sony ir and bs2 — Parallax Forums
sony ir and bs2
edited 2000-07-20 06:38 in General Discussion
Hello Pieter-Jan:
You might want to compare your approach with the Sony/BS2 code that is posted
in the Code Bank section at:
http://www.personalrobotics.net
There is no problem with slow response in this code -- in fact, there is a
PAUSE command at the end of the main loop to debounce incoming signals. Hope
this helps.
Regards...Don
Pieter-Jan van Diepen wrote:
> hello all,
> I've written some code to receive signals from a sony ir-remote. It works,
> but is very slow. The start bit of the sony protocol is very sometimes
> recognized, so i have to send my ir signal many times. Is there something
> wrong in the code, is it normal, or has anyone tips/trics?
[noparse][[/noparse]snip]
__________________________________________________________________________
FirstBOT(tm) Robot Kits & Components - http://www.FirstBotStore.com
Personal Robotics News - http://www.personalrobotics.net
    edited 2000-07-18 12:34
    hello all,
    here is my code
    irsense con 15
    irinput var in15
    irthreshold con 500
    irstartlow con 1100
    irstarthi con 1400
    value var byte
    raw var word(7)
    start var word
    dummy var word
    output 1
    out1 = 1
    output 5
    out5 = 1
    output 9
    out9 = 1
    top:
    debug "tp"
    gosub read_ir
    if value =1 then do_1
    if value =5 then do_5
    if value =9 then do_9
    goto top
    do_1:
    low 1
    pause 1000
    high 1
    pause 1000
    goto top
    do_5:
    low 5
    pause 1000
    high 5
    pause 1000
    goto top
    do_9:
    low 9
    pause 1000
    high 9
    pause 1000
    goto top
    read_ir:
    debug ? irinput
    if irinput = 0 then noir
    pulsin irsense,0,start
    pulsin irsense,0,raw(0)
    pulsin irsense,0,raw(1)
    pulsin irsense,0,raw(2)
    pulsin irsense,0,raw(3)
    pulsin irsense,0,raw(4)
    pulsin irsense,0,raw(5)
    pulsin irsense,0,raw(6)
    pulsin irsense,0,dummy
    if (start <irstartlow) or (start > irstarthi) then noir
    value = 0
    for dummy = 6 to 0
    value = value *2
    if raw(dummy) < irthreshold then ir0
    value = value +1
    debug ? value
    ir0:
    next
    return
    noir:
    debug "noir"
    value=-1
    return
    many thanks pieter-jan
    Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
    edited 2000-07-19 02:22
    I wrote some code for the BS@ to do this same thing. It never worked as
    well as I wanted though, just like yours i would have to press the button
    several times. Then I wrote some code in picbasic and have never had any
    trouble. The faster speed of the pics help A LOT. I could pass it on to
    you if you like, assuming you can program PICs.
    >From: "Pieter-Jan van Diepen" <diepenpj@h...>
    >Reply-To: basicstamps@egroups.com
    >Subject: [noparse][[/noparse]basicstamps] sony ir and bs2
    >Date: Tue, 18 Jul 2000 08:34:03 CEST
    >hello all,
    >here is my code
    >irsense con 15
    >irinput var in15
    >irthreshold con 500
    >irstartlow con 1100
    >irstarthi con 1400
    >value var byte
    >raw var word(7)
    >start var word
    >dummy var word
    >output 1
    >out1 = 1
    >output 5
    >out5 = 1
    >output 9
    >out9 = 1
    >top:
    >debug "tp"
    >gosub read_ir
    >goto top
    >do_1:
    >low 1
    >pause 1000
    >high 1
    >pause 1000
    >goto top
    >do_5:
    >low 5
    >pause 1000
    >high 5
    >pause 1000
    >goto top
    >do_9:
    >low 9
    >pause 1000
    >high 9
    >pause 1000
    >goto top
    >read_ir:
    >debug ? irinput
    >value = 0
    >for dummy = 6 to 0
    > value = value *2
    >value = value +1
    >debug ? value
    >ir0:
    >next
    >return
    >noir:
    >debug "noir"
    >value=-1
    >return
    edited 2000-07-19 17:19
    Ed,
    Do you mind if you email the Picbasic code to me at
    Gary.Chung@d... ??
