LCD-Wirz — Parallax Forums
LCD-Wirz
edited 2000-04-15 16:09 in General Discussion
I just assembled a Seiko display to a Wirz serial board, both from MP Jones.
The Wirz is called SL1-OEM. I tried to run it from a BS1 with serout
commands. It is supposed to autodetect true or inverted input, but I can
only get some text display at 1200N, garbage at 2400. Clearing the screen
with chars 10,13 displays garbage. Also, it will not display more than 8
chars on a 1x16 display. The Wirz docs are poor. Is it possible that the
Wirz needs "pacing" as a BS2 can do? I have successfully run several
different serial VFDs from the BS1, but am new to serial communications.
Can someone give me a clue?
Ray McArthur
    edited 2000-04-15 06:40
    Update:
    I got the display working using control commands from Scott Edwards bakpak
    docs, but I still only get 8 of the 16 characters. It happens for all
    column settings of the dip switches at or above 16 chars. Does this mean I
    have busted hardware, or is there more to know?
    Ray McArthur
    To: stamps parallax <basicstamps@egroups.com>
    Sent: Friday, April 14, 2000 11:49 PM
    Subject: [noparse][[/noparse]basicstamps] LCD-Wirz
    Jones.
    > Thanks,
    > Ray McArthur
    edited 2000-04-15 07:01
    Update to the update:
    Got it working all columns! It must be a "split 2x8" display that Scott's
    docs talk about for some 1x16 units. Had to set dip switches for "1 row
    split" and 8 columns.
    Thanks, anyhow.
    Ray McArthur
    To: <basicstamps@egroups.com>
    Sent: Saturday, April 15, 2000 1:40 AM
    Subject: Re: [noparse][[/noparse]basicstamps] LCD-Wirz
    > Update:
    I
    > Thanks,
    > Ray McArthur
    > From: rjmca <rjmca@w...>
    > Jones.
    can
    screen
    8
    the
    > > Thanks,
    > > Ray McArthur
    HI Ray,
    It sounds like you have a few problems.
    1. Check your DIP Switch settings. Chances are you've got something wrong
    there. I know they can be really confusing.
    2. The 16x1 LCD from MPJA is wired as an 8x2. Check the docs and make sure
    the LCD line setting on the SLI-OEM switches are correct.
    3. 10, 13 will not clear the screen. Use a Form Feed Character or send
    0x0FE, 0x001 to clear it.
    Good luck,
    myke
    > Update:
    I
    > Thanks,
    > Ray McArthur
    > Jones.
    can
    screen
    8
    the
    > > Thanks,
    > > Ray McArthur
