2 pin BSC2 to stepper — Parallax Forums
edited 2000-04-16 05:24 in General Discussion
Hi all:
If anyone has worked with these Airpax stepper motor linear actuators give
me a holler please.
They don't seem to have any significant actuation force. Is the low $9 buck
price a tip off? Guess I answered my own question, but any feed back on this
is welcome. So if you pay big bucks the thing is going to have 1 LBF or so?
Here's my code if anyone is interested:
'ALLEGRO UND2544B TO AIRPAX STEPPER LINEAR 'ACTUATOR A92218 (JAMECO P/N
162587)
'3/31/00 TECHNO_MASAI-M.PLUNKETT
'ADAPTED FROM ALLEGRO UND2544B SPEC SHEET.
'TWO WIRE CONTROL OF STEPPER,
'STEPPER WIRE DIAGRAM TO '2544B
'ORG PIN 8
'BLK PIN 6
'BRN PIN 3
'YEL PIN 1
'SEE ALLEGRO DWG# EP-015 FOR ZENER, ETC ON P3 'OF SPEC SHEET, IT WON'T PRINT
OUT UNLESS YOU '"PRINT AS IMAGE".
DIRS = %0000000000000111
CTR VAR WORD
DELAY VAR WORD
STEPS VAR WORD
COIL1_2 CON 0
COIL3_4 CON 1
DELAY = 2
STEPS = 50
'Retract
FOR CTR = 1 TO STEPS
LOW COIL1_2
HIGH COIL3_4
PAUSE DELAY
LOW COIL1_2
LOW COIL3_4
PAUSE DELAY
HIGH COIL1_2
LOW COIL3_4
PAUSE DELAY
HIGH COIL1_2
HIGH COIL3_4
PAUSE DELAY
NEXT
'EXTEND
HIGH COIL1_2
HIGH COIL3_4
PAUSE DELAY
HIGH COIL1_2
LOW COIL3_4
PAUSE DELAY
LOW COIL1_2
LOW COIL3_4
PAUSE DELAY
LOW COIL1_2
HIGH COIL3_4
PAUSE DELAY
NEXT
END
    edited 2000-04-12 02:34
    Pardon the delayed response, but I just noticed that you have delay=2 in
    your code. I have used a Slo-Syn stepper and a geared stepper from Airpax.
    Mine will not even run with a delay of only 2 ms. In both cases, torque
    falls off below ~25 ms. If you look with a scope, you can see that coil
    current doesn't have time to decay, (because of inductance), at too high a
    stepping rate. In addition, mechanical inertia also eats up torque at high
    rates. The max rate depends on the particular stepper, but I will bet that
    2 ms is way too fast for your motor. The rate can be boosted somewhat by a
    zener in your clamp circuit.
    Better late than never?
    Ray McArthur
    To: <basicstamps@egroups.com>
    Sent: Saturday, April 01, 2000 10:26 PM
    Subject: [noparse][[/noparse]basicstamps] 2 pin BSC2 to stepper
    > Hi all:
    > me a holler please.
    buck
    this
    so?
    > 162587)
    > 'ORG PIN 8
    > 'BLK PIN 6
    > 'BRN PIN 3
    > 'YEL PIN 1
    PRINT
    > CTR VAR WORD
    > DELAY VAR WORD
    > STEPS VAR WORD
    > COIL1_2 CON 0
    > COIL3_4 CON 1
    > DELAY = 2
    > STEPS = 50
    > 'Retract
    > LOW COIL1_2
    > HIGH COIL3_4
    > PAUSE DELAY
    > LOW COIL1_2
    > LOW COIL3_4
    > PAUSE DELAY
    > HIGH COIL1_2
    > LOW COIL3_4
    > PAUSE DELAY
    > HIGH COIL1_2
    > HIGH COIL3_4
    > PAUSE DELAY
    > NEXT
    > 'EXTEND
    > HIGH COIL1_2
    > HIGH COIL3_4
    > PAUSE DELAY
    > HIGH COIL1_2
    > LOW COIL3_4
    > PAUSE DELAY
    > LOW COIL1_2
    > LOW COIL3_4
    > PAUSE DELAY
    > LOW COIL1_2
    > HIGH COIL3_4
    > PAUSE DELAY
    > NEXT
    > END
    > eGroups.com home: http://www.egroups.com/group/basicstamps
    > http://www.egroups.com - Simplifying group communications
    edited 2000-04-13 04:08
    Hi Ray:
    Guess I haven't hooked up my ol'1202A HP o-scope to it, frankly I don't know
    how to interpret a scope reading on a stepper,(more the willing to read
    anything you might comment on here) but with the delay set to 2 I get the
    best performance i.e. seems to get most force, but it skips steps, at other
    delays, say just like 4 or so, or even 30, 35 it skips a lotta steps and
    auto reverses at the slightest actuation force, like if I touch the
    actuator, it will back right up.
