Audio vs. linear taper Pots? — Parallax Forums
edited 2000-07-12 05:02 in General Discussion
Hello again everyone,
Vince's post about the A/B switch on the wheelchair was very helpful,
thanks everyone for your input. I have another dilemma. I'm using an LM386
as an audio amplifier with a pot for a volume control - works well but the
response of the pot I have is decidedly non-linear! This even though it's
supposed to be a linear taper pot...perhaps the response curve of the amp
isn't linear? I've heard of something called an audio taper which
presumably is not a regular log taper...which one do I need to get a linear
increase in volume from the 386?
Thanks, Duncan
    Duncan:
    Because of the ~logarithmic response of the human ear, audio taper pots are
    used for volume controls. These pots have a log taper, not linear. If you
    are using one of the standard circuits shown on the data sheet, a 10K audio
    pot should work.
    Ray McArthur
    I'm using an LM386
    linear
