Problem with pinX command w/ II & 2SX — Parallax Forums
edited 2000-07-21 18:08 in General Discussion
I am new to this list, so please excuse any redundancy in this question. I
tried emailing Parallax's STAMP support but the email will not go through... (?)
I am trying out a very simple program that will light a LED when a toggle
switch is in a given position. The program is as follows:
again:
if pin0=1 then beginning
if pin0=1 then ending
beginning:
high 7
pause 250
goto again
ending:
low 7
pause 1000
goto again
The problem is that whenever I try to download the program to the 2SX chip or II
chip (using the correct software) I get a "pin0 is undefined" error. I have
tried using caps, spaces, etc. to see whether it was a syntax problem and have
not gotten anywhere. This program is almost straight out of a learning book I
am working with and nowhere does it say whether I have to define "pin0" or why I
might be getting an error. The wiring is as follows:
p0 => Vdd -> 1k resistor -> toggle switch -> p0
p7 => Vdd -> 1k resistor -> LED -> p7
I can get the program to work without the if...then statement involving checking
the state of p0. Hmmm... What am I doing wrong??? Any help would be much
appreciated.
SNF
    edited 2000-07-21 18:01
    I'm sure you will get a few answers for this, but here's mine:
    pinX is for the Stamp I. For the II and IISX you need to use inX and outX.
    again:
    if in1=1 then beginning
    Or even:
    if in1 then beginning
    However, I'm not clear on your two if statements
    They test the same thing which means the second one will very likely never
    execute unless it sees an edge between the two statements.
    I'm thinking:
    top:
    if in0 then offled
    high 7
    goto top
    offled:
    low 7
    goto top
    or even:
    OUTPUT 7
    again:
    out7=in0
    goto again
    Something like that? Notice that HIGH and LOW implicitly call OUTPUT but if
    you are using outX, you have to use an OUTPUT statement.
    Good luck!
    Al Williams
    AWC
    *Basic Stamp FAQ: http://www.al-williams.com/wd5gnr/stampfaq.htm
    > From: SNFettig Listserv [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AkoMrE9eZfTLHxW-aMvNgp0cyc4GAWp6PYZsjFWybKTwbN3zv7GJY2oG1gjGM0hXpKuImM5rtgBDWiyReX4o]lists@s...[/url
    > Sent: Friday, July 21, 2000 11:25 AM
    > To: basicstamps@egroups.com
    > Subject: [noparse][[/noparse]basicstamps] Problem with pinX command w/ II & 2SX
    > this question. I tried emailing Parallax's STAMP support but the
    > when a toggle switch is in a given position. The program is as follows:
    > again:
    > beginning:
    > high 7
    > pause 250
    > goto again
    > ending:
    > low 7
    > pause 1000
    > goto again
    > 2SX chip or II chip (using the correct software) I get a "pin0 is
    > undefined" error. I have tried using caps, spaces, etc. to see
    > whether it was a syntax problem and have not gotten anywhere.
    > This program is almost straight out of a learning book I am
    > "pin0" or why I might be getting an error. The wiring is as follows:
    > involving checking the state of p0. Hmmm... What am I doing
    > wrong??? Any help would be much appreciated.
    > Regards,
    > SNF
    Change pin0 to IN0. This will take care of the undefined symbol for the BSII.
    Your first statement "if IN0=1 then beginning" will not let program execution
    fall-through to
    the second statement "if IN0=1 then ending", (unless IN0 = 0).
    Why..? If IN0 = 1 program execution is sent to beginning. If IN0=0 you will
    fall-through
    to beginning because you didn't test to see if IN0=0 and jump to ending.
    again:
    if IN0=1 then beginning <--- if IN0 = 1 you will never get to the second
    line.
    if IN0=1 then ending <--- if IN0 = 0 would take you to ending:
    beginning:
    high 7
    pause 250
    goto again
    ending:
    low 7
    pause 1000
    goto again
    The IF IN0 THEN is a logical operation that will test the logic state of the
    input
    pin. Test
    the input pin for each logic value ie,, 0 or 1 to make a decision based on the
    state
    of the
    input.
    Example:
    again:
    if IN0=0 then ending
    beginning:
    high 7
    pause 250
    goto again
    ending:
    low 7
    pause 1000
    goto again
    This should get you there......[noparse]:o[/noparse]]
    Bruce
    http://www.rentron.com
    To: <basicstamps@egroups.com>
    Sent: Friday, July 21, 2000 10:25 AM
    I
    | again:
    | beginning:
    | high 7
    | pause 250
    | goto again
    | ending:
    | low 7
    | pause 1000
    | goto again
    II
    tried
    using caps, spaces, etc. to see whether it was a syntax problem and have not
    gotten
    anywhere. This program is almost straight out of a learning book I am working
    with
    and nowhere does it say whether I have to define "pin0" or why I might be
    getting an
    checking
    appreciated.
    | Regards,
    | SNF
