Stamps and motor control — Parallax Forums
edited 2000-04-10 16:36 in General Discussion
Hello,
I have an old Hero 2000 robot arm, which was sold by Heathkit. The same arm
was sold separately from the robot as an "arm trainer". Not counting the
gripper, the arm is moved by four identical, 12V gearmotors. One for
shoulder, one for elbow, and two for wrist (the wrist is a differential
mechanism).
I have been trying to create an interface so that I can control the arm with
my PC. I am using the Basic Stamp II for PC interfacing. To drive the
motors, I am using SN754410NE motor driver chips. For PWM speed control, I'm
using the PAK Va from AWC.
Here's the problem: I'm a bit new at motors, and I'm having some troubles.
At low PWM duty cycles, the motor makes a high pitched sound and won't move.
At slightly higher speeds, the tone is still there but the motor starts to
move. What is this tone?
Also, I was under the impression that the SN754410NE had built-in diodes for
backEMF protection. One of the chips exploded (sparks, little divot out of
the top of the IC) today, leading me to believe that something was wrong.
Does anyone have experience working with the Hero 2000 arm? What I'd really
love is a circuit to build that lets the PC or Stamp (or other
microcontroller) drive the arm's motors. I can handle control algorithms,
etc. I'm just having trouble with the hardware interfacing. I'd like to see
someone's
circuit to see where I'm going wrong.
Joe Driscoll
    edited 2000-04-07 00:32
    HI,
    Don't know about the SN754410NE chip but the MC33030 chip is very easy to use
    with a STAMP2 . I am using them with an x-Y control system and it is fairly
    simple.
    I found that the STAMP needs expansion for both analog signal and digital data
    handling.
    If you want I can email my prgm ( not yet fully debugged ) and it will give you
    some idea of the complexity.
    The noises are the PWM causing the windings to vibrate. If you are using a PWM
    to control speed
    you must be sure that the inductance of the motor is high enough so that the
    current continues to flow during the off
    time. Try the chip in a simple config before using it in a STAMP control system
    to make sure you have that part working smoothly.
    Also you need diodes to make sure that the stored energy in the inductance has
    somewhere to go.. In the case of full H bridge that means 4 diodes
    for each motor. Usually they are built in to the control chip.
    ( PLEASE NO MORE DIODE RELAY STUFF!!! [noparse]:)[/noparse])
    To: <basicstamps@egroups.com>
    Date sent: Thu, 6 Apr 2000 17:51:40 -0500
    Send reply to: basicstamps@egroups.com
    Subject: [noparse][[/noparse]basicstamps] Stamps and motor control
    > Hello,
    > mechanism).
    > someone's
    > Thanks,
    > Joe Driscoll
    ron... the motor man...
    Ronald Doctors
    http://www.members.home.net/rdoctors
    edited 2000-04-07 01:50
    Thanks for the reply. Yes, please send me your program -- that would help a
    lot. When you say "you must be sure that the inductance of the motor is high
    enough so that the current continues to flow during the off time", I'm not
    sure I understand that part. With the SN754410NE and the L293D, when the
    enable pin is low, the outputs are at a high impedance state. Is that a
    problem? It seems like the back emf produced during that "off" time needs to
    go somewhere. Maybe this is the problem?
    Joe Driscoll
    Sent: Thursday, April 06, 2000 6:32 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Stamps and motor control
    > HI,
    use
    fairly simple.
    data handling.
    give you some idea of the complexity.
    a PWM to control speed
    system to make sure you have that part working smoothly.
    has somewhere to go.. In the case of full H bridge that means 4 diodes
    > From: "Joseph Driscoll" <driscoll85@h...>
    > > Hello,
    arm
    > > mechanism).
    with
    I'm
    troubles.
    move.
    to
    for
    of
    wrong.
    really
    algorithms,
    see
    > > someone's
    > > Thanks,
    > > Joe Driscoll
    > Ronald Doctors
    edited 2000-04-07 02:36
    Sent: Thursday, April 06, 2000 8:48 PM
    > Way back when I assembled one and installed it into a hero 2K for my
    junior high science class. The only things I recall vividly are that:
    > 1. the motors were driven by large heatsinked H-bridges. I suggest getting
    a much more robust controller. 5A @ 12V would not be unreasonable.
