LCD1002 - 20x4 LCD Panel from B.G. Micro — Parallax Forums
edited 2000-06-07 22:09 in General Discussion
Chris-
See App Note 1: LCD User-Interface Terminal in the BASIC Stamp
I Application Notes. Has more than you need to address your
questions.
Steve
On 6 Jun 00 at 15:00, Chris V. wrote:
> I've recently purchased a LCD1002 - 20x4 LCD Panel from B.G.
> Micro, I am unable to determine how to hook it up in 4 bit mode, to
> my Basic Stamp Rev. D. I am also unable to figure out how to program
> the stamp so I can write Characters to the LCD directly from the
> stamp. If anyone has this LCD display, and knows how to run it, I
> would appriciate some help with it. The LCD is run by a HD44780
> controller by Hitachi.
    edited 2000-06-06 23:00
    Micro, I am unable to determine how to hook it up in 4 bit mode, to my Basic
    Stamp Rev. D. I am also unable to figure out how to program the stamp so I
    can write Characters to the LCD directly from the stamp. If anyone has this
    LCD display, and knows how to run it, I would appriciate some help with it.
    The LCD is run by a HD44780 controller by Hitachi.
    Chris V.
    A.K.A. [noparse][[/noparse]ToJ]Picard, [noparse][[/noparse]ToJ]Locutus
    "Is that a turtle on your head? or are you a Klingon?" - Unknown
    _______________________________________________________
    Get 100% FREE Internet Access powered by Excite
    Visit http://freelane.excite.com/freeisp
    edited 2000-06-07 03:00
    I did read that, it did not work anyway, I wired it up like stated, the only
    thing I can come up with is that because the display is a different size,
    the programming is different?
    On Tue, 6 Jun 2000 16:18:09 +0800, basicstamps@egroups.com wrote:
    > Chris-
    > questions.
    > Steve
    Chris V.
    edited 2000-06-07 12:44
    I assume you have the information for the pinouts and the
    information for how to reset the display using the reset
    by instruction method, which is basically sending the reset
    character to the LCD display 3 times with at least 10ms delay
    between. You will HAVE to use the 2-line mode in your function
    set command. The main problem I had was that I had to supply
    a negative voltage for contrast before I could see anything
    on the display. For a while I thought the display wasn't working.
    I am presently still working with some HD44780 based LCD modules
    being controlled from the stamp via a palm pilot.
    I have the complete spec sheet for the HD44780 in pdf format.
    If you like, I can e-mail it to you. Here are my connections:
    Stamp LCD
    Port0 Data Bit 4 Pin 11
    Port1 Data Bit 5 Pin 12
    Port2 Data Bit 6 Pin 13
    Port3 Data Bit 7 Pin 14
    Port4 Register select (RS) Pin 4
    Port5 Read/Write (RW) Pin 5
    Port6 Enable Pin 6
    +5vdc Pin 1
    GND Pin 2
    Contrast voltage Pin 3
    If you still have problems or questions, feel free to contact me.
    Bob
    tesla@i...
    >Chris V.
    edited 2000-06-07 20:14
    To: <basicstamps@egroups.com>
    Sent: Tuesday, June 06, 2000 3:00 PM
    Subject: [noparse][[/noparse]basicstamps] LCD1002 - 20x4 LCD Panel from B.G. Micro
    Basic
    this
    it.
    know what, save yourself a lot of trouble and convert that lcd to serial.
    got www.elabinc.com and get their ede 702
    its $9 us and get a 4 mhz resonator with internal capacitors $.25
    alls you have to do is make the circuit board, very easy, I have three of
    these ede702 and they are great, they work. I just put one on my 4X20 lcd.
    when you get it in the mail you will get a schematic for how its hooked up
    with the lcd and there is a bs1 example program but I have a bs2 sample
    program.... let me give it to you now.. its really really easy and only uses
    ***1*** IO.
    LCD CON 7 ' defining the io to use on the stamp to transfer data to the ede
    702
    N9600 CON 84 ' this number i derived from the stamp manual, just depends how
    you set pin 1-2 on the EDE702
    i have them both set high for standard and 9600 baud
    or you can set the low for inverted and 2400 baud
    PAUSE 500
    BEGIN:
    Serout lcd, n9600,[noparse][[/noparse]$FE] '(direct lcd control through ede702)
    'serout 7, n9600,[noparse][[/noparse]%11111101] (this sets the 1 digital pin on the mc to high
    which you can use to turn on your lcd backlight)
    serout lcd, n9600,[noparse][[/noparse]$01] ('Clears page and cursor goes to line 1 (home)
    pause 50
    serout lcd, n9600,[noparse][[/noparse]"TEST LINE 1"]
    pause 50
    serout lcd,n9600,[noparse][[/noparse]$FE]
    serout lcd,n9600,[noparse][[/noparse]$C0] 'Takes cursor to beginning of line 2
    pause 50
    serout lcd, n9600,[noparse][[/noparse]"TEST LINE 2"]
    pause 50
    serout lcd,n9600,[noparse][[/noparse]$94] 'Takes cursor to beginning of line 3 *** Not listed
    in documentation with ede 702, I just tinkered
    'for a bit and came up with it
    pause 50
    serout lcd, n9600,[noparse][[/noparse]"TEST LINE 3"]
    pause 50
    serout lcd,n9600,[noparse][[/noparse]$D4] 'Takes cursor to beginning of line 4 *** not listed
    in ede 702 documentation.
    PAUSE 50
    serout lcd, n9600,[noparse][[/noparse]"TEST LINE 4"]
    PAUSE 50
    Experiment with the delays, you could probably make em 10ms, this code works
    I just did it now.... the ede702 is the way to go.... if you have any
    questions at all just ask. I had problems when I first tried hooking it up,
    but now I know this product very well.
    -Tyson Stephen
    tysonstephen@h...
    Thankyou for your help! I'll let you know if this works.
    On Wed, 7 Jun 2000 12:14:02 -0700, basicstamps@egroups.com wrote:
    > From: Chris V. <cvenem01@e...>
    > Basic
    so I
    > this
    > it.
    lcd.
    up
    uses
    > ***1*** IO.
    ede
    > 702
    how
    > PAUSE 500
    > BEGIN:
    high
    > pause 50
    > pause 50
    > pause 50
    > pause 50
    listed
    > pause 50
    > pause 50
    listed
    > PAUSE 50
    > PAUSE 50
    works
    up,
    > -Tyson Stephen
    > tysonstephen@h...
    Chris V.
