Switch input — Parallax Forums
Switch input
edited 2000-07-16 01:17 in General Discussion
I am using a 9-position rotary switch as an input to a BS2.
The problem is that I don't have 9 unused I/O pins left.
The Ser-Key serial encoder from Reynolds Electronics looked
like a good solution. However, it needs a key press and
release sequence in order to transmit the key value.
With my rotary switch arrangement the key is always 'pressed'
until the switch position is changed.
Anyone have any ideas - serial conversion, encoder...?
On another subject, does the Parallax PBasic have a line
continuation character? My serout commands to the LCD
display tend to become rather lengthy.
Thanks for the help.
Adolph Stumpf
    edited 2000-07-15 02:18
    Adolph:
    Could you tie your rotary switch common to a single series pushbutton and
    push the button after setting the desired position? Then you could use
    Serkey.
    Ray McArthur
    > Adolph Stumpf
    i belive that its jameco that sells a pot with indents wich mens you can use
    the pot command.
    good luck
    To: <basicstamps@egroups.com>
    Sent: Friday, July 14, 2000 8:48 PM
    Subject: [noparse][[/noparse]basicstamps] Switch input
    > Adolph Stumpf
