Sharp GP2D12 — Parallax Forums
Sharp GP2D12
edited 2000-05-31 12:30 in General Discussion
I'm interested in using the Sharp GP2D12 analog distance measuring sensor.
Since it is making a continuous measurement, would it possibly measure
something rotating?
In my case I want a rough measurement of a set of rotor blades.
I would be about 2 ft from the center of rotation. Each blade is about 8"
in width, and turn from 100 to 500 RPM.
Would I see a pulse train with the two voltage levels. One corresponding to
the distance of the a rotor blade, and the other being 0.6V (>80cm) as the
sensor is pointing up...
Any help appreciated.
Bill Heacock
    edited 2000-05-30 02:09
    Yes but need some considerations. The GP2D12 does not takes mesurements
    contimuously but at several times each second . 38ms per reading that
    means a 26.31 Hz. To have reliable sample readings your system should
    work at maximum of 13 Hz (Nyquist). This will depend of how many blades
    you have rotating.If you have one blade rotating a 500 RPM this means
    500/60 = 8.3 Hz. But if you have 2 blades will be 16.6 Hz. 3 blades
    will be 25 Hz.
    ACJacques
    > something rotating?
    > Bill Heacock
    edited 2000-05-30 19:37
    Where did you find the 38ms per reading?
    I did find a 2 page data sheet on it, but it did not mention this. My
    project will be two blade design so it would become marginal above 390 RPM.
    Bill Heacock
    >will be 25 Hz.
    >ACJacques
    >> something rotating?
    >> Bill Heacock
    edited 2000-05-30 20:34
    Look:
    http://www.acroname.com/robotics/info/articles/sharp/sharp.html
    In the booklet supplied by Acroname for GP2D12 buyers they said
    that measurements are updated about about 32ms.I dont now who is
    correct, but this figure is a litle better in your case. With readings
    at 31.2 Hz you become marginal at around 450 rpm.
    ACJacques
    > Thanks,
    > Bill Heacock
    > >will be 25 Hz.
    > >ACJacques
    > >> something rotating?
    > >> Bill Heacock
    edited 2000-05-31 03:34
    for your rotor blade measurment can you use the hand held digital rpm
    indicators made for model airplanes and helicopters? they can measure 2,3 or
    4 blades. An 8" blade sounds like a full size helicopter to me <S>
    Sincerely
    Kerry
    http://Mntnweb.Com
    WWW hosting and Authoring
    Admin@M...
    It's actually a full size Gyrocopter. My challenge is measuring the angle
    of the rotor while in flight. On a gyro, the two-bladed rotor is mounted on
    a teetering hinge that allows the rotor disc to seek its own angle of
    attack (AOA) relative to the airframe and oncoming wind.
    My intention is to measure the distance at 18" from the center hub and
    calculate the angle. I'm using another IR sensor and the Stamp's pulsin
    command to make the RPM measurement.
    I think my answer may be to use the RPM pulse to sync the measurement for
    the most reliable measurement.
    Bill Heacock
    >Sincerely
    >Kerry
    >http://Mntnweb.Com
    >Admin@M...
