tiny pager motors — Parallax Forums
tiny pager motors
edited 2000-06-17 02:28 in General Discussion
anyone know the type of plug
used on the tiny pager vibrator
motors?? What is the name,
who makes it and where can I
get a female side ??
thanks
also, how did you remove the
vibrator weight? -[noparse];)[/noparse]
    edited 2000-06-16 05:37
    > thanks
    Grind it off carefully with a Dremel(-like) tool and a small grinding
    wheel, or carbide disk (which will slice it) parallel with the shaft.
    Bruce
    edited 2000-06-16 16:45
    Here's my favorite method.
    Materials needed.
    1 - Thin piece of hard steel.
    ahh.. metal putty knife?
    1 - Hacksaw (thin blade).
    Sorry no substitutes for this
    1 - Steel pipe.
    ID as needed so motor fits freely inside and twice
    as long as the motor. 1/2" 3/8" drive socket?
    1 - Drive Punch with VERY small diameter.
    Your not likely to find this item so a push pin, the
    type with the plastic head will do nicely.
    1 - Hammer. Mabey that 3/8" ratchet from the socket set above ;>
    A. Use the hacksaw to cut a narrow slot about 1/4" deep into
    the an edge of the thin steel plate.
    B. Slip the pager motor shaft into the slot in the
    steel. (motor on one side weight on the other)
    C. Place this assembly with the motor into the pipe.
    (You may want to tape the wires of the pager motor
    around the body to protect them from getting pinched.)
    D. Place pipe on hard surface.
    E. Insert sharp end of push pin into hole on end of weight
    so it is against the end of the motor shaft.
    F. Tap lightly with hammer until motor falls out.
    Best of luck..
    From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6qTEzgiusiuUiBEM18ietuLlN1a4Rf375zGbUe76CvF3yYV0VceX6ui6CV_tCFhyWugrYyfDN3ckO9Bmbck]bvbates@u...[/url
    Sent: Tuesday, June 15, 1999 8:53 PM
    To: basicstamps@egroups.com
    Subject: Re: [noparse][[/noparse]basicstamps] [noparse][[/noparse]ot] tiny pager motors
    > thanks
    Bruce
    edited 2000-06-16 17:30
    thanks,
    I think I'll tap it out, maybe a sacrificed-china drill bit #0 will do it as
    a punch.
    What about that dinky little plug, any leads...
    From: "Witherspoon, Michael J" <michael.j.witherspoon@i...>
    To: <basicstamps@egroups.com>
    Sent: Friday, June 16, 2000 10:45 AM
    Subject: RE: [noparse][[/noparse]basicstamps] [noparse][[/noparse]ot] tiny pager motors
    > Materials needed.
    > 1 - Steel pipe.
    > Best of luck..
    > Mike
    > From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9WFEMTZ-xtn8PTPmAem_ltCPF3SDX0WZMPm9O7oB9pXSa3DiKDcQTzd1gL8ULO5KxLAAL6Cf2fAEU-ZXpn35]bvbates@u...[/url
    > > thanks
    > Regards,
    > Bruce
    edited 2000-06-16 18:47
    Sorry mine didn't have plugs.
    I clipped two pins from a .1 header and soldered the leads to them.
    From: rad0 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iDfrmB9fVKjBppKrlgxEq0V25EChvbBoO7JlpU_I8kla0izP1pBqC4WkcbaKzFmLcTh_LQ]rden0@h...[/url
    Sent: Friday, June 16, 2000 9:31 AM
    thanks,
    a punch.
    > Materials needed.
    > 1 - Steel pipe.
    > Best of luck..
    > Mike
    > From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3Z0KOC6oxLm5qrKrAnMhPcd9UXfbY1meVghA0iCtcpKaGn0G9mweCiKI7wp6uOUlBXTji1O72hqarzzUSA]bvbates@u...[/url
    > > thanks
    > Regards,
    > Bruce
    edited 2000-06-17 02:25
    I use a file to grind down the smallest side of the weight. Other use stiff
    metal and a hammer to beat the shaft out. Good tutorial on
    www.beam-online.com
    -William
    Sent: Friday, June 16, 2000 12:36 AM
    Subject: [noparse][[/noparse]basicstamps] [noparse][[/noparse]ot] tiny pager motors
    > thanks
    Wow! That cool. That's the best sounding method yet. You have pictures? Want
    to write a short tutorial briefing?
    -William
    From: Witherspoon, Michael J <michael.j.witherspoon@i...>
    Sent: Friday, June 16, 2000 11:45 AM
    > Materials needed.
    > 1 - Steel pipe.
    > Best of luck..
    > Mike
    > From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yMbaBibya55iZ04btnNouSSbQu-zYI_Oxnfjc3MeiRoIt027Hlwsg8ZF5TDtbAlM9J80da9FYGFjnBCxOtw]bvbates@u...[/url
    > > thanks
    > Regards,
    > Bruce
