CMOS and TTL signal voltage levels? — Parallax Forums
edited 2000-05-28 17:33 in General Discussion
Can anyone tell me what the actual specs are for a 'high' CMOS/TTL signal?
What is the minimum voltage for each? A customer is trying to interface to
our equipment with what I feel is a flaky signal...
Duncan
    edited 2000-05-27 00:49
    > signal?
    > to our equipment with what I feel is a flaky signal...
    > > > Duncan
    With TTL: A logic-high output should be at least 2.4V. A logic-high input
    at least 2V.
    CMOS is quite a bit different. Working with a 5V supply, a CMOS logic-high
    output is at least 4.9V, and a logic-high input must be at least 70% of the
    power supply, or 3.5V with a 5V supply.
    Thanks to Jan Axelson for this data. It came directly from her book
    'Serial Port Complete". Lots more than just serial information in
    this book..;o]
    Bruce Reynolds
    Reynolds Electronics
    633 N. 8th St.
    Canon City, Co. 81212
    Voice: 719-269-3469
    Fax: 719-276-2853
    http://www.rentron.com
    signal?
    to
    Are you asking about BASIC Stamp inputs? The input thresholds I have seen
    (albeit in a relatively small sample) have been very close to 1.3 volts.
    The PIC16C57 data sheet states that the threshold shall in any production
    run be within the range from 1 to 2 volts on a 5 volt power supply over the
    speced commercial or industrial temperature range. The noise margin is of
    course best if the input signal comes from a low impedance source and
    swings clean and fast between 0 and 5 volts.