    Gary
    To: <basicstamps@egroups.com>
    Sent: Wednesday, July 19, 2000 9:22 AM
    Subject: Re: [noparse][[/noparse]basicstamps] sony ir and bs2
    > >hello all,
    > >here is my code
    > >irsense con 15
    > >irinput var in15
    > >irthreshold con 500
    > >irstartlow con 1100
    > >irstarthi con 1400
    > >value var byte
    > >raw var word(7)
    > >start var word
    > >dummy var word
    > >output 1
    > >out1 = 1
    > >output 5
    > >out5 = 1
    > >output 9
    > >out9 = 1
    > >top:
    > >debug "tp"
    > >gosub read_ir
    > >goto top
    > >do_1:
    > >low 1
    > >pause 1000
    > >high 1
    > >pause 1000
    > >goto top
    > >do_5:
    > >low 5
    > >pause 1000
    > >high 5
    > >pause 1000
    > >goto top
    > >do_9:
    > >low 9
    > >pause 1000
    > >high 9
    > >pause 1000
    > >goto top
    > >read_ir:
    > >debug ? irinput
    > >value = 0
    > >for dummy = 6 to 0
    > > value = value *2
    > >value = value +1
    > >debug ? value
    > >ir0:
    > >next
    > >return
    > >noir:
    > >debug "noir"
    > >value=-1
    > >return
    Here is the code, I modified it for my particular app. I am too busy now
    to comment it much, but it should be easy to figure out.
    'decodes sony IR remote signals
    symbol loop = b16
    symbol start = W7
    top:
    b13=0
    b2=0
    b3=0
    b4=0
    b5=0
    b6=0
    b7=0
    b8=0
    b9=0
    b12=0
    pulsin 0, 0, start
    if start > 240 then get
    goto top
    get:
    if start < 1000 then getbits
    goto top
    getbits:
    pulsin 0, 0, B13
    pulsin 0, 0, B2
    pulsin 0, 0, B3
    pulsin 0, 0, B4
    pulsin 0, 0, B5
    pulsin 0, 0, B6
    pulsin 0, 0, B7
    pulsin 0, 0, B8
    pulsin 0, 0, B9
    pulsin 0, 0, B10
    pulsin 0, 0, B11
    pulsin 0, 0, B12
    if b13=0 or b2=0 or b3=0 or b4=0 or b5=0 or b6=0 or b7=0 or b8=0 or
    b9=0 or b10=0 or b11=0 or b12=0 then top
    gosub setvalue
    w8=b0+b1
    serout 2, n9600, ("total = ", #w8, $0A, $0D) 'send data to LCD
    low 1
    pause 10
    dir1=0
    serout 1, t9600, (w8) 'send data to basic stamp
    goto top:
    setvalue:
    bit0 = b13/96
    bit1 = b2/96
    bit2 = b3/96
    bit3 = b4/96
    bit4 = b5/96
    bit5 = b6/96
    bit6 = b7/96
    bit7 = b8/96
    bit8 = b9/96
    bit9 = b10/96
    bit10 = b11/96
    bit11 = b12/96
    return
    >From: "Gary Chung" <gary.chung@d...>
    >Date: Thu, 20 Jul 2000 00:19:17 +0800
    >Ed,
    >Gary.Chung@d... ??
    >Thanks
    >Gary
    >From: "ED Ward" <punk__rocker@h...>
    >button
    >to
    > > >hello all,
    >works,
    >something
    > > >here is my code
    > > >irsense con 15
    > > >irinput var in15
    > > >irthreshold con 500
    > > >irstartlow con 1100
    > > >irstarthi con 1400
    > > >value var byte
    > > >raw var word(7)
    > > >start var word
    > > >dummy var word
    > > >output 1
    > > >out1 = 1
    > > >output 5
    > > >out5 = 1
    > > >output 9
    > > >out9 = 1
    > > >top:
    > > >debug "tp"
    > > >gosub read_ir
    > > >goto top
    > > >do_1:
    > > >low 1
    > > >pause 1000
    > > >high 1
    > > >pause 1000
    > > >goto top
    > > >do_5:
    > > >low 5
    > > >pause 1000
    > > >high 5
    > > >pause 1000
    > > >goto top
    > > >do_9:
    > > >low 9
    > > >pause 1000
    > > >high 9
    > > >pause 1000
    > > >goto top
    > > >read_ir:
    > > >debug ? irinput
    > > >value = 0
    > > >for dummy = 6 to 0
    > > > value = value *2
    > > >value = value +1
    > > >debug ? value
    > > >ir0:
    > > >next
    > > >return
    > > >noir:
    > > >debug "noir"
    > > >value=-1
    > > >return