    I've measured the current draw, and it's usually around 0.5 amp.
    > 2. failure to monitor the limit switches caused biiiiiiiig problems. The
    cable drive is more fragile than it looks.
    My plan is to monitor the limit switches from the stamp, by running them to
    input lines. Or, I could just have a hardware shutoff, using an OR gate or
    something.
    > I have a vague recollection of encoders on the arm as well, but this might
    be a figment of my imagination. I do remembr clearly the ordeal that getting
    to e arm to 'home' was. It seems the hero 2K SW was very picky.
    Right, there are optical encoders on all of the motors. They output pulses,
    which are squared up via a LM393. I plan to use a PAK VII pulse coprocessor
    (from AWCE) to keep track of pulses. The stamp can then ask the PAK
    periodically for pulse counts, and that way the position of the arm is known
    (assuming it started from a known location).
    I plan to use the stamp as an arm "server": it polls sensors (and the PAK
    VII) and sends that data to a PC. The PC then sends speed and direction
    commands. The control algorithms can then be carried out on the PC.
    edited 2000-04-07 02:48
    Way back when I assembled one and installed it into a hero 2K for my junior high
    1. the motors were driven by large heatsinked H-bridges. I suggest getting a
    2. failure to monitor the limit switches caused biiiiiiiig problems. The cable
    I have a vague recollection of encoders on the arm as well, but this might be a
    figment of my imagination. I do remembr clearly the ordeal that getting to e arm
    -dave
    Passion must be present. Everything else can be learned.
    WCCR chief engineer, Professional student, geek at large, and I'm 6'4
    dave paton http://homepage.mac.com/dpaton dave at ieee dot org
    edited 2000-04-07 03:32
    Joe:
    The TI datasheet states that external clamp diodes should be used with
    inductive loads. The equivalent circuit they show does not have clamp
    diodes. This is probably what caused your smoke. You need 4 diodes. At
    each motor terminal, connect two diodes: one to the bridge positive supply,
    the other to bridge gnd or negative. All diodes should "point" up toward
    plus supply.
    Ray McArthur
    Sent: Thursday, April 06, 2000 8:50 PM
    > Hi,
    a
    high
    to
    > Thanks,
    > Joe Driscoll
    edited 2000-04-07 03:57
    Er..that's what I meant. Missed the '.'. Still, half an amp at 12V is 6W. I
    doubt most IC drivers could handle that. Besides, an h-bridge isn't very hard to
    build. Also don't forget the starting current will be a little higher. The
    motors are geared way down, but there is still a largish kick needed to start
    them, especially when they are loaded heavily. And then there's the inductive
    kick when you turn it off, or reverse it...
    Of course, I'm fond of overdesigning my controllers by a fcator of 2, so take
    this with a grain or two of salt.
    > something.
    Mmm...I'd go for the switches as inputs to the stamp. MUX them if required.
    Using the limit switches as hardware cutoffs will complicate things
    unnecesarially, IMHO, as you'll have to bypass them to restart the motor, and
    with reversing factored in....ugh.
    > > getting the arm to 'home' was. It seems the hero 2K SW was very picky.
    Cool. Sounds like a nice imple way to get it to go. It also saves the stamp from
    having to do the counting, and the associated overhead.
    Sounds like fun. Keep us updated!
    -dave
    edited 2000-04-07 04:08
    Joe:
    My last message applies to the L293. I just looked at the data for the
    SN754410NE, and it DOES show clamp diodes built into the IC. Also, they do
    not have the recommendation to use them. What I don't understand is that
    they still used external clamps in their example circuit.
    Ray McArthur
    Sent: Thursday, April 06, 2000 10:32 PM
    > Joe:
    supply,
    > plus supply.
    > Ray McArthur
    > From: Joseph Driscoll <driscoll85@h...>
    > > Hi,
    help
    > a
    > high
    not
    needs
    > to
    > > Thanks,
    > > Joe Driscoll
    edited 2000-04-07 04:21
    I'm not an expert on motor drivers, but I think the L293 does NOT have
    diodes. the L293D does -- you have to make sure which one you have.
