Detected but not responding... — Parallax Forums
edited 2000-04-27 19:07 in General Discussion
When i try to download program i get Stamp detected but not
responding on COM1 Check power supply. I am using a straight
through cable and a ac adapter? I'm running on
WinNT 4.0 sp 5 and the Basic Stamp Editor 1.091 beta.
    edited 2000-04-23 08:20
    Have you tried just using a battery as a power supply. Some carrier boards
    allow a 9V battery to be plugged in and the voltage regulator on the chip
    drops it down to 5V. (at least thats how I understand it) Depending on
    which stamp you have, they require different amounts of current of which
    your ac adapter power supply may not be able to provide. I think the bs2sx
    needs at least 60 mA power supply but I may be wrong.
    Else, you might try setting the editor to transmit on com2 in case you have
    the cable attached to the wrong serial port. Obviously check the cable
    connections in case you haven't yet. I hope this helps.
    Jim Szymczak
    edited 2000-04-23 12:35
    Is this version supposed to run on NT? I know NT can tie up access to the
    serial port, check to be sure no other program is using the port (modem,
    mouse, palm software, etc.)
    Duncan
    edited 2000-04-23 16:49
    Thanks for your reply.
    Basic Stamp Editor 1.091 Beta is listed to support 95/98 and NT
    Murray
    To: <basicstamps@egroups.com>
    Sent: Sunday, April 23, 2000 6:35 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Detected but not responding...
    > Duncan
    edited 2000-04-23 16:51
    The ac adapter can supply 300 ma which should be enough for bs2sx. But i
    will try a battery later today.
    How can you specify a com port in the editor?
    Murray
    Sent: Sunday, April 23, 2000 2:20 AM
    boards
    bs2sx
    have
    > Regards,
    > Jim Szymczak
    edited 2000-04-23 19:18
    To specify a com port in Basic Stamp Editor version 1.091 beta go to:
    edit -> preferences -> editor operation -> then there is a pulldown menu to
    specify the default com port.
    >Murray
    >From: Jim Szymczak <szymczak@c...>
    >boards
    >bs2sx
    >have
    >> Regards,
    >> Jim Szymczak
    edited 2000-04-24 03:01
    Update:
    I tried to run from another pc Win98 400 MHz with 98 MB ram with the
    following results:
    From Basic Stamp Editor 1.091 beta
    if i click on identify button i get Found BS2SX-IC (firmware v 1.0)
    i set edit pref to auto detect and BS2SX
    after i click run i get:
    dialog => Basic Stamp II detected but not responding on COM1 check
    power supply.
    after i click ok i get
    dialog (Basic Stamp editor) with following list
    Create to FormCreate:18
    FormCreate to Open:0
    Open to FormShow:5
    FormShow to InitVitalSettings:5
    InitVitalSettings to DoSerial:0
    DoSerial to EnableDisableStatus:41821
    EnableDisableStatus to Create: -755927564
    Then Debug Terminal #1 is displayed.
    When i apply power to Stamp Activity Board the greeb led is on and i
    can click the 4 buttons and each led turns on.
    But nothing else works?????
    Both LM2936 5v reg. and 24LC16B/SN get hot to the touch the PBASIC
    chip doesn't get as hot but is warm.
    What other test can i do
    But i
    > Murray
    carrier
    > boards
    the chip
    Depending on
    of
    which
    the
    > bs2sx
    case
    you
    > have
    cable
    > > Regards,
    > > Jim Szymczak
    edited 2000-04-24 04:04
    Instead of letting the editor autodetect which com-port, specify either
    com1 or com2... If that doesn't work, try a different serial cable, or at
    least track down the pinouts and make sure the cable works. I don't know
    what else that you can test. Try connecting only to the basic stamp
    through the carrier board without any extra hardware and make sure there is
    no bent pins on the stamp. Although unlikely, you might try to reseat the
    stamp in it's socket. Perhaps it wasn't making a connection... Good Luck
    tracking down the problem.. If it turns out to be a bad stamp, let me know
    how consulting with Parallax pans out.
    Jim Szymczak
    N1RYU
    >Update:
    >following results:
    >power supply.
    >Open to FormShow:5
    >But i
    >> Murray
    >carrier
    >> boards
    >the chip
    >Depending on
    >of
    >which
    >the
    >> bs2sx
    >case
    >you
    >> have
    >cable
    >> > Regards,
    >> > Jim Szymczak
    edited 2000-04-24 16:04
    > Duncan
    I have the same trouble with a k6 machine running windows 98. I have found
    that a rs232
    in not necessarily a rs 232 as far as the pins go, I have not fixed the
    problem yet, but will
    put the findings on the site...........jwh
    edited 2000-04-24 23:37
    Update.
    I got an answer from tech support. All i had to do was change the extension
    of my program files from bs2 to bsx.
    I am now able to download and run programs.
    Murray
    Sent: Sunday, April 23, 2000 10:04 PM
    is
    > Regards,
    > Jim Szymczak
    > N1RYU
    > >Update:
    > >following results:
    > >power supply.
    > >Open to FormShow:5
    > >But i
    > >> Murray
    > >carrier
    > >> boards
    > >the chip
    > >Depending on
    > >of
    > >which
    > >the
    > >> bs2sx
    > >case
    > >you
    > >> have
    > >cable
    > >> > Regards,
    > >> > Jim Szymczak
    edited 2000-04-27 17:14
    Hello,
    I have a BS2SX, and I "had" the same problem. What I think you should
    do first is make sure you did not burn up your stamp. (As I hear people do
    it alot, but I never have [noparse]:)[/noparse] ) To do that, you need to have the newer
    windows stamp edator. If that is what you are using, click on the "ID" tag
    at the top of the screen. If it tells you that it cannot find the
    stamp,....... you just may be out of luck. As for the power, I use a 9V just
    fine. (then again I use BOE) But it can handle just a little bit over 5V, to
    a little over 12V ( I am not sure about the ending range, but to be exact,
    check the manual) It works great with that.
    Another thing is, if you have to much stuff hooked up to the boards
    power supply, (VIN, VDD) then it will draw WAY to much current, and will
    take all the power from the stamp, wich is not a good thing. What are you
    running on your board? Servos will defenatly eat it up, I know this from
    experence. Just make a power supply for what ever you are using one the
    board. If you are not using the boards power, I do not know what to tell
    you. Hope you find out what is wrong.
    -AJB, IL
    PS) You did save the code in SX right? Because if you did not, it will give
    you the same message.
    >Reply-To: basicstamps@egroups.com
    >Date: Sun, 23 Apr 2000 14:18:17 -0400
    > >Murray
    > >boards
    >chip
    >on
    >which
    > >bs2sx
    > >have
    > >> Regards,
    > >> Jim Szymczak
    ________________________________________________________________________
    Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
    The problem was the program file loaded had an extension of .bs2 and needed
    to be changed to .bcx.
    Everything now works.
    Thanks.
    Murray
    Sent: Thursday, April 27, 2000 11:14 AM
    > Hello,
    just
    to
    > -AJB, IL
    give
    to
    i
    > > >Murray
    > > >boards
    > >chip
    > >on
    > >which
    > > >bs2sx
    you
    > > >have
    cable
    > > >> Regards,
    > > >> Jim Szymczak