    Anyway this thing runs great with the delay set to 2 but I need more
    reliability, no skipped steps.
    I will look into the Slo Syn stepper.
    Also, I had a 15v zener on it, just like the Allegro spec sheet for the
    UND2544B.
    Thanks, no matter how late, I'm just glad I got your post, there been a
    pretty big increase in the number of post recently, though they're all
    pretty interesting.
    Mark
    To: basicstamps@egroups.com <basicstamps@egroups.com>
    Date: Tuesday, April 11, 2000 6:34 PM
    Subject: Re: [noparse][[/noparse]basicstamps] 2 pin BSC2 to stepper
    >Ray McArthur
    >From: techno_masai <plunkettm@e...>
    >> Hi all:
    give
    >> me a holler please.
    >buck
    >this
    >so?
    >> 162587)
    >> 'ORG PIN 8
    >> 'BLK PIN 6
    >> 'BRN PIN 3
    >> 'YEL PIN 1
    >PRINT
    >> CTR VAR WORD
    >> DELAY VAR WORD
    >> STEPS VAR WORD
    >> COIL1_2 CON 0
    >> COIL3_4 CON 1
    >> DELAY = 2
    >> STEPS = 50
    >> 'Retract
    >> LOW COIL1_2
    >> HIGH COIL3_4
    >> PAUSE DELAY
    >> LOW COIL1_2
    >> LOW COIL3_4
    >> PAUSE DELAY
    >> HIGH COIL1_2
    >> LOW COIL3_4
    >> PAUSE DELAY
    >> HIGH COIL1_2
    >> HIGH COIL3_4
    >> PAUSE DELAY
    >> NEXT
    >> 'EXTEND
    >> HIGH COIL1_2
    >> HIGH COIL3_4
    >> PAUSE DELAY
    >> HIGH COIL1_2
    >> LOW COIL3_4
    >> PAUSE DELAY
    >> LOW COIL1_2
    >> LOW COIL3_4
    >> PAUSE DELAY
    >> LOW COIL1_2
    >> HIGH COIL3_4
    >> PAUSE DELAY
    >> NEXT
    >> END
    edited 2000-04-13 05:28
    Mark:
    The behavior you describe is bizarre. Normally, skipped steps occur at
    too-high rates. Could you have the coils connected wrong, or an incorrect
    step? When my code had errors, the motor was quite erratic. I'll check
    your code when we have a chance.
    I just looked at the Jameco catalog... they don't give coil resistance.
    Did you measure it? The steppers I messed with are rotary units, but yours
    simply looks like a rotary stepper with a leadscrew attached, so I would
    expect it to be similar in operation. The Airpax products I have seen were
    decent quality.
    Ray
    Sent: Wednesday, April 12, 2000 11:08 PM
    > Hi Ray:
    know
    other
    > UND2544B.
    > pretty interesting.
    > Mark
    > From: rjmca <rjmca@w...>
    Airpax.
    a
    high
    that
    a
    > >Ray McArthur
    > >> Hi all:
    > give
    > >> me a holler please.
    > >buck
    > >this
    > >so?
    > >> 162587)
    > >> 'ORG PIN 8
    > >> 'BLK PIN 6
    > >> 'BRN PIN 3
    > >> 'YEL PIN 1
    > >PRINT
    > >> CTR VAR WORD
    > >> DELAY VAR WORD
    > >> STEPS VAR WORD
    > >> COIL1_2 CON 0
    > >> COIL3_4 CON 1
    > >> DELAY = 2
    > >> STEPS = 50
    > >> 'Retract
    > >> LOW COIL1_2
    > >> HIGH COIL3_4
    > >> PAUSE DELAY
    > >> LOW COIL1_2
    > >> LOW COIL3_4
    > >> PAUSE DELAY
    > >> HIGH COIL1_2
    > >> LOW COIL3_4
    > >> PAUSE DELAY
    > >> HIGH COIL1_2
    > >> HIGH COIL3_4
    > >> PAUSE DELAY
    > >> NEXT
    > >> 'EXTEND
    > >> HIGH COIL1_2
    > >> HIGH COIL3_4
    > >> PAUSE DELAY
    > >> HIGH COIL1_2
    > >> LOW COIL3_4
    > >> PAUSE DELAY
    > >> LOW COIL1_2
    > >> LOW COIL3_4
    > >> PAUSE DELAY
    > >> LOW COIL1_2
    > >> HIGH COIL3_4
    > >> PAUSE DELAY
    > >> NEXT
    > >> END
    edited 2000-04-13 17:41
    At 08:08 PM 4/12/00 -0700, techno_masai promulgated:
    [noparse][[/noparse]Apologies to all for the length of this post, but I felt the
    information important to many Stampers - due to the fairly
    recent availability of linear actuators in the surplus catalogs,
    here in the US]
    Mark and Ray:
    Sorry for my "delayed" response as well. Either my ISP or the eGroups mail
    monster ate my earlier reply to this 'thread' <sigh>.
