Transistors — Parallax Forums
Transistors
edited 2000-05-21 01:46 in General Discussion
Hi, just wondering if anyone can give me the easiest solution for reading a
schematic for a transistor.
you have the Collector,base and emitter.
i am only really looking for the emitter, or collector... the schematic has
three lines. and one has an arrow on it, does that represent the collector
or the emitter.
thanks in advance.
Tyson
    edited 2000-05-19 20:24
    The arrow is the emitter. If it points out, you have an NPN transistor.
    If it points in, PNP.
    The base is the one that makes a T instead of a V with the inside line.
    Al Williams
    AWC
    This week only: save up to 70% on PAKs -- details at
    http://www.al-williams.com/awce
    > From: Tyson Stephen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VWfpoBkD7KIar19XXvpw-a2L145wAHHx8KRsQb3DCs7bmatqaHjRJHVzIL2DsMyALcaq5KxiJbipDs0]tysonstephen@h...[/url
    > Sent: Friday, May 19, 2000 1:56 PM
    > To: basicstamps@egroups.com
    > Subject: [noparse][[/noparse]basicstamps] Transistors
    > reading a
    > schematic has
    > or the emitter.
    > thanks in advance.
    > Tyson
    edited 2000-05-19 20:50
    The pin with arrow is always the collector. On a NPN (Not Pointing iN) the
    arrow points out, on a PNP (Pointing iN Proudly) the arrow points in.
    -William
    To: <basicstamps@egroups.com>
    Sent: Friday, May 19, 2000 2:56 PM
    a
    has
    > or the emitter.
    > thanks in advance.
    > Tyson
    edited 2000-05-19 21:59
    I remember it this way:
    Pointing iN Pointer for PNP and Not Pointing iN pointer for NPN...
    Silly, but works for me!
    .mark
    >From: Joost Luyten[noparse]/noparse]SMTP:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1aFBeDUN8-e1qkYo52prMgEtylZZk5S6XMpA6HQ0Exc8DQjUvEk7XiwGHfY28_xIiW8U4Hm7lw]on2bbp@p...[/url
    >Sent: Friday, May 19, 2000 2:04 PM
    >Subject: Re: [noparse][[/noparse]basicstamps] Transistors
    ><<File: ATT01656.html>>
    >Hi all,
    >A rule that I once have learned in school is that you could find the emitter
    >by using three letters from the word emitter, namely eMITter.
    >MIT is the German word for 'with'.
    >MIT an arrow ==> with an arrow ==> emitter
    >I think not very often used in the USA, but works fine for me [noparse]:)[/noparse]
    >--- Greetings from Joost Luyten, ON2BBP
    >email :
    >- on2bbp@p...
    >- on2bbp@a... (this sends an SMS notification to my mobile phone)
    >ICQ : 45143957
    >Home :
    >Joost Luyten
    >Werftsesteenweg 44
    >2220 Heist op den Berg
    >Belgium
    Oorspronkelijk bericht
    > Van: Al Williams <alw@a...>
    > Aan: basicstamps@egroups.com <basicstamps@egroups.com>
    > Datum: vrijdag 19 mei 2000 21:24
    > Onderwerp: RE: [noparse][[/noparse]basicstamps] Transistors
    > Al Williams
    > AWC
    edited 2000-05-19 22:04
    Hi all,
    A rule that I once have learned in school is that you could find the emitter by using three letters from the word emitter, namely eMITter.
    email :
    - on2bbp@pi.be
    - on2bbp@advalvas.be (this sends an SMS notification to my mobile phone)
    ICQ· : 45143957
    Home :
    Joost Luyten
    Werftsesteenweg 44
    Belgium
    Van: Al Williams <alw@al-williams.com>
    Al Williams
    AWC
    edited 2000-05-19 22:08
    > eMITter.MIT is the German word for 'with'.MIT an arrow ==> with an
    > arrow ==> emitterI think not very often used in the USA, but works
    hey, that's great! you just made my day
    Jason
    edited 2000-05-20 00:10
    The EMITTER has the arrow.
    >-William
    >From: Tyson Stephen <tysonstephen@h...>
    >a
    >has
    >> or the emitter.
    >> thanks in advance.
    >> Tyson
    73 de KG4EXY
    edited 2000-05-20 02:42
    SAY WHAT William???? Do you have a lot of burnt up transistors laying on
    your bench? Just funning...... ==Mac==
    >-William
    edited 2000-05-20 07:23
    Sent: Friday, May 19, 2000 12:24 PM
    Subject: RE: [noparse][[/noparse]basicstamps] Transistors
    > Al Williams
    > AWC
    Thanks a lot for all of your guys help
    edited 2000-05-20 17:22
    The arrow points in the direction of conventional current flow and is found
    on the emitter. The collector is the other end of the 'V' shape, and the
    base is the flat piece. If current flows out of the emitter it is an NPN
    transistor.
    Oops [noparse]:)[/noparse] I meant the pin with the arrow is always the EMITTER! Sorry.
    -William
    Sent: Friday, May 19, 2000 9:42 PM
    the
    > >-William