    Al Williams
    AWC
    * 8 Channels of PWM with the PAK-V at
    http://www.al-williams.com/awce/pak5.htm
    > Joe:
    > Also, they do
    edited 2000-04-07 04:53
    I have the L293D and the SN754410NE, both of which have built-in diode
    protection at the outputs. The current draw from the motor I'm using is
    around 0.5A (which is close to max on the L293D, so that's why I use the
    SN754410NE). And still, poof: the chip blew up during PWM operation (not at
    startup). I have a schematic in GIF format if anyone is interested.
    Joe Driscoll
    Sent: Thursday, April 06, 2000 10:21 PM
    Subject: RE: [noparse][[/noparse]basicstamps] Stamps and motor control
    > Regards,
    > Al Williams
    > AWC
    > > Joe:
    > > Also, they do
    that
    edited 2000-04-07 05:58
    I revisited their site. You're right, Al. Thanks for the info.
    Ray McArthur
    Sent: Thursday, April 06, 2000 11:21 PM
    > Regards,
    > Al Williams
    > AWC
    > > Joe:
    > > Also, they do
    that
    edited 2000-04-07 06:10
    Joe:
    You may send me a schematic off-list if you want. No guarantees, but I can
    try. Question: what is the PWM frequency?
    Ray McArthur
    Sent: Thursday, April 06, 2000 11:53 PM
    > Hi,
    at
    > Joe Driscoll
    > From: Al Williams <alw@a...>
    > > Regards,
    > > Al Williams
    > > AWC
    > > > Joe:
    the
    > > > Also, they do
    > that
    edited 2000-04-07 13:56
    Oh, sorry Joe. I was replying to a reply and didn't realize you were the
    originator of the thread. I know we covered this off line already. Whoops.
    Al Williams
    AWC
    *Solderless Stamp Prototyping: http://www.al-williams.com/awce
    > From: Joseph Driscoll [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PxENTq7vd_PsjAG31F35qo7Sn1vR611Cpd0UG4npeQkQmtS3GzHQ0TrgeSGqjpZR2xAWbm24sAP1F7Du4K47Q88]driscoll85@h...[/url
    > Sent: Thursday, April 06, 2000 10:54 PM
    > To: basicstamps@egroups.com
    > Hi,
    > operation (not at
    > Joe Driscoll
    > > Regards,
    > > Al Williams
    > > AWC
    > > > Joe:
    > data for the
    > > > Also, they do
    > that
    edited 2000-04-07 15:13
    At 09:22 AM 4/7/00 -0500, Joseph Driscoll promulgated:
    >Hi,
    >The GIF is on its way to you off list. I have a question for everyone: what
    >happens if you switch the enable pin of the motor driver chip too fast?
    >Maybe the frequency of the PWM signal is too high? Would too fast a
    >switching time fry the driver chip?
    Hi Joe -
    Sure could !
    There is generally a frequency (aka repetition) maximum in the data sheet.
    Sorry - I don't have a data sheet handy.
    It should be under the AC characteristics - even though this is a DC device.
    Bruce
    >Thanks,
    >Joe Driscoll
    >From: rjmca <rjmca@w...>
    >Sent: Friday, April 07, 2000 12:10 AM
    >> Joe:
    >can
    >> Ray McArthur
    >> > Hi,
    >> at
    >> > Joe Driscoll
    >> > > Regards,
    >> > > Al Williams
    >> > > AWC
    >> > > > Joe:
    >> the
    >> > > > Also, they do
    >> > that
    edited 2000-04-07 15:15
    >Hi,
    >Thanks,
    >Joe Driscoll
    Joe -
    Just one more comment -
    The PWM signal should be going to the POWER LEADS, *NOT* the ENABLE lines.