    You might take a look at this reference Mark and confirm a recollection I
    have -
    [noparse][[/noparse] http://www.thomsonmotors.com/airpax/airpax.htm ] in the center picture
    labelled
    " Value Added Products - "
    " Geared Motors and Digital "
    " Linear Actuators "
    and take a look at the linear actuator at the bottom of the picture -
    center of
    the frame. If that is what the Jameco (Airpax) linear actuator looks like,
    you
    may want to continue with that lead and this note. If so,
    The Thomson Industries (Airpax) series numbers are:
    K92100 and L92100 and are called "Digital Linear Actuators"
    Although there is no document number on the literature I personally have
    before me, the title/ref is:
    "Product Selection and Engineering Guide", Thomson (Airpax Mechatronics),
    Thomson Industries, 7 McKee Place, Port Washington, NY, 11050, USA;
    1-203-271-6400; www.thomsonmotors.com
    and
    WWW: www.thomsonindustries.com (US HQ Corporate Site)
    E-Mail: litrequest@t... US Toll-Free 1-800-554-8466
    Literature Req. No. 12-01-000-6001 US Fax 1-800-445-0329
    or 1-516-883-9039 Int'l
    Other E-Mail: GB/Europe info@t... ASIA airpax@t...
    It can be obtained by download from that same website noted above
    [noparse][[/noparse] www.thomsonmotors.com/airpax ] in the Catalog Section, or apparently by
    requesting Literature No. 12-01-000-6001 by e-mail (see refs above);
    various torque curves are shown there as well.
    Personally, I think this piece of literature is a (device specific) "must
    have",
    and I obtained mine by Snail Mail - some time ago. Whether it can be
    ordered like
    that today, I don't know for sure. An inquiry at the website might
    determine that.
    The reason I view it as a "must have" is from the pov that there is very
    little
    in the way of documentation on linear actuators (in general), and it has
    been my experience that most of the units available (new, surplus,
    liquidated, etc) seem
    to be (at least similar) to those listed in this Thomson (Airpax) catalog.
    There is a more important reason yet - if one looks closely at the
    documentation (I can't speak for the download, although I would hope it
    would concur), one comes to realization that these must be driven as
    UNI-POLAR steppers would be driven. This
    ties us back to the original question <whew !>.
    The Allegro Chip mentioned is for BI-POLAR Steppers. At this juncture the
    best recommendation I could make, would be to hold on to the Allegro chip
    for some
    future adventure with BI-POLAR steppers, and wander over the the E-Lab site:
    [noparse][[/noparse] www.elab.com ] and take a look at their EDE-1200 Uni-Polar Stepper ASIC
    Chip.
    Why ?
    In truth any UNI-POLAR stepper drive chip might do, from scads of
    manufacturers.
    It would be my guess that some additional torque insight might be required,
    however, and the quickest route I know to FIRST-HAND information is via
    E-Labs and the Prez. there, Todd Peterson [noparse][[/noparse]EMAIL: "Todd Peterson"
    <toddp@e...> ] who is kind
    enough to monitor this list.
    Perhaps Elabs might take this on as a small documentation side-project
    (hint, hint),
    at some future date. There is additional information I would be happy to
    offer for reference. An Elabs EDE-1200 App Note regarding (Airpax) Linear
    Actuators, relative
    to microprocessors in general, and the Stamp family in specific would be
    MOST welcome by all, I'm sure (least *I* would love to have one <smile>).
    The additional specific topic(s) of "torque" + "UN-POLAR" + "EDE-1200" (or
    other
    chips) might be a topic for a brief E.E. "White Paper" (as are becoming so
    popular today on niche subjects <weird !>). YMMV on that one.
