Stepper motors - How do they work — Parallax Forums
edited 2000-06-06 02:24 in General Discussion
Hey All,
I was recently approached by an EE who wanted to know if I know how
steppers worked. I really didn't know much more then him. How exactly do
they work? How would I control one from my stamp? I have five small ones
that I bought thinking they were DC. I'd really like to use them.
-William
To: <basicstamps@egroups.com>
Sent: Wednesday, May 24, 2000 12:58 AM
Subject: [noparse][[/noparse]basicstamps] Stepper motors
> Hello,
> Many of my science and mathematics customers want more precision on our
> mobile platforms than we get from servos. So, the answer is stepper
> motors? Anyone willing to share sources, ideas, stamp software, etc to
> run steppers. What I need are motor/gears to run a 3 inch wheel and push
> around 2-3 pounds. Most of the subject matter of past e-mail covered
> hacked parts or surplus. So, I would like to also find a "dependable"
> source to send our customers to.
> TIA
> Rick Rowland
> http://www.smallrobot.com
    edited 2000-05-30 01:04
    One of the easiest hook-ups I have seen is at
    http://www.seattlerobotics.org/encoder/may98/steppers.html It will give you
    a hookup diagram and there is even a link for the code to drive it. It is
    not the way I would write the code, but it looks like it would work. I have
    some more compact code at home that I can post if needed.
    Here is a site that gives a great explanation of how steppers work:
    http://www.cs.uiowa.edu/~jones/step/
    Tim
    [noparse][[/noparse]Denver, CO]
    > From: William Cox [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dW6uP43Ddi_JLp3e2jrXzuhIv4odfLt4E0QShrcUNFEChUZjb8WrLfPRImcv6L3gCiLcD5NWgKGSCPl4tfwxWaEduQ]william@c...[/url
    > Sent: Monday, May 29, 2000 5:49 PM
    > To: basicstamps@egroups.com
    > Subject: Re: [noparse][[/noparse]basicstamps] Stepper motors - How do they work
    > Hey All,
    > -William
    edited 2000-06-02 23:01
    I saw a reference to a
    stepper motor with
    a "standard 23 frame size"
    what does this mean??
    Sent: Monday, May 29, 2000 7:04 PM
    Subject: RE: [noparse][[/noparse]basicstamps] Stepper motors - How do they work
    you
    have
    > Tim
    > > From: William Cox [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4jCL2YMl__uTLSbQG3f8KLoRUMxOQkJ02m5SukXtL7oqzsp7QGMIQuo4ejYfs6OcKl8R8ug9QXfCGet_ayPw0Hwu]william@c...[/url
    > > Hey All,
    > > -William
    edited 2000-06-03 01:11
    Most of the larger size steppers (the type that have a square mounting
    flange, not the type that mount on 2 ears) are built to standard frame sizes
    so they can be interchangeable. The dimensions describe the diameter of the
    shaft, the bolt circle of the mount, the diameter of the mounting shoulder,
    the diameter of the motor body, etc. They do not define the length of the
    motor, the electrical characteristics, steps per revolution, or the output
    torque. The standards are issued by an organization called to as NEMA (I
    think this stands for National Electrical Manufacturers Association) and are
    usually described as NEMA 23, NEMA 34 etc.
    So, a NEMA 23 (standard 23 frame size) means that the motor has a 1/4"
    output shaft and the mounting hole bolt circle is about 1.75" in diameter
    (this dimension id from memory, so don't do making a design based on it.).
    Normally NEMA 23 motors will have an output torque between 40 - 150 in/oz. I
    have seen smaller and larger output values, but they are pretty rare.
    Tim
    Sent: Friday, June 02, 2000 4:01 PM
    > stepper motor with
    > From: "Tim Goldstein" <timg@k...>
    > you
    is
    > have
    > > Tim
    > > > From: William Cox [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OnNsnhhUTj6qVbEL5GtdoupUqxwsZMwhgIFhY0OuvB-xpJwCAl7mXoBZgSA8fi2Y4Bt_FwNSSbr3rDtbAhPO4Bsp_Q]william@c...[/url
    > > > Hey All,
    do
    ones
    > > > -William
    edited 2000-06-03 01:31
    ok, thanks.
    one more I'll just ask before I get started,
    a servo motor differs from just a stepper motor
    because of the position feedback, right?
