MAX7219 Help! — Parallax Forums
MAX7219 Help!
edited 2000-04-21 06:04 in General Discussion
I am coming to the rope's end trying to get the app mod LED
driver to work, all I want to do is send the max7219 a number based
on input recieved from a keypad and count the numbers down. The
numbers are all in 50 units incs up to 500. Can anyone help?
    edited 2000-04-21 05:14
    Umm, you're already using the Scott Edwards code? I used the SE app note
    with no problems...make sure you've got it wired right and it only supports
    common cathode LEDs. If you're more specific about what's happenning I'm
    sure someone here can be of assistance.
    Duncan
    I know nothing about this chip, but check out
    http://www.al-williams.com/wd5gnr/stampfaq.htm#s3.11
    Ed Ward contributed code for this device to the FAQ.
    Al Williams
    AWC
    *Expand your Stamp's I/O with a PAK-III or PAK-IV:
    http://www.al-williams.com/awce/pak3.htm
    > From: orthner@s... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2gjsE7NlNYnAGD-gnvWBS9ZhdrlQctlIPvtbrixj7yaS6KKdoL_AkhEPU45ZBJ7AzXJt3j0GX8MGEA]orthner@s...[/url
    > Sent: Thursday, April 20, 2000 11:15 PM
    > To: basicstamps@egroups.com
    > Subject: Re: [noparse][[/noparse]basicstamps] MAX7219 Help!
    > only supports
    > Duncan