    The tenative and general conclusions I have reached from what I've read, and
    what I've learned thru experimetation - are:
    FULL, HALF, and MICRO-STEPPING methods are available from UNI-POLAR drive
    chips,
    and torque curves will vary accordingly. More than that, gearing may be
    required, depending on the application. Actuators aren't generally
    appropriate for use in
    stepper motor applications, but stepper motors (to an extent) might be used
    like
    a linear actuator (Acme/ball screw drive and helix shaft). Individual
    applications
    may vary from that general premise.
    Generally SLO SYN (type and brand) motors are expensive (even surplus) but
    sometimes they are quite necessary; again, depending on the application.
    If the Airpax unit is the one I suspect it is - it is intended for LIGHT
    DUTY application ONLY. Low cost, light loads and like factors are
    consistant with these Airpax (surplus) units.
    Hope that helps.
    Bruce
    >Hi Ray:
    >UND2544B.
    >pretty interesting.
    >Mark
    >>Ray McArthur
    >>> Hi all:
    >give
    >>> me a holler please.
    >>buck
    >>this
    >>so?
    >>> 162587)
    >>> 'ORG PIN 8
    >>> 'BLK PIN 6
    >>> 'BRN PIN 3
    >>> 'YEL PIN 1
    >>PRINT
    >>> CTR VAR WORD
    >>> DELAY VAR WORD
    >>> STEPS VAR WORD
    >>> COIL1_2 CON 0
    >>> COIL3_4 CON 1
    >>> DELAY = 2
    >>> STEPS = 50
    >>> 'Retract
    >>> LOW COIL1_2
    >>> HIGH COIL3_4
    >>> PAUSE DELAY
    >>> LOW COIL1_2
    >>> LOW COIL3_4
    >>> PAUSE DELAY
    >>> HIGH COIL1_2
    >>> LOW COIL3_4
    >>> PAUSE DELAY
    >>> HIGH COIL1_2
    >>> HIGH COIL3_4
    >>> PAUSE DELAY
    >>> NEXT
    >>> 'EXTEND
    >>> HIGH COIL1_2
    >>> HIGH COIL3_4
    >>> PAUSE DELAY
    >>> HIGH COIL1_2
    >>> LOW COIL3_4
    >>> PAUSE DELAY
    >>> LOW COIL1_2
    >>> LOW COIL3_4
    >>> PAUSE DELAY
    >>> LOW COIL1_2
    >>> HIGH COIL3_4
    >>> PAUSE DELAY
    >>> NEXT
    >>> END
    edited 2000-04-13 22:23
    Mark:
    I just looked at your code and may have found a problem. Assuming your
    motor color codes follow the Airpax codes shown on page 101 of the V1.9
    manual, and the wires are connected as you say in your code comments, the
    coil phases are incorrect. They should be:
    red & green to positive
    yellow to UDN pin 1
    orange to pin 3
    brown to pin 8
    black to pin 6
    The code looks OK, except you will get a "glitch" when backing up. You can
    greatly abbreviate the code you are using by using LOOKUP as in the stamp
    manual, page 43.
    Good luck,
    Ray McArthur
    Sent: Thursday, April 13, 2000 12:28 AM
    > Mark:
    yours
    were
    > decent quality.
    > Ray
    > > Hi Ray:
    > know
    the
    > other
    > > UND2544B.
    > > pretty interesting.
    > > Mark
    in
    > Airpax.
    torque
    coil
    high
    > a
    > high
    > that
    by
    > a
    > > >Ray McArthur
    > > >> Hi all:
    > > give
    > > >> me a holler please.
    $9
    > > >buck
    on
    > > >this
    > > >so?
    P/N
    > > >> 162587)
    > > >> 'ORG PIN 8
    > > >> 'BLK PIN 6
    > > >> 'BRN PIN 3
    > > >> 'YEL PIN 1
    WON'T
    > > >PRINT
    > > >> CTR VAR WORD
    > > >> DELAY VAR WORD
    > > >> STEPS VAR WORD
    > > >> COIL1_2 CON 0
    > > >> COIL3_4 CON 1
    > > >> DELAY = 2
    > > >> STEPS = 50
    > > >> 'Retract
    > > >> LOW COIL1_2
    > > >> HIGH COIL3_4
    > > >> PAUSE DELAY
    > > >> LOW COIL1_2
    > > >> LOW COIL3_4
    > > >> PAUSE DELAY
    > > >> HIGH COIL1_2
    > > >> LOW COIL3_4
    > > >> PAUSE DELAY
    > > >> HIGH COIL1_2
    > > >> HIGH COIL3_4
    > > >> PAUSE DELAY
    > > >> NEXT
    > > >> 'EXTEND
    > > >> HIGH COIL1_2
    > > >> HIGH COIL3_4
    > > >> PAUSE DELAY
    > > >> HIGH COIL1_2
    > > >> LOW COIL3_4
    > > >> PAUSE DELAY
    > > >> LOW COIL1_2
    > > >> LOW COIL3_4
    > > >> PAUSE DELAY
    > > >> LOW COIL1_2
    > > >> HIGH COIL3_4
    > > >> PAUSE DELAY
    > > >> NEXT
    > > >> END
    edited 2000-04-14 22:21
    Hi Ray:
    Thanks for looking over my code and hook up, seems like I went thru every
    permutation on the wiring from the UDN to the AirPax, but will check what
    you suggested.
