Winscope (OT) — Parallax Forums
Winscope (OT)
edited 2000-08-21 02:38 in General Discussion
Howdy Wayne,
It looks like DSE have a waveform generator kit too. See cat. number K7348
at www.dse.com.au. I don't know if the software is Windows based (but what
are the chances of it not being?).
Lance.
> From: Vegman@I... [noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KWnFXGTjLMd1wI8Ph93PPKQcidDPq8A_kFub0MhemXceMNs4vx3vbE3BC53rn-LxS3jAYJVnMVI]vegman@i...[/url
> Sent: Monday,21 August 2000 11:07
> To: basicstamps@egroups.com
> Subject: Re: [noparse][[/noparse]basicstamps] Winscope
> Guys
> I have just built a osscilisope for my PC
> It uses a sound card pre amp which I plug cro leads into BNC plugs (left
> and
> Right channel on sound card)
> This then uses winscope to display two waveforms
> Works great and at a fraction of the cost of a "real" scope
> Check out :-
> www.dse.com.au for Soundcard pre amp Kit - K7347
> or
> www.jaycar.com.au for Kit KA1811 (same as above)
> Does any body know of a PC controlled (windows) adjustable wave form
> generator?
> Hope this helps
> Wayne
> sound
> From: Philippe Derenne <derennep@s...>
> To: <basicstamps@egroups.com>
> Sent: Monday, August 21, 2000 1:54 AM
> > Hi Willem,
> > I've seen something about a scope program for a sound card, and I think
> you
> > must connect the signal to the line input of your soundcard. It's a
> stereo
> > input, so you should get 2 channels. Be sure not to overload your card's
> > input !
> > Where did you get Winscope ?
> > Best regards,
> > Philippe Derenne
> > From: Willem <willems@c...>
> > Sent: Sunday, August 20, 2000 5:49 PM
> > > ok i try i have downloaded winscope but i dont know how to wire him
> using
> > > the soundcard must i use a probe or can i try him using the wires from
> the
> > > speakers to test??
> > > Kind regards.
> > > Willem.
> > > From: will <kiddies@t...>
> > > Sent: Sunday, August 20, 2000 1:27 PM
> > > > dad:
> > > > can you translate please
> > > > willems@c... wrote:
> > > > > Hoi ik heb winscope gedownload maar ik krijg hem niet aan de praat
> > > > > moet je een probe gebruiken of kan je hem ook testen met de
> speaker
> > > > > draden??
> > > > > Met vriendelijke groet .
> > > > > Willem.