    At least that's what I've generally seen, YMMV depending on the particular
    chip.
    egards,
    Bruce
    >> Joe:
    >can
    >> Ray McArthur
    >> > Hi,
    >> at
    >> > Joe Driscoll
    >> > > Regards,
    >> > > Al Williams
    >> > > AWC
    >> > > > Joe:
    >> the
    >> > > > Also, they do
    >> > that
    edited 2000-04-07 15:22
    Joe Driscoll
    > Joe:
    can
    > Ray McArthur
    > > Hi,
    > at
    > > Joe Driscoll
    > > > Regards,
    > > > Al Williams
    > > > AWC
    > > > > Joe:
    > the
    > > > > Also, they do
    > > that
    edited 2000-04-07 15:44
    I'm looking at the SN754410NE datasheet, and they have some timing diagrams
    using a "test circuit" that had a pulse high-time of 10 uS. But I can't tell
    if that is a minimum by looking at the page. On another page, where min,
    max, and typical values are given, the rise time, fall time, and pulse
    duration values are blank. I'm using the PAK Va from AWC for PWM. It has two
    modes of operation, equal area mode and proportional PWM mode. Its data
    sheet says that when using equal area mode, the time period is about 512 uS,
    and proportional PWM mode uses a 2 uS time base. Sound like equal mode is
    slower, and therefore safer in my application? What driver chips have others
    used with the PAK Va? How were things connected?
    Joe Driscoll
    Sent: Friday, April 07, 2000 9:13 AM
    > >Hi,
    what
    > Hi Joe -
    > Sure could !
    device.
    > Regards,
    > Bruce
    > >Thanks,
    > >Joe Driscoll
    > >> Joe:
    > >can
    > >> Ray McArthur
    > >> > Hi,
    diode
    is
    the
    (not
    > >> at
    > >> > Joe Driscoll
    have
    > >> > > Regards,
    > >> > > Al Williams
    > >> > > AWC
    > >> > > > Joe:
    for
    > >> the
    > >> > > > Also, they do
    is
    > >> > that
    edited 2000-04-07 15:57
    You mean the logic Vcc of the driver chip should be switched? Or do you mean
    the driver channel inputs? I've heard of the latter, but I've seen many
    cases of pulsing the enable lines (but maybe they were using a slower PWM
    frequency). Why is pulsing the enable lines bad? Is it because when the
    enable is low, the outputs are at high-Z?
    Joe
    Sent: Friday, April 07, 2000 9:15 AM
    > Joe -
    > chip.
    > egards,
    > Bruce
    > >> Joe:
    > >can
    > >> Ray McArthur
    > >> > Hi,
    diode
    is
    the
    (not
    > >> at
    > >> > Joe Driscoll
    have
    > >> > > Regards,
    > >> > > Al Williams
    > >> > > AWC
    > >> > > > Joe:
    for
    > >> the
    > >> > > > Also, they do
    is
    > >> > that
    edited 2000-04-07 16:33
    Just to clarify:
    1) The PAK-V and the PAK-Va are identical except the old PAK-V required a
    shunt resistor across its timing element. The PAK-Va does not. There are no
    more PAK-Vs, just the PAK-Va, but we have several volume customers who would
    be upset if we just changed how the chip works and didn't give it a new
    name. However, informally, we just call them PAK-V.
    2) In either mode, the time base is 2uS. Here's how it works.
    Proportional mode (like the Stamp) figures the least amount of work
    required. At 50%, for example, there is a 2uS on time and a 2uS off time.
    For 33% there is a 2uS on time and 4uS off time. The proportion of the
    pulses is correct, but the total frequency varies depending on the duty
    cycle. So 50% is 250kHz and 33% is 166.7kHz. This mode charges a capacitor
    as fast as possible for a given duty cycle.
    Equal Area mode always uses 256 time periods (512uS or 1.95kHz). 50% is
    256uS on and 256uS off. 1/256 is 2uS on and 510uS off. This mode is often
    used in controlling LEDs. Makes for a nice scope display too.
    The mode is set for the whole chip. So all 8 PWM outputs are in one mode or
    the other.
    I know from your previous e-mails that the Stamp's PWM is not driving your
    motors any better than the PAK-V. I wonder if you try driving the supply pin
    if that will make a difference?
