    However, there are several other ways to do this that might be more
    efficient. For example:
    work.highbyte=work.highbyte+data(1)
    work=work+data(2) ' don't use lowbyte or carry won't propagate
    You can also equate variables (like a union in C or an equivalence in
    Fortran if anybody else is that old). However, with the arrays, starting at
    1 I'm not sure if that is an option. Consider this (data is a reserved word,
    so I'm using datas):
    dword var word
    datas var dword.lowbyte
    work var word
    datas(0)=$AA ' low part
    datas(1)=$55 ' high part
    debug hex dword
    work = work + dword ' work = work + $55AA
    However, I can't figure how to make this work with a partial array. The code
    above works because every variable is an array in PBasic if you want it to
    be. However, I couldn't see an easy way to "slide" the equivalence to a
    separate element in an existing array.
    Al Williams
    AWC
    * Floating point math for the Stamp, PIC, SX, or any microcontroller:
    http://www.al-williams.com/awce/pak1.htm
    > From: Jay Kobelin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=96bAYz-x2bmtRG5KKiY0FKcnuBE3fvQGPWsOCLgq2B2I1xT5Tt6VO6ktzG7sHneSVtgaQNNgvHH69yk5]pcb4u@e...[/url
    > Sent: Saturday, October 07, 2000 12:02 PM
    > To: basicstamps@egroups.com
    > Subject: [noparse][[/noparse]basicstamps] Adding Words
    > data(2), together:
    > work var word
    > work=0
    > Thanx
    > Jay
    >data(2), together:
    > work var word
    >work=0
    Hi Jay,
    There's a bitty bug in that code, as the shift should read:
    work=work+(work<<8) ' with parens
    work=work<<8+work ' executes left to right
    because the stamp executes stricly from left to right, without precedence,
    unless you use parentheses.
    Also, DATA is a reserved word for the stamp. Better choose a different
    variable name. No need for the initial "work=0". The whole thing can be
    put on one line:
    work=mydata(1)<<8+mydata(0) ' combine two bytes into one word.
    Array variables are numbered 0,1,...
    There are some tricky ways to do it by using alias variable names:
    work var word
    mydata var work.byte0 ' name for the low byte of work
    ' now mydata(0) and mydata(1) are implicitly the two bytes of work.
    ' no assignment statement required.
    I recall that Al gave a great response where this came up in the earlier
    thread, to point out the alternatives using the SERIN modifiers to combine
    bytes that arrive via a SERIN command.
    The << operators are explained in the stamp manual v1.9 on pg 246. This
    use of << to combine bytes is elementary computer science.
    Here are some links that lead into a huge amount of free material on stamp
    programming:
    http://www.stampsinclass.com
    http://www.hth.com/losa.htm
    http://www.geocities.com/stampic/links.htm#top12
    http://www.seetron.com/links.htm
    http://www.al-williams.com/wd5gnr/stampfaq.htm
    http://www.emesystems.com/BS2links.htm
    -- Tracy Allen
    Electronically Monitored Ecosystems
