Digest Number 98 — Parallax Forums
Digest Number 98
edited 2000-06-09 01:30 in General Discussion
> Hi all,
> I am building a autoleveler for a model aircraft and I want to try and
> interface this with a GPS or some sort of Dead Reckoning System. I
> want, that when the radio transmitter is turned off the model aircraft
> will fly back to a certain postion and circle until it run's out of
> fuel. At this stage in the project I have the autoleveling system
> ready. If anybody has good info on dead reckoning systems I would be
> greatfull Thanks Paul
With the 'scrambling' turned off GPSs are now accurate to 10s of
feet so it could work. You would probably want an OEM module
although they cost more that a commerical unit.
Here is one about the size of a quarter.
http://www.laipac.com/msg4.htm
You will have to do some math to figure how to get from where you
are to 'home' unless you have a unit with Waypoints.
Mike DeMetz sect. Michiana R/C Choppers
miked@t...
http://sites.netscape.net/mdemetz
