3-prong plug — Parallax Forums
3-prong plug
edited 2000-10-07 06:18 in General Discussion
The 3-prong adapter plug included in the "What's a Microprocessor" kit
seems to not be long enough on just one side. This adapter is used
to plug the servo to the Board of Education breadboard. The pins
seat just fine on the other end. Any suggestions?
    edited 2000-10-06 05:44
    I'm not familiar with the plug and cable, but could you have it reversed
    (end-to-end) ??
    edited 2000-10-06 16:05
    What worked for me was to...
    Grasp the plastic portion of the 3-prong, and press the long end of the pins
    down onto a hard surface. The plastic will slide on the prongs--use this to
    center the plastic on the pins' length.
    Daniel McGlothin
    From: tntmod@l... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Zgt_w2a1Cx8VBJIbkL6uK8maj281XoWXtLQUiwm_VExbyzEBXgufnd3-K4glJGaA7wDZDeYvYXffcFOw5A]tntmod@l...[/url
    Sent: Thursday, October 05, 2000 11:28 PM
    To: basicstamps@egroups.com
    Subject: [noparse][[/noparse]basicstamps] 3-prong plug
    edited 2000-10-06 17:10
    I had this same problem. There is something in one of the manuals (possible
    the one on Robotics) that shows that you can just push the pins through the
    center black strip so they are equal on both sides. I personally tried this
    and it did work sort of. They are now equal on both sides, but when you try
    to plug them into anything they just slip through the black center piece.
    So they are pretty much useless to me. I've been meaning to replace them,
    but haven't gotten around to it. For now, I have just plugged jumper wires
    from the breadboard to the servo. I know it's a sloppy solution, but at
    least I did get the servos to work.
    Shawn
    From: tntmod@l... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aeE_pOyOJ2KhIrAyPR9KDZG72XpGViBSM0QgPx01N4s6Sf68uP072W1VDGeS4iEOCfyFSVpX5ZWZm9tkCA]tntmod@l...[/url
    Sent: Thursday, October 05, 2000 9:28 PM
    Thanks for your help, it worked great. I didn't realize the pins would
    slide, actually I was afraid to try until someone suggested it. Tony
    To: <basicstamps@egroups.com>
    Sent: Friday, October 06, 2000 10:05 AM
    Subject: RE: [noparse][[/noparse]basicstamps] 3-prong plug
    pins
    to
    > Regards,
    > Daniel McGlothin
    > From: tntmod@l... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nsz5n7MSt8qkJyMOM0Cv-PpGW3NfmPyYiasomfuuqi9kIAXywFc9xw8zjXUEw4ADmih_gz3I7SrVU9_Y6FY]tntmod@l...[/url
