Problem with Stamp v1.091.exe — Parallax Forums
edited 2000-05-24 03:14 in General Discussion
I am new to the Basic Stamp (I have the BS2 BOE), and I am
experiencing problems with the windows version of the programming
software. I have gotten programs to run fine with the DOS version,
but when I try to run a program from windows, I get the following
error: "Could not open port: Reason is unknown." Has anyone gotten
this error? If I try changing the default COM port preferences to
AUTO, I get a different error: "BASIC Stamp II not found on any COM
port. 1) Check serial connection. 2) Verify loopback connection
between RTS and DSR."
Again, it works in DOS, so I am a bit confused. Any suggestions?
-Jamie Forrest
    edited 2000-05-22 15:09
    My guess is that you have a mouse or other serial device connected to the
    port in question and a Windows driver is holding it open. Also, keep in mind
    that usually you can't use COM1 and COM3 at the same time, nor COM2 and
    COM4. So if you have a mouse on COM1, COM3 is effectively useless.
    Al Williams
    AWC
    *8 channels of PWM: http://www.al-williams.com/awce/pak5.htm
    > From: James Forrest [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=T9OQl0_SqzVV4YWmRGfjjfNd-gpQPiM2wGSns-CQSSX7e4wUvSGY1dMcbmtCHdwY4Sx_CUQVRzeDR5yPR5xhKg]honksandsirens@y...[/url
    > Sent: Monday, May 22, 2000 9:06 AM
    > To: basicstamps@egroups.com
    > Subject: [noparse][[/noparse]basicstamps] Problem with Stamp v1.091.exe
    > -Jamie Forrest
    edited 2000-05-22 21:23
    Hi, you might want to re-boot your computer and go into the bios (press del
    key or f1 at very beginning when told) and just make sure com 1 is set to
    3f8 and com 2 is set to 2f8. Then if thats all set. when you go back into
    windows go into the control panel and click on system icon, click the device
    manager tab key and then scroll down to "PORTS (COM AND LPT)" and clcik on
    the + to expand that. if there is no com2 then you need to go back to the
    control panel and add hardware. and when it asks if you want windows to
    search for hardware, say no and just select com port from the list of
    devices. just go through that and it should work ok. make sure you do not
    have a modem on com 2. you can check this by going back to the system icon
    under device manager and checking out modem section. if you have a modem on
    com2 you may want to use com 1 for your bs2 but if you have a mouse on com 1
    then you might want to connsider getting a ps2 mouse or getting an db9 to
    ps2 adapter.
    thats all i can think of..
    -Tyson Stephen
    tysonstephen@h...
    edited 2000-05-22 21:45
    Note: I have had problems with the windows version on my PII-400MHz DELL
    machine.
    Is yours a DELL ?
    I never did resolve the problem and parallax could not help.
    I had to revert back to an older, slower generic machine using the DOS
    version.
    Let me know if you find anything.
    Darren
    I get this problem alot, actually. The problem is almost always one thing: A
    conflict. I regularly forget to disable my Palm III's hotsync manager, which
    is also on COM2. So they conflict and it doesn't work. If you are sharing
    the com port with something else or there might be something else using that
    port, try shutting it down. I did have a problem once where it was a
    different problem, and I'm still not sure what the problem was. After a lot
    of fiddling it eventually went away. I would say it is probrably a conflict
    with another piece of software though. That would also explain why it worked
    in DOS. (There wouldn't be anything else running.)