    On the Airpax from Jameco, both the positive wires are red, I connected them
    together to 12v. I ran a zener 2EZ15D5MSCT from the same 12v with the zigzag
    end pointing to the UDN and ran it to pins 2 and 7.
    Am planning on using the look up table once I get the Airpax up and running
    decently.
    The resistance between the brn & org is 115 ohms, between the brn & red its
    59 ohms, between the brn & the other red(no green wire on this Airpax unit)
    is 0.
    Per Al Williams book I though I had it figured out.
    Mark
    Date: Thursday, April 13, 2000 2:23 PM
    >Mark:
    >yellow to UDN pin 1
    >orange to pin 3
    >brown to pin 8
    >black to pin 6
    >manual, page 43.
    >Good luck,
    >Ray McArthur
    >> Mark:
    incorrect
    >yours
    >were
    >> decent quality.
    >> Ray
    >> > Hi Ray:
    >> know
    >the
    >> other
    and
    >> > UND2544B.
    >> > pretty interesting.
    >> > Mark
    >in
    >> Airpax.
    >torque
    >coil
    >high
    >> a
    >> high
    >> that
    >by
    >> a
    >> > >Ray McArthur
    >> > >> Hi all:
    actuators
    >> > give
    >> > >> me a holler please.
    >$9
    >> > >buck
    >on
    >> > >this
    >or
    >> > >so?
    >P/N
    >> > >> 162587)
    >> > >> 'ORG PIN 8
    >> > >> 'BLK PIN 6
    >> > >> 'BRN PIN 3
    >> > >> 'YEL PIN 1
    >WON'T
    >> > >PRINT
    >> > >> CTR VAR WORD
    >> > >> DELAY VAR WORD
    >> > >> STEPS VAR WORD
    >> > >> COIL1_2 CON 0
    >> > >> COIL3_4 CON 1
    >> > >> DELAY = 2
    >> > >> STEPS = 50
    >> > >> 'Retract
    >> > >> LOW COIL1_2
    >> > >> HIGH COIL3_4
    >> > >> PAUSE DELAY
    >> > >> LOW COIL1_2
    >> > >> LOW COIL3_4
    >> > >> PAUSE DELAY
    >> > >> HIGH COIL1_2
    >> > >> LOW COIL3_4
    >> > >> PAUSE DELAY
    >> > >> HIGH COIL1_2
    >> > >> HIGH COIL3_4
    >> > >> PAUSE DELAY
    >> > >> NEXT
    >> > >> 'EXTEND
    >> > >> HIGH COIL1_2
    >> > >> HIGH COIL3_4
    >> > >> PAUSE DELAY
    >> > >> HIGH COIL1_2
    >> > >> LOW COIL3_4
    >> > >> PAUSE DELAY
    >> > >> LOW COIL1_2
    >> > >> LOW COIL3_4
    >> > >> PAUSE DELAY
    >> > >> LOW COIL1_2
    >> > >> HIGH COIL3_4
    >> > >> PAUSE DELAY
    >> > >> NEXT
    >> > >> END
    edited 2000-04-14 22:45
    Hi Bruce:
    Thanks for the detailed post, all very interesting and great stuff.
    I guess what threw me off on the UDN2544 was that on the Allegro spec sheet
    front page under Features it says "Inputs configured for Unipolar Stepper
    Motors", so I guess you can drive a bipolar stepper with unipolar inputs?
    Will check out the links you posted, especially on the EDE-1200 Uni-Polar
    Stepper ASIC
    I look forward to checking out their EDE-1200 App Note regarding (Airpax)
    Linear Actuators big time.
    Have you worked at all with digital encoders from US Digital, that will be
    probably the next thing I'll be tackling once I get the Airpax up and
    running.
    Mark
    Cc: Todd Peterson <toddp@e...>
    Date: Thursday, April 13, 2000 9:49 AM
    Subject: Re: [noparse][[/noparse]basicstamps] [noparse][[/noparse]long] 2 pin BSC2 to stepper
    > here in the US]
    >Mark and Ray:
    >have -
    >labelled
    >center of
    >you
    >and
    >have",
    >ordered like
    >determine that.
