Sub-mm position with Stamp2sx? — Parallax Forums
edited 2000-07-13 09:15 in General Discussion
Good afternoon,
I have a chamber, measuring 4m by 2m, and am contemplating whether
it's practical to build an x-y coordinate system to carry a very small
load. This would have to be accurate to sub-mm (0.4mm or so) throughout
the entire region.
The position of the load should be controlled by a stamp2sx, as:
1) It should not take 10min to move the load completely across
the chamber, so encoder data should be gathered pretty fast at this
resolution.
2) The encoder I'd use would probably be at least 1000cpr,
possibly geared down.
For this application, the resolution and absolute accuracy are most
important.
I don't know if a stamp is capable of this, but:
Has anyone built a setup similar to this, using a Stamp as the main
processor?
Thank you for your time, have a pleasant evening,
Paul
    edited 2000-07-11 08:00
    Several companies make submicron positioners that are driven by stepper
    motors. Start with edmund scientific and go from there. I don't have any
    URL's handy, but there are several other outfits that make them. Definitely
    something a stamp can drive, I would think.
    To: <basicstamps@egroups.com>
    Sent: Monday, July 10, 2000 3:08 PM
    Subject: [noparse][[/noparse]basicstamps] Sub-mm position with Stamp2sx?
    > Good afternoon,
    > the entire region.
    > resolution.
    > important.
    > processor?
    > Paul
    edited 2000-07-11 20:35
    Hi Carl,
    I haven't seen one yet that allows a 4m by 2m range of motion. If
    you've found one, could you please tell me where?
    If they are stepper driven that is a bonus; as you also mention,
    it would make driving the platform with a Stamp much simpler.
    Paul
    > From: Paul J. Csonka <csonka@e...>
    > > Good afternoon,
    > > the entire region.
    > > resolution.
    > > important.
    > > processor?
    > > Paul
    edited 2000-07-12 02:32
    Thomson has stepper driven positioners that have the range and
    accuracy you're looking for. The most accurate stages are ball lead screw
    driven, but you sacrifice range of motion and speed. The toothed (timing)
    belt driven models are larger and faster, but less accurate. They are all
    expensive. 8^0. Are you looking for sub mm positioning over a 2 meter x 4
    meter ROM? For that I think you'll need microstepping stepper drives and
    perhaps a higher frequency pulse source than the BS2X...depending on the
    speed you need.
    Cheers, Duncan
    edited 2000-07-12 08:42
    A boo-boo on my part. I was thinking millimeters instead of meters when
    I saw the 4m by 2m. I suspect that if you do a little research you will be
    able to find several outfits that sell leadscrews that you can use to
    fabricate one of your own; your application doesn't seem like something off
    the shelf. Another thought would be to use a submicrom positioner on top of
    the platform that would give you the resolution you desire, as well as the
    speed you want. A quick web search for precision lead screws gets me
    http://www.kerkmotion.com/ which have screws good to 0.0006", which is in
    the range you probably want for repeatability, then tack on a submicron on
    the platform for the really precision stuff. Encoders won't probably be
    needed for the little one, but you definitely would want one for the screws.
    I just noticed that the shaft runout for the aforementioned outfit was 2-3
    thou, but they say they can do better if you want it. I'm sure that there's
    lots of companies that can do the same.
    Sent: Tuesday, July 11, 2000 12:35 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Sub-mm position with Stamp2sx?
    > Hi Carl,
    > Paul
    stepper
    any
    Definitely
    > > > Good afternoon,
    throughout
    > > > the entire region.
    edited 2000-07-13 03:29
    Hello Carl,
    Thank you for your assistance.
    Kerkmotion has a nice website. I will contact them for further
    details.
    I'd also thought of course positioning, followed by the fine,
    but initially discarded it. Perhaps on your suggestion I will go with it
    after all, as it's definitely the least costly!
    Thanks for your time,
    Paul
    (This appears to be getting off-topic, so my apologies).
    > > Hi Carl,
    > > Paul
    > stepper
    > any
    > Definitely
    > > > > Good afternoon,
    > throughout
    > > > > the entire region.
    Sent: Wednesday, July 12, 2000 7:29 PM
    > Hello Carl,
    Nonsense. As long as the stamp is the common denominator, all topics
    are fair. Some time ago it got pretty wild discussing nuclear reaction
    control with a stamp, but it was nonetheless stamp-based!
