Buffer-amplifier chip? — Parallax Forums
edited 2000-04-20 10:00 in General Discussion
Hello all,
I'm trying to interface a PIC with the parallel port on my
computer and I'm only getting ~3.5v for a 'high'. Can anyone suggest a
buffer-amplifier chip that will take a flaky logic level and turn it into 5v?
Thanks, Duncan
    edited 2000-04-18 19:03
    At 01:42 PM 4/18/00 -0400, orthner@s... promulgated:
    >Hello all,
    >Thanks, Duncan
    Duncan -
    Is this a laptop ?
    Bruce
    edited 2000-04-19 09:37
    Hi all,
    I don't really have a solution for this, for which I'm sorry Duncan, but I have
    a
    similar problem with my bs2sx: the pins will only output a tiny 0.5 volts when I
    set them high ...
    I have been trying rctime in the standard light sensor setup from the manual on
    all the pins individually and that works perfectly. But when i write a program
    that sequentially sets all pins high for a while and measure the pins directly
    with a volt meter I only get 0.5 volts.
    For every pin there is a 220 ohm resistor on my board ( I soldered those in
    after
    I saw it on a picture earlier and since allmost all setups require resistors
    between the pin and the external circuitry I thought it would be handy to put
    them in as standard ) Maybe I shouldn't have done that?
    kind regards,
    Sandor
    orthner@s... wrote:
    > Hello all,
    > Thanks, Duncan
    edited 2000-04-19 16:41
    Sandor Rabe <sandor.rabe@e...> writes:
    directly
    Are these 220 ohm resistors going from your output pins to ground? If so,
    5000/220 = 22 milliamps, which sounds like too much current to source,
    especially if you have several pins set to Hi at the same time. Just an
    idea...
    Also, a common "cure" is to use "Schmidt triggers" on your outputs
    (74xxx14) to get a full TTL Hi.
    Steve
    Steve Roberts: sroberts@s...
    edited 2000-04-19 17:05
    You can use a 74125 which is a 3.0 logic to 5 volt logic buffer.
    However a 3.5 level is "OK" for TTL.
    Kent Dillin
    edited 2000-04-19 22:51
    Thanks everyone for ideas on this. I ended up using a '244 buffer-driver
    and it worked great. Really cleaned up those flaky signals coming from the
    parallel port...
    Duncan
    Hi Steve
    > directly
    > idea...
    Nah. I've connected resistors to pin0..pin15 and beyond the resistors there
    is just a bank of "sockets" in which I can plug wires going to whatever
    external circuitry. The resistors are only there to protect my pins. Also, I
    tested them sequentially which means the there's only 1 pin high at a give
    time. I measured the potential between the pin after the resistor and ground
    with a volt meter and that read 0.5 volts. I din't hook up anything else on
    those pins when measuring.
    [noparse][[/noparse]....]
