OT - Regulator recommendations (5V & 12V) and how do I create neg ative voltage — Parallax Forums
edited 2000-05-31 21:14 in General Discussion
What is a good 5V and 12V regulator? I know they are not terribly expensive
so I guess anything under $10-15 or so would be fine.
Also, I know this is probably a very simple question, but how do I create
negative voltage?
-If everyone throws in their two cents worth, -
-but its a penny for your thoughts...who keeps the profit?-
    edited 2000-05-30 17:20
    I am not sure what your initial voltage source will be rather
    it be a wall transformer or you are building youe own power
    supply or what but these are numbers for voltage regulators:
    Positive voltage regulators:
    78XX
    Where XX = voltage regulated
    So a 7805 would be a +5vdc regulator,
    7812 = +12vdc regulator...etc
    (BTW negative voltage regulators are nomenclatured the same way
    but start with 79 instead of 78)
    (But you need a negative voltage to begin with before regulating it)
    Radio shaft carries the 7805 as part# 276-1770 (Rated 1 amp)
    In a TO-220 case (The square 3 pin case)
    and they have 2 heat sinks part# 276-1363, 276-1368
    Jameco and other electronic mags sell the other voltage types
    and packages like the TO-3 metal can type.
    Jameco charges .29 each while Radio shaft charges $1.49
    These components will regulate the voltage but will not filter
    the voltage. Again I am not sure of your application.
    As for the negative voltage, I ran into a need for this just last
    week. I bought come 16x4 LCD's off eBay and after might near pulling
    my hair out discovered that the reason I couldn't see anything on the
    display was that I needed a negative voltage for the LCD contrast.
    I bastardized a MAX232. A 16-pin chip whose purpose is to bring TTL
    voltages to RS232 voltage levels. The MAX232 is powered by +5vdc and
    along with 4 10uf capacitors, yields a negative voltage on one of the
    pins. Its not a lot current, but it worked for me.
    There is a chip, part# 7660CPA (Jameco part# 51174) which is easily
    available. It is an 8-pin dip IC that is a CMOS +5vdc to -5vdc converter.
    Costs $1.09. I need some of these.
    Hope this helps,
    Bob
    >negative voltage?
    edited 2000-05-31 00:40
    LM 317 good adjustable 1.2 to 32V regulator gen.purpose, up to 1.5 A. LM338
    good up to 5A .Negative voltages could be easyily created with ICL(or MAX)
    7660 or 7662(more current) ICs manufactured by several companies. Good up to
    100mA. Need only two external capacitors. Search at findchips.com. Look at
    Maxim-ic for regulated outputs and more current and LOW DROPOUT regulators.
    (low dropout = more efficiency but more expensive).
    ACJacques
    > negative voltage?
    edited 2000-05-31 01:48
    you can use 7805&7812 for +ve voltage and 7905&7912 for -ve voltage.
    >From: Levi Ruiz <Levi@P...>
    >Reply-To: basicstamps@egroups.com
    >To: "'basicstamps@egroups.com'" <basicstamps@egroups.com>
    >Subject: [noparse][[/noparse]basicstamps] OT - Regulator recommendations (5V & 12V) and how do
    >Date: Tue, 30 May 2000 07:51:09 -0700
    >negative voltage?
    ________________________________________________________________________
    Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
    edited 2000-05-31 18:23
    up to
    On a similar note, since this fellow will be powering from an automobile
    12V system, and someone has pointed out the surge danger, how best to
    protect from these high voltages? I'm building an APRS tracker that will be
    powered from 12V and I'd like to protect it from these (potentially 100V+?)...
    Best, Duncan
    edited 2000-05-31 19:30
    Hi Duncan.
    I would use a big zener, like 1 watt, ~20V. They sell transorbs for this
    job, but they are simply series back-to-back zeners with an energy (joule)
    spec. MOVs are so "soft" that I wouldn't trust them.
    Ray McArthur
    be
    100V+?)...
    edited 2000-05-31 19:40
    National Semiconductors LM2940 line made specifically for this app.
    regards, Jack
    > up to
    > Best, Duncan
    MOVs will also fail over time with repetitive hits. When they fail they
    tend to fail shorted.
    Larry
    At 02:30 PM 5/31/00 -0400, you wrote:
    >Hi Duncan.
    >Ray McArthur
    >be
    >100V+?)...
    Larry G. Nelson Sr.
    mailto:L.Nelson@i...
    http://www.ultranet.com/~nr
