Op-amp recomendations — Parallax Forums
edited 2000-06-08 17:01 in General Discussion
I need to find a generic (preferably) single supply Rail-to-rail op-amp. I
would like rail to rail or close to it on both the input and output. An
op-amp with a high current output would also be prefered.
________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
    edited 2000-06-08 16:36
    Ed,
    AD8041 comes close, but input common mode doesn't reach + rail, and I doubt
    if it's generic...
    Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
    Manufacturer of the famous BOB-II Serial Video Text Display Module!
    I
    There are a lot of choices now, from National, TI, Maxim and Linear,
    Burr-Brown and Analog Devices. One good approach is to get on their web
    sites and use their parameter tables. Narrow it down with other specs:
    accuracy, CMRR, bandwidth, power supply current, minimum and maximum power
    supply voltage, packaging, etc etc.. You might take a look at the LMC6582
    from National. OR, the LT1490 from Linear Tech is very nice, and popular,
    but practically impossible to get ahold of in distribution. Or the
    MAX4292, which like most Maxim chips, is only available in surface mount.
    Or the TLV245x family. Most web sites will send you samples. If you need
    to adapt from a SOIC-8 package, remember that Steve Roberts is selling
    little adatper circuit boards.
    There is a large range of bandwidth versus power supply specs. The low
    power supply current (down to 1 microamp and 1.1 volt supply) is achieved
    by pushing the bandwidth down to kilohertz. R-R op amps running at higher
    voltages and currents are available with bandwidths up to around 20hz.
    regards,
    -- Tracy
