FIRST, controllong a Victor Spped Controller — Parallax Forums
edited 2000-05-02 13:19 in General Discussion
I'm the parent advisor to a rookie FIRST robotics team. This year we
defined a requirement in working with the Victor controller: we want to
interface w the controller in an unusual way. The controller has a jumper on
it. This is called the 'brake/coast' jumper and it determines how the
controller will behave when it gets no input. It can either act as a shunt
to the load or become an open circuit. The jumper goes on terminals A-B or
B-C. In our contest it is advantageous for the jumper to be on coast during
the 2 minute contest and for it to be on brake when the power is shut down by
the contest controlling computer. Thus we need a set of output pins from the
stamps computer which will act just like a single pole double throw relay.
Any suggestions?
Charlie Affel, caffel@a...
    Since the embedded STAMP is optically isolated, you can't use any of the
    pins w/o
    breaking a rule. You must use the I/O provided, and that's a bit
    frustrating.
    The Victor 883 speed controller defaults to BRAKE if no jumper is installed.
    You could use a reed switch and electromagment, or limit switch actuated by
    a servo to
    de-select BRAKE for the competition.
    When the radio communication is stopped at the end of a match, current stops
    flowing
    and the reed switch or limit switch opens, thereby selecting the brake mode
    by default.
    To: basicstamps@egroups.com <basicstamps@egroups.com>
    Date: Monday, May 01, 2000 4:06 PM
    Subject: [noparse][[/noparse]basicstamps] Re: FIRST, controllong a Victor Spped Controller
    on
    during
    by
    the
    >Any suggestions?
