Windows NT problems with stampw — Parallax Forums
edited 2000-06-29 17:06 in General Discussion
I have been tinkering with setting up the stampw.exe compiler and
having it run under NT with service pack 5. There is a fair amount of
user security set up on our network, such that a student user can't
access the C: drive directly (ie through My Computer, etc). The error
messages that I get are "Failed to set data for BGcolor" when I
launch the editor, and then the same when I try to exit the editor.
Eventually I get a access violation error like "access violation at
address 0041F391 of module stampw.exe. Read of address 000000BC".
I have tried to ghange the graphics card settings to a lower
resolution, but that didn't help. Any ideas anyone??
    edited 2000-06-28 16:45
    Can you just install it to a different drive? At work they don't want us
    using the C drive either, they haven't went to the extreme a protecting it
    from us. But they have partitioned the drive into a C: and a D:. We are
    allowed to use the D: all we want, plus we have a personal drive on the
    network. I installed the stamp software here so I could work on stuff at
    lunch. I put it on the D: drive and didn't have any problems. We are also
    running NT 4.0 sp 5.
    Hope this helps!
    Shawn
    From: djtroyer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Eapx4NYqKBTBImkGZ31HDv63HPKvVxIxx9KhhclXGk51_njiT61n_SR8Ib6Ot3hDaBB9yRbJCf4-YXQG7xRiTgPQgw]derek.troyer@e...[/url
    Sent: Wednesday, June 28, 2000 8:31 AM
    To: basicstamps@egroups.com
    Subject: [noparse][[/noparse]basicstamps] Windows NT problems with stampw
    edited 2000-06-29 14:07
    > having it run under NT with service pack 5. There is a fair amount of user
    > security set up on our network, such that a student user can't access the C:
    > drive directly (ie through My Computer, etc). The error messages that I get
    are
    > "Failed to set data for BGcolor" when I launch the editor, and then the same
    > when I try to exit the editor. Eventually I get a access violation error like
    > "access violation at address 0041F391 of module stampw.exe. Read of address
    > 000000BC".
    There is info on this in a README or DOC. You have to run it the first time
    with Administrator privilges becaues it writes to the registry. Then you set
    the shortcut with a command line option with something like /noregistry to
    prevent further attempts to write. Non-admin users will have to select the
    COM port each time they run the program.
    The problem you are having is due to an error in the software. It is
    trying to create it's preference settings in an area of the Windows
    Registry that happens to be protected from users other than the
    administrator on Windows NT. This is something we didn't realize at the
    time. We are fixing this problem and the next version (to be released at
    the end of July) will include it. We have included a command-line switch
    in the current version that will allow you to get rid of the problem in the
    mean time.
    Simply enter /NOREGISTRY in the command-line of the properties of the
    icon you created on your desktop (or create one if you haven't already).
    There should have been a Windows Interface Readme.txt file that came with
    the software. It describes this command-line switch plus a few other
    useful items.
    > Date: Wed, 28 Jun 2000 15:30:43 -0000
    > From: "djtroyer " <derek.troyer@e...>
    > Subject: Windows NT problems with stampw
    --Jeff Martin
    Tech. Support
    All Products: http://www.parallaxinc.com
    Educational BASIC Stamp: http://www.stampsinclass.com
    Educational SX Tools: http://www.sxtech.com