    Al Williams
    AWC
    * Expand your Stamp I/O with a PAK-III or IV:
    http://www.al-williams.com/awce/pak3.htm
    > From: Joseph Driscoll [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EPcTaQR2fLlHk8jpF-e73hTe-nQ9RaY-e4XCVcppGi8M_fq-LLZGhyyl2WUGbbB_bCnVMA31mmpxxcjX]driscoll85@h...[/url
    > Sent: Friday, April 07, 2000 9:45 AM
    > Hi,
    > timing diagrams
    > can't tell
    > It has two
    > about 512 uS,
    > have others
    > Thanks,
    > Joe Driscoll
    > From: Bruce Bates <bvbates@u...>
    > > >Hi,
    > what
    > > Hi Joe -
    > > Sure could !
    > data sheet.
    > device.
    > > Regards,
    > > Bruce
    > > >Thanks,
    > > >Joe Driscoll
    > > >> Joe:
    > guarantees, but I
    > > >can
    > > >> Ray McArthur
    > > >> > Hi,
    > diode
    > I'm using
    > is
    > why I use
    > the
    > (not
    > > >> at
    > > >> > Joe Driscoll
    > have
    > one you have.
    > > >> > > Regards,
    > > >> > > Al Williams
    > > >> > > AWC
    > > >> > > > Joe:
    > for
    > > >> the
    > > >> > > > Also, they do
    > understand
    > is
    > > >> > that
    edited 2000-04-07 18:42
    I'll send it off line.. the diodes 4 need to go directly from the motor
    to the supply pos and neg. all 4 diodes go arrow up toward the rail. They are
    not ON except during back emf.
    They need to be rated at 2 x the rail max volts and at least equal to max amps.
    Date sent: Thu, 6 Apr 2000 19:50:42 -0500
    > Hi,
    > Thanks,
    > Joe Driscoll
    > From: Ronald Doctors <rdoctors@h...>
    > > HI,
    > use
    > fairly simple.
    > data handling.
    > > > Hello,
    > arm
    > > > mechanism).
    > with
    > I'm
    > troubles.
    > move.
    > to
    > for
    > of
    > wrong.
    > really
    > algorithms,
    > see
    > > > someone's
    > > > Thanks,
    > > > Joe Driscoll
    > > Ronald Doctors
    Ronald Doctors
    edited 2000-04-07 22:29
    Joe:
    I have to study your circuit & info, but a general answer about frequency is
    yes, it can make smoke if it's too high. PWM is used to minimize power
    dissipation in the control transistors, because the transistors are switched
    "on" or "off". Power dissipated is Vce x Ic. When the transistor is "on",
    Vce is low, so power is small. When the switch is "off", power is low
    because current is zero. However, during switching "on" to "off" or vice
    versa, power dissipation can be quite high (especially with an inductive
    load). If switching frequency is low enough, these intervals of high power
    dissipation occur a small percentage of total time, so the average power is
    small. Another problem is that diodes have a "recovery time", which means
    that they momentarily are like a "short" when going from conduction to
    non-conduction. This causes current spikes in the switching transistors
    which becomes more important as frequency rises.
    The question of what is "too high" a frequency depends on the speed of the
    transistors & diodes used. Off hand I don't know. Maybe we will have an
    idea after studying your stuff. I wonder if Ron Doctors has experience with
    this?
    Ray McArthur.
    Sent: Friday, April 07, 2000 10:22 AM
    > Hi,
    what
    > Thanks,
    > Joe Driscoll
    > > Joe:
    > can
    > > Ray McArthur
    > > > Hi,
    is
    the
    (not
    > > at
    > > > Joe Driscoll
    have
    > > > > Regards,
    > > > > Al Williams
    > > > > AWC
    edited 2000-04-09 02:25
    Joe:
    The data for the SN754410 calls out 400-900ns enable/disable time. This
    means that if you are applying PWM to the enable line in proportional mode,
    the frequency is way too high. Al Williams states that this mode outputs in
    the range of 200kHz. But Al also points out that equal area mode is ~ 2kHz,
    which is much more reasonable for your chips. Could you operate in this
    lower frequency mode?