    >little
    >for some
    site:
    >Chip.
    >Why ?
    >manufacturers.
    >(hint, hint),
    >Actuators, relative
    >other
    and
    >chips,
    >like
    >applications
    >Hope that helps.
    >Regards,
    >Bruce
    >>Hi Ray:
    know
    other
    >>UND2544B.
    >>pretty interesting.
    >>Mark
    Airpax.
    a
    high
    that
    a
    >>>Ray McArthur
    >>>> Hi all:
    >>give
    >>>> me a holler please.
    >>>buck
    >>>this
    >>>so?
    >>>> 162587)
    >>>> 'ORG PIN 8
    >>>> 'BLK PIN 6
    >>>> 'BRN PIN 3
    >>>> 'YEL PIN 1
    >>>PRINT
    >>>> CTR VAR WORD
    >>>> DELAY VAR WORD
    >>>> STEPS VAR WORD
    >>>> COIL1_2 CON 0
    >>>> COIL3_4 CON 1
    >>>> DELAY = 2
    >>>> STEPS = 50
    >>>> 'Retract
    >>>> LOW COIL1_2
    >>>> HIGH COIL3_4
    >>>> PAUSE DELAY
    >>>> LOW COIL1_2
    >>>> LOW COIL3_4
    >>>> PAUSE DELAY
    >>>> HIGH COIL1_2
    >>>> LOW COIL3_4
    >>>> PAUSE DELAY
    >>>> HIGH COIL1_2
    >>>> HIGH COIL3_4
    >>>> PAUSE DELAY
    >>>> NEXT
    >>>> 'EXTEND
    >>>> HIGH COIL1_2
    >>>> HIGH COIL3_4
    >>>> PAUSE DELAY
    >>>> HIGH COIL1_2
    >>>> LOW COIL3_4
    >>>> PAUSE DELAY
    >>>> LOW COIL1_2
    >>>> LOW COIL3_4
    >>>> PAUSE DELAY
    >>>> LOW COIL1_2
    >>>> HIGH COIL3_4
    >>>> PAUSE DELAY
    >>>> NEXT
    >>>> END
    edited 2000-04-14 22:53
    Mark:
    Your wire colors are different than I thought. Could you give me a list of
    all the wire colors and resistance readings between them? I am interested
    in your project because I am considering buying one of those steppers.
    Ray McArthur
    Sent: Friday, April 14, 2000 5:21 PM
    > Hi Ray:
    > you suggested.
    them
    zigzag
    running
    > decently.
    its
    unit)
    > is 0.
    > Mark
    > >Mark:
    > >yellow to UDN pin 1
    > >orange to pin 3
    > >brown to pin 8
    > >black to pin 6
    can
    > >manual, page 43.
    > >Good luck,
    > >Ray McArthur
    > >> Mark:
    > incorrect
    check
    resistance.
    > >yours
    would
    > >were
    > >> decent quality.
    > >> Ray
    > >> > Hi Ray:
    don't
    > >> know
    read
    > >the
    > >> other
    > and
    the
    > >> > UND2544B.
    a
    all
    > >> > pretty interesting.
    > >> > Mark
    delay=2
    > >in
    > >> Airpax.
    > >torque
    > >coil
    > >high
    > >> a
    at
    > >> high
    bet
    > >> that
    somewhat
    > >by
    > >> a
    > >> > >Ray McArthur
    > >> > >> Hi all:
    > actuators
    > >> > give
    > >> > >> me a holler please.
    low
    > >$9
    > >> > >buck
    back
    > >on
    > >> > >this
    LBF
    > >or
    > >> > >so?
