Big LED displays — Parallax Forums
Big LED displays
edited 2000-04-12 17:45 in General Discussion
Dear List,
I am trying to make a four digit LED display using four 4" displays made by
Ligitek (common cathode). They require between 12 to 14 volts total to be
driven. I am using the Maxim 7219 seven segment LED driver... the problem
is of course that the Maxim chip cannot deliver that kind of voltage. I am
a bit unsure how to bridge the two... I need to bridge both the segment pins
and the digit pins of the chip to the display. How? I am assuming the
segment pins are positive and the digit pins are negative... The Maxim
chip's datasheet has a diagram that claims to explain how to do this but it
seemed to never leave the 5 volt realm.
Thanks in advance
Paul
Paul Ramirez Jonas
email prjnyc@m...
    by
    > Ligitek (common cathode). They require between 12 to 14 volts...
    Paul,
    While not slated to be released until early next week, I'll mention this
    just a bit early since you asked: The EDE707 Octal Seven-Segment LED Display
    Decoder is now available for shipping. This 28 pin addition to our EDExx IC
    Family should be just what you are looking for; its outputs drive
    inexpensive 2N2222 NPN transistors, so the voltage you're using will pose no
    problems.
    Features include a full Hex character set (0123456789AbCdEF), counter
    functionality, leading zero blanking, and lamp test. Interface is via a
    four-bit bus with latch signal.
    A PDF datasheet is available for download at our website:
    http://www.elabinc.com in the 'EDExx IC Family' section. Also, for a CD-ROM
    containing our latest datasheets (Paul or anyone on the list), just e-mail
    me your postal mailing address (off-list) to the address shown below.
    Best of luck with the project!
    Todd Peterson
    E-Lab Digital Engineering, Inc.
    (816) 257-9954 FAX: (816) 257-9945
    toddp@e...
