BS2SX - party line communications — Parallax Forums
edited 2000-04-14 00:04 in General Discussion
HELP!
· I need help getting a multi-stamp system, where each stamp communicates over a common line [noparse][[/noparse]using texas Instruments SN75176 transceivers]. I can capture data using low baud rate for transmitting stamp, and high baud rate for receiving stamp, but data is wrong, and not consistant.
George@csi-aero.com
    edited 2000-04-13 23:58
    At 02:39 PM 4/13/00 -0700, George promulgated:
    >HELP!
    >George@c...
    George -
    This TI chip supports RS-485, this is not something the Stamp can deal with
    directly. There are solutions, however. Your best bet is to obtain a copy of
    Serial Port Complete, a book by Jan Axleson. Her website is [noparse][[/noparse] www.lvr.com ].
    Although this book is not about Stamps is covers the entre of most serial
    protocols. It also deals with interfacing to those protocals in various ways.
    This presumes you want to learn about such things, and have the time to do the
    necessary learning.
    If you are familiar with the protocol, but unfamiliar with the Stamp, you
    might
    benefit from some of the examples found at www.hth.com/losa . LOSA is an
    acronym
    for List Of Stamp Applications. This is a compendium of various projects,
    done by Stampers. It is a completely voluntary effort.
    If you are in need of a "quick-fix" and in a hurry to bring a Stamp or
    other device onto an RS-485 network, check B&B Electronics [noparse][[/noparse]
    http://www.bb-elec.com/ ]. They have various protocal converters and other
    serial device equipment. Bringing the RS-485 to RS-232 may begin to give
    you what you need. Once you get to that point the protocal becomes easier
    to deal with, but full function may be lost by the time you get to the
    stamp end.
    If you are electronically inclined, and wish to make your own converter,
    refer to
    the first reference. Jan's book will be your key.
    Concerns about voltage level shifting are generally addressed by the
    MAX-232 (Maxim: www.maximic.com) or other similar devices. I suspect TI may
    have some too.
    So there's a brief help summary regarding serial protocols and the Stamp.
    If you
    have specific needs or questions, please state them in detail.
    Bruce
    >Attachment Converted: "d:\eudora\attach\basicst3.htm"
    At 06:58 PM 4/13/00 -0400, Bruce Bates promulgated:
    >>HELP!
    >>George@c...
    George -
    Sorry - I just realized you had BS2-SX in the title. The Parallax website is
    down at the moment, but if you would like, I can send you the pertinant data
    regarding serail communication and the BS2-SX. The baudmode parameters differ
    from those in the book.
    Bruce
