solar stamp — Parallax Forums
solar stamp
edited 2000-08-13 01:35 in General Discussion
hi all
I am trying to do the solar stamp project but i seem to have a hit a snag. I
have the super cap attached to VDD and it charges in about 30 secs. The
solar panel is attached to the 9 volt stubs on the carrier board. I get the
impression from the manual it should take longer. And when the stamp is
running off the cap it discharges to 4 v and the leds go out. This takes
about a minute. I read in the manual that at 4 volts the stamp resets but in
the application it says they were running at 3.65 volts. I dont have the
same solar panel used in the application as i couldnt find one. Also they
mention a solar battery but just show a solar panel. are these two the same?
my project is slightly different from the one in the book. I want a led to
be on
while the stamp sleeps for 6 hrs then light another led. Does having the led
on constantly really suck up that much power?
thanks for the help
jeff
    edited 2000-08-11 07:23
    Hi Jeff;
    I'm new to this Basic Stamp stuff myself. However I've been in
    electronices a while. Do you lnow how much the battery is drawing
    in charge mode ? Depending on the size of your solar cell, it could be
    only
    ma (milliamps), an LED draws a few ma itself, Not knowing all
    the figures I would guess that the LED might be taking the better part
    of the charge current leaving little or none for the charging of the
    battery.
    A good way to test this is turn the LED off for a charge cycle and see if
    things get better. Also using solar charging, it might be a good idea to
    charge the battery on a regular charger to start off with, if you were not
    getting a good charge by now the battery is most likly pretty weak.
    Of course these are all just ideas, but thats my 2 cents worth.
    Let us know how ya make out.
    kc7zmz
    Frank
    To: <basicstamps@egroups.com>
    Sent: Thursday, August 10, 2000 4:14 PM
    Subject: [noparse][[/noparse]basicstamps] solar stamp
    > hi all
    I
    the
    in
    they
    same?
    to
    > be on
    led
    > thanks for the help
    > jeff
    Hello,
    Solar projects usually require careful reduction of all power consumed.
    LED's often draw from 1 to 20 milliamps depending on the series resistor
    used, and are one area of large power usage as compared to the stamp. You
    might try using a very high brightness LED, and setting the current very low
    (0.1 to 0.2mA) with the proper series resistor to extend run-time. Another
    problem is using the onboard 5VDC voltage regulator. The onboard regulator
    is a linear regulator that is not very energy efficient. Use of a switching
    regulator to provide the 5 volts can reduce power consumption. Let me know
    if you need parts for an energy efficient 5VDC switching regulator circuit,
    etc.
    Sincerely,
    Charles Page, President, Technology Electronics, Ltd.
    www.technologykit.com
    To: basicstamps@egroups.com <basicstamps@egroups.com>
    Date: Thursday, August 10, 2000 7:15 PM
    > hi all
    I
    in
    they
    same?
    >be on
    led
    >thanks for the help
    >jeff
