Basic Stamp Style PLC Module, Info and Prices — Parallax Forums
edited 2000-06-15 04:17 in General Discussion
Topic: PLC Style BSII Module
Thanks goes out to everyone for waitng patiently for this information.
The Attached photo of a·BSII module built ala PLC style for another customer customer is not available, as this batch or lot of building block modules was built for their exclusive use.
Do not fret though, a Revision B will be available in about 2-3 weeks. (LCD's not inclued.)
___________________________________________________________________
This·Revison has the following features and Changes from the one previously presented:
Revison A··········································· Revison B
8 Inputs··············································· 8 Inputs
No Input State Indicator·················· w/LED Input State Indicators
7 Outputs··········································· 8 Outputs
w/ LED State Indicators··················· w/LED State Indicators
LCD Output······································· LCD Output
Assigned to I/O Pin #8···················· Selectable via I/O Pin 15
·····························································User defines if they wish to use or not.
The following·is a list of Features are used·in both versions.
Revision B has over 150 Parts which make up this module.
5 volt Switching Regulator: This results in high efficiency and low heat when converting from 24 VDC to 5 volts.
1.5 Amp Capacity· @ 5 volts, is available should one wish to use a power hungry VFD Display with this module.
TO-92 Darlingtons are used·as open collector outputs with flyback diodes on the board for·protection against inductive spikes. 500 ma capacity nominal for outputs.
Inputs are easily configured to use with both flavors of industrial 24 volt sensors both PNP and NPN.· Sensors will derive their power from the sensor input connections. There is no need to assemble a large section of DIN Rail terminal blocks to distribute power to Sensors.· A DIN Rail fuse block is recommended to power up this module.
The Inputs will also accept 2 wire switches and various photo transistor or hall effect sensors with open collectors.
The LCD output connector is configured pin for pin to mate with a Scott Edwards Serial LCD Backpack Interface. Thus the connector has 5 pins set up as +5, Gnd, Serial Out, Gnd, +5 for pin order. Identical to the LCD Serial Backpack. Its hard to improve on such a good device interface.
Please fill out the following section, then cut and paste into a return e-mail ( ronaldsa@earthlink.net· ) to note your preference.
······························································· Customer Info
Business Name:
Contact Name:
Address:
City:
State:
Country:
Day or Night Phone Number:
··················································· _________________________________
BSIO 8x8 Module Pricing and Options
DIN Rail Mounting Kit (cut for this module only)·························· 18.36
U-Assemble Kit (without Basic Stamp II and DIN Rail Kit)·········160.00
Module Assembled (with DIN Rail Mounting, w/o BSII)············251.00
Module Assembled (with DIN Rail Mounting and BSII)············ 300.00
Options:
The 4 terminal input screw connections maybe substituted for a 4 Pin Molex Connector (0.100 spacing with friction lock and polarizing ribs).· Mating 4 Pin Plug and Terminals will also be included in this option.
Sorry at this time no VISA or Mastercard Orders can be accepted.
Please·note the desired quanity·and method of shipment. A reply e-mail will be sent with the total· Module Cost plus Shipping, as per your preference.
Send a Check or Money Order made out to: Digital Design Solutions, Inc.
Mail to this Address:
1937 Hyde Drive
Loveland, CO. 80538
Shipment·of this module will commence in 2-3 weeks. Those businesses who wish to purchase more modules in the future after evaluating this module may request additional purchases via a PO.
For those who's needs are not met with this 8x8 PLC Style Basic Stamp Interface, another version with incrementally addressable I/O in units of 8 Inputs or Outputs, up to 128 points will be available later on.
If anyone has a specific application question please feel free to e-mail· (· ronaldsa@earthlink.net· ) your inquiry. I will try to respond as soon as possible.
Thank's again for your interest.
Sincerely,
Ron Anderson