    Ray McArthur
    > Hi,
    what
    > Thanks,
    > Joe Driscoll
    edited 2000-04-09 03:55
    Well, 900nS on and 900nS off is 1.8uS. The PAK works at 2uS per half
    cycle -- 4uS per cycle or 250kHz. So I think that is OK.
    Al Williams
    AWC
    * Microcontroller Projects with Basic Stamps:
    www.al-williams.com/awce/sbook.htm
    > From: rjmca [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ADECN2VpSCzZk-QMXGKncAgrpvCwYEuZifuRdFWK8nPb9MpcMsSTpmWzbKt5VOiKjmHmt-7ImpSf]rjmca@w...[/url
    > Sent: Saturday, April 08, 2000 8:26 PM
    > Joe:
    > proportional mode,
    > outputs in
    > is ~ 2kHz,
    > Ray McArthur
    > > Hi,
    > what
    > > Thanks,
    > > Joe Driscoll
    edited 2000-04-09 06:08
    Al:
    I am afraid that the switching losses will be very high when the time spent
    transitioning from hi to lo and back is an appreciable part of the total
    duty cycle. Is there a problem running at the lower frequency? If you have
    a chance, read my message of 4/7 at 5:30PM and see if you agree with it.
    Ray McArthur
    Sent: Saturday, April 08, 2000 10:55 PM
    > Regards,
    > Al Williams
    > AWC
    > > From: rjmca [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=T_TNx--ywac1zdd1INVKdayt8-CMaYxVQ9wAfGzeEZkxiGt1xknCDVHH5Cq3LnQAI0Rm1n0rr3Fw]rjmca@w...[/url
    > > Joe:
    > > proportional mode,
    > > outputs in
    > > is ~ 2kHz,
    > > Ray McArthur
    > > > Hi,
    > > what
    fast?
    > > > Thanks,
    > > > Joe Driscoll
    edited 2000-04-09 06:37
    That's true too. Actually, you can scale back the clock element and reduce
    your baud rate by the same factor. This also reduces current consumption to
    the chip. So a 25Mhz resonator (or crystal) will cut your baud rate in half
    and set the time base to 4uS.
    Al Williams
    AWC
    * Solderless Stamp prototyping at http://www.al-williams.com/awce
    > From: rjmca [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=E1MvJwF7-3meP_okLo2fuy27sy2c2e65DgLVAadGLbKm5hjcH3B54S0TSTi2O8qWcVSkBAqhXHC2FA]rjmca@w...[/url
    > Sent: Sunday, April 09, 2000 12:09 AM
    > Al:
    > time spent
    > If you have
    > Thanks,
    > Ray McArthur
    > > Regards,
    > > Al Williams
    > > AWC
    > > > Joe:
    > time. This
    > > > proportional mode,
    > > > outputs in
    > > > is ~ 2kHz,
    > operate in this
    > > > Ray McArthur
    > > > > Hi,
    > for everyone:
    > > > what
    > fast?
    > > > > Thanks,
    > > > > Joe Driscoll
    I'll try things in equal area mode and see what happens. I'll be away from
    the arm for a week or so, but I'll let you know when I've tried things.
    Joe Driscoll
    >From: "Al Williams" <alw@a...>
    >Reply-To: basicstamps@egroups.com
    >Date: Sun, 9 Apr 2000 00:37:47 -0500
    >Regards,
    >Al Williams
    >AWC
    > > From: rjmca [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=s5GumWWCPH2R8A8RWbxD1GJF2ze-xvrDOa1_YXdYNF9QA0ihwHXTE8x5LWa-N02mmuq5JQDi7hwJ2l3w]rjmca@w...[/url
    > > Al:
    > > time spent
    > > If you have
    >it.
    > > Thanks,
    > > Ray McArthur
    > > > Regards,
    > > > Al Williams
    > > > AWC
    > > > > Joe:
    > > time. This
    > > > > proportional mode,
    > > > > outputs in
    > > > > is ~ 2kHz,
    > > operate in this
    > > > > Ray McArthur
    > > > > > Hi,
    > > for everyone:
    > > > > what
    > > fast?
    >a
    > > > > > Thanks,
    > > > > > Joe Driscoll
    ______________________________________________________
    Get Your Private, Free Email at http://www.hotmail.com