    (JAMECO
    > >P/N
    > >> > >> 162587)
    > >> > >> 'ORG PIN 8
    > >> > >> 'BLK PIN 6
    > >> > >> 'BRN PIN 3
    > >> > >> 'YEL PIN 1
    > >WON'T
    > >> > >PRINT
    > >> > >> CTR VAR WORD
    > >> > >> DELAY VAR WORD
    > >> > >> STEPS VAR WORD
    > >> > >> COIL1_2 CON 0
    > >> > >> COIL3_4 CON 1
    > >> > >> DELAY = 2
    > >> > >> STEPS = 50
    > >> > >> 'Retract
    > >> > >> LOW COIL1_2
    > >> > >> HIGH COIL3_4
    > >> > >> PAUSE DELAY
    > >> > >> LOW COIL1_2
    > >> > >> LOW COIL3_4
    > >> > >> PAUSE DELAY
    > >> > >> HIGH COIL1_2
    > >> > >> LOW COIL3_4
    > >> > >> PAUSE DELAY
    > >> > >> HIGH COIL1_2
    > >> > >> HIGH COIL3_4
    > >> > >> PAUSE DELAY
    > >> > >> NEXT
    > >> > >> 'EXTEND
    > >> > >> HIGH COIL1_2
    > >> > >> HIGH COIL3_4
    > >> > >> PAUSE DELAY
    > >> > >> HIGH COIL1_2
    > >> > >> LOW COIL3_4
    > >> > >> PAUSE DELAY
    > >> > >> LOW COIL1_2
    > >> > >> LOW COIL3_4
    > >> > >> PAUSE DELAY
    > >> > >> LOW COIL1_2
    > >> > >> HIGH COIL3_4
    > >> > >> PAUSE DELAY
    > >> > >> NEXT
    > >> > >> END
    edited 2000-04-14 23:12
    At 02:45 PM 4/14/00 -0700, techno_masai promulgated:
    >Hi Bruce:
    If the truth would be know bi-polar/uni-polar are almost connectivity
    methods, but
    it kinda fails the true test. The direct answer to your question is yes.
    >Stepper ASIC
    You will appreciate the docs (free) and the assistance, I can assure you.
    I surely am in no position except to HINT at something like that <smile>.
    >running.
    Some, but not extensively. I had an application I was going to get involved in
    about 6 months ago, but it never got off the ground. I have the docs
    though, and various "typical" examples of various encoders. I never
    filtered thru it to see if there was one which mentioned the US Digital
    ones. Which encoder were you looking
    to use, and what is the exact application ?
    Bruce
    >Mark
    edited 2000-04-15 01:55
    Mark:
    The UDN 2544 should drive a unipolar stepper if connected as their example
    circuit that you are using. If one of your stamp pins drives UDN pins 9&10,
    and the other stamp pin drives UDN pins 15&16, there should be no problem.
    I have an EDE1200 driving a stepper, and it works fine, but so should your
    UDN.
    Will check out the Airpax site Bruce mentioned, but I think I already have
    it downloaded.
    Ray McArthur
    Sent: Friday, April 14, 2000 5:45 PM
    > Hi Bruce:
    sheet
    > Stepper ASIC
    > running.
    > Mark
    > From: Bruce Bates <bvbates@u...>
    > > here in the US]
    > >Mark and Ray:
    mail
    > >have -
    > >labelled
    > >center of
    like,
    > >you
    > >and
    > >have",
    > >ordered like
    > >determine that.
    > >little
    catalog.
    > >for some
    > site:
    > >Chip.
    > >Why ?
    > >manufacturers.
    required,
    > >(hint, hint),
    > >Actuators, relative
    (or
    > >other
    so
    > and
    > >chips,
    used
    > >like
    > >applications
    but
    > >Hope that helps.
    > >Regards,
    > >Bruce
    > >>Hi Ray:
    > know
    the
    > other
    > >>UND2544B.
    > >>pretty interesting.
    > >>Mark
    in
    > Airpax.
    torque
    coil
    high
    > a
    > high
    > that
    by
    > a
    > >>>Ray McArthur
    > >>>> Hi all:
    > >>give
    > >>>> me a holler please.
    $9
    > >>>buck
    on
    > >>>this
    > >>>so?
    P/N
    > >>>> 162587)
    > >>>> 'ORG PIN 8
    > >>>> 'BLK PIN 6
    > >>>> 'BRN PIN 3
    > >>>> 'YEL PIN 1
    WON'T
    > >>>PRINT
    > >>>> CTR VAR WORD
    > >>>> DELAY VAR WORD
    > >>>> STEPS VAR WORD
    > >>>> COIL1_2 CON 0
    > >>>> COIL3_4 CON 1
    > >>>> DELAY = 2
    > >>>> STEPS = 50
    > >>>> 'Retract
    > >>>> LOW COIL1_2
    > >>>> HIGH COIL3_4
    > >>>> PAUSE DELAY
    > >>>> LOW COIL1_2
    > >>>> LOW COIL3_4
    > >>>> PAUSE DELAY
    > >>>> HIGH COIL1_2
    > >>>> LOW COIL3_4
    > >>>> PAUSE DELAY
    > >>>> HIGH COIL1_2
    > >>>> HIGH COIL3_4
    > >>>> PAUSE DELAY
    > >>>> NEXT
    > >>>> 'EXTEND
    > >>>> HIGH COIL1_2
    > >>>> HIGH COIL3_4
    > >>>> PAUSE DELAY
    > >>>> HIGH COIL1_2
    > >>>> LOW COIL3_4
    > >>>> PAUSE DELAY
    > >>>> LOW COIL1_2
    > >>>> LOW COIL3_4
    > >>>> PAUSE DELAY
    > >>>> LOW COIL1_2
    > >>>> HIGH COIL3_4
    > >>>> PAUSE DELAY
    > >>>> NEXT
    > >>>> END
    edited 2000-04-15 03:50
    Sure Ray:
    Here's what I got:
    red-red1 0
    yel-org 0
    yel-red 59
    yel-red1 0
    yel-blk 120
    yel-brn 0
    org-brn 116
    org-red 0
    org-red1 57
    org-brn 116
    org-blk 0
    brn-red 0
    brn-red1 59
    brn-blk 0
    blk-red1 0
    blk-red 60
    Hope I got them all. I arbitrarily called one of the two identical red wires
    red1.
