Program download problem — Parallax Forums
edited 2000-05-03 12:00 in General Discussion
On Wed, 3 May 2000, Hans Magnet wrote:
> Hi,
> I have had an intermittent problem with loading a program to my
> Stamp. The program load sometimes works and sometimes doesn't, and I
I have had some problems in the past where I had the stamp running in a
tight loop at startup. After loading the program and it starting its loop,
it was difficult to get it to program. Usually took ten or more trys to
regain control. I started putting a one second pause at the start of my
programs and the problem went away.
Just my .02,
Dale Harwood [noparse][[/noparse] N4VFF ]
internet> dale@h...
ax.25> n4vff@n4vff.#cha.tn.usa.noam
#include <std_disclaimer.h>
    edited 2000-05-03 09:42
    see no rational reason why it goes on strike, there appears to be no
    consistency. This intermittent problem lasts from a few attempts to a
    day. Quite frustrating when I am trying to write a program and need
    to run it after a change!
    I suspect the cause is something Windows 98 is doing with the Com1
    port.
    Does that seem likely?
    My OS is Windows 98.
    The Basic Stamp is BSIISX.
    The Basic Stamp Editor is version 1.091 beta.
    The settings are correct in the "Preferences" and "Editor Operations"
    (BS2SX, Com1, and All or Current).
    The cable connection is OK.
    Sometimes it is not possible to load the program to the BSIISX.
    When the problem occurs:
    1) The signal gets from laptop to the BSIISX Basic Stamp, as it is
    reset on giving the "run" command.
    2) The signal also gets from the Stamp to the laptop as I see the
    serout response in the debug window on the laptop screen at the same
    time as it is shown on the instruments LCD screen.
    3) The cable connecting Stamp and laptop is OK, as point 1), 2) and
    the program was downloaded before and downloads after this problem
    occurs.
    The message when the problem occurs says as follows:
    Basic Stamp IISX not responding on com 1
    1. Check serial cable connection.
    2. Check power supply.
    In these cases there is a serial connection, connected properly, and
    power is on (via a transformer).
    The last time this problem occurred it lasted about 2 hours, but when
    I returned from a coffee break it worked! Nothing had been changed
    since the previous attempt, when it didn't work.
    Thanx for your help,
    Hans Magn
    edited 2000-05-03 11:06
    At 08:42 AM 5/3/00 -0000, Hans Magnet promulgated:
    >Hi,
    >port.
    Hans -
    There have been various reported problems with laptops as well as
    laptops with Win 98, and even WIN 98 alone. Below are just some trouble
    shooting thoughts, since there will have to be a process of elimination
    before real debugging of the problem can occur.
    Reported Problems
    Some have to do with the power-save features
    ( [noparse][[/noparse]#1] comm port not being restored quickly enough,
    [noparse][[/noparse]#2] some other power-save feature impacting timing),
    and others seem to point to comm port voltages
    ( [noparse][[/noparse]#3] inherent lowered port voltages on some non-standard or older laptops
    [noparse][[/noparse]#4] lowered voltages do to depleted or low battery resources)
    Some have been said to reflect timing considerations of the port as controlled
    by the operating system
    ( [noparse][[/noparse]#5] comm port settings in "control panel" area
    [noparse][[/noparse]#6] comm board driver conflicts involving timing )
    >occurs.
    Guaranteeing that a programming cable is "known good" (INCLUSIVE of
    intermittant
    wires on a home made cable) is highly important. Many problems end up back
    here
    after a long, exhaustive and fruitless troubleshooting process.
    You might want to try com 2 (or some other port) if that is possible
    on your computer. Sometimes this can provide additional information.
    Sometimes this is just a matter of the battery peaking. Laptops (when online)
    often only trickle charge. Turning the system off brings about a higher
    charge
    rate. Check your manual for details.
    Additionally, there is the matter of power-save, in conjunction with
    battery voltage.
    In this case there may be a compound problem of delayed timing and battery
    voltage.
    I'm sure if you mention the name of your laptop, there may be others who have
    personal experience, and may be able to assist further. That found above is
    just
    a general outline (with problem reference numbers) for further discussion.
    Hope this helps
    > Hans Magn
    Thanks Bruce,
    The laptop is a Siemens Scenic Mobile 360.
    Hans
    > >Hi,
    I
    no
    to a
    need
    > >port.
    Operations"
    > Hans -
    trouble
    elimination
    > Reported Problems
    laptops
    controlled
    same
    and
    > >occurs.
    > intermittant
    up back
    > here
    and
    when
    (when online)
    higher
    > charge
    > battery voltage.
    battery
    > voltage.
    others who have
    above is
    > just
    discussion.
    > Hope this helps
    > > Hans Magn