    So, for a servo,
    Where is this feedback sensor, or potentiometer, is built-in
    the motor or do you have to put this outside on you own??
    Sent: Friday, June 02, 2000 7:11 PM
    sizes
    the
    shoulder,
    are
    I
    > Tim
    > From: rad0 <rden0@h...>
    > > stepper motor with
    give
    > > you
    > is
    > > have
    > > > Tim
    > > > > From: William Cox [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=355ZOof_6UhKyrw-I3eiEUxipj90yd0c1hx21Y01qOhLMdPGUElzCnljQ-OZ6YPr9VpNUKzm7HqFV93kFUvoggWXYUQ]william@c...[/url
    > > > > Hey All,
    how
    exactly
    > do
    > ones
    > > > > -William
    edited 2000-06-03 03:22
    Servo control implies position feedback, however
    steppers with position encoders are common too.
    Steppers offer incremental, predictable movement,
    within limits - It is often desirable to run the
    stepper outside these limits (Speed, for instance),
    so additional means of keeping track of position
    are necessary.
    > So, for a servo,
    The sensor is not necessarily on the motor - It's
    purpose is to keep track of whatever the motor is
    moving. This determines where it goes.
    regards, Jack
    edited 2000-06-03 21:21
    So, if I buy a futaba servo motor, will it have a
    position sensor built in, or not ??
    Sent: Friday, June 02, 2000 9:22 PM
    > are necessary.
    > > So, for a servo,
    > regards, Jack
    edited 2000-06-03 21:54
    If you mean a Futaba radio control hobby type servo the answer is yes. It
    uses a pot as the feedback mechanism. When you say servo motor I generally
    think of a heavier duty type motor like would be used in an industrial robot
    or a CNC machine. In that case they most commonly use an incremental encoder
    that may be attached to the motor or is commonly attached to the actual part
    that is moved so the backlash is accounted for.
    Tim
    > From: rad0 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mBYGv7Q_sBbaZpbxN94SBATZZzafkoPD0ZglUFPA5QG528Q0GHcGhkJ-Rhn_euMs3jr2XA]rden0@h...[/url
    > Sent: Saturday, June 03, 2000 2:22 PM
    > From: <goflo@p...>
    > > are necessary.
    > > > So, for a servo,
    > > regards, Jack
    edited 2000-06-03 22:13
    Yes. There is a very clear example of interfacing
    "R/C" servos to Stamps in the BS1 documentation on
    Parallax's site.
    regards, Jack
    edited 2000-06-05 21:48
    robot
    encoder
    part
    To avoid confusion, when referring to a hobby servo motor these are called
    PWP(Pulse Width Position)servos.
    Bean, thitt@i...
    edited 2000-06-06 01:35
    yes, this is what I'm getting at, I don't want to buy the wrong part.
    -- done that too many times...
    I want to 'set up' a 200 oz-in "servo" motor
    to a machine.
    By the way, are 'servo' motors operated/behave
    just like a stepper motor, except for the feed-back??
    For example, are they uni-polar and bi-polar, constructed
    just like a stepper? Are there any major differences in control
    from a stepper??
    Thanks, I'm just getting a (my) grip on this.
    Sent: Saturday, June 03, 2000 3:54 PM
    robot
    encoder
    part
    > Tim
    > > From: rad0 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ceMRny_BB50sX7HUbFaBwtrheqO-jjYkm5vukgLoo-5vX6SDGkzJywYHgbSgK2GDRUmiETQg]rden0@h...[/url
    > > From: <goflo@p...>
    > > > are necessary.
    > > > > So, for a servo,
    > > > regards, Jack
    Steppers and servos are not constructed in the same way, a servo is
    just a plain old ordinary DC motor with positioning electronics
    attached to it. Steppers on the other hand are constructed
    completely different.
    To control a servo you need to use PWM, and by sending different
    pulses to the motor you can get it to move to different positions.
    You should be able to connect them directly to the STAMP with no
    extra circuitry needed besides what is already a part of the motor
    Steppers generally have no electronics and either need an H-Bridge
    for bipolar steppers, such as an L293D or L298 or a transistor array
    like the ULN2003A for unipolar motors, though you can also force a
    unipolar stepper to act as a bipolar one by using an H-Bridge.
    -Chris
    part.
    > to a machine.
    > from a stepper??