    The label on this Airpax stepper linear actuator has these numbers A92218,
    8232
    Hope to hear about your luck with these linear actuators.
    Mark
    Date: Friday, April 14, 2000 2:53 PM
    >Mark:
    >Thanks,
    >Ray McArthur
    >> Hi Ray:
    >> you suggested.
    >them
    >zigzag
    >running
    >> decently.
    >its
    >unit)
    >> is 0.
    >> Mark
    >> >Mark:
    the
    >> >yellow to UDN pin 1
    >> >orange to pin 3
    >> >brown to pin 8
    >> >black to pin 6
    >can
    stamp
    >> >manual, page 43.
    >> >Good luck,
    >> >Ray McArthur
    >> >> Mark:
    at
    >> incorrect
    >check
    >resistance.
    >> >yours
    >would
    >> >were
    >> >> decent quality.
    >> >> Ray
    >> >> > Hi Ray:
    >don't
    >> >> know
    >read
    get
    >> >the
    at
    >> >> other
    >> and
    >the
    >> >> > UND2544B.
    been
    >a
    >all
    >> >> > pretty interesting.
    >> >> > Mark
    >delay=2
    >> >in
    >> >> Airpax.
    >> >torque
    >> >coil
    >> >high
    >> >> a
    >at
    >> >> high
    >bet
    >> >> that
    >somewhat
    >> >by
    >> >> a
    >> >> > >Ray McArthur
    >> >> > >> Hi all:
    >> actuators
    >> >> > give
    >> >> > >> me a holler please.
    >low
    >> >$9
    >> >> > >buck
    >back
    >> >on
    >> >> > >this
    >LBF
    >> >or
    >> >> > >so?
    >(JAMECO
    >> >P/N
    >> >> > >> 162587)
    >> >> > >> 'ORG PIN 8
    >> >> > >> 'BLK PIN 6
    >> >> > >> 'BRN PIN 3
    >> >> > >> 'YEL PIN 1
    >> >WON'T
    >> >> > >PRINT
    >> >> > >> CTR VAR WORD
    >> >> > >> DELAY VAR WORD
    >> >> > >> STEPS VAR WORD
    >> >> > >> COIL1_2 CON 0
    >> >> > >> COIL3_4 CON 1
    >> >> > >> DELAY = 2
    >> >> > >> STEPS = 50
    >> >> > >> 'Retract
    >> >> > >> LOW COIL1_2
    >> >> > >> HIGH COIL3_4
    >> >> > >> PAUSE DELAY
    >> >> > >> LOW COIL1_2
    >> >> > >> LOW COIL3_4
    >> >> > >> PAUSE DELAY
    >> >> > >> HIGH COIL1_2
    >> >> > >> LOW COIL3_4
    >> >> > >> PAUSE DELAY
    >> >> > >> HIGH COIL1_2
    >> >> > >> HIGH COIL3_4
    >> >> > >> PAUSE DELAY
    >> >> > >> NEXT
    >> >> > >> 'EXTEND
    >> >> > >> HIGH COIL1_2
    >> >> > >> HIGH COIL3_4
    >> >> > >> PAUSE DELAY
    >> >> > >> HIGH COIL1_2
    >> >> > >> LOW COIL3_4
    >> >> > >> PAUSE DELAY
    >> >> > >> LOW COIL1_2
    >> >> > >> LOW COIL3_4
    >> >> > >> PAUSE DELAY
    >> >> > >> LOW COIL1_2
    >> >> > >> HIGH COIL3_4
    >> >> > >> PAUSE DELAY
    >> >> > >> NEXT
    >> >> > >> END
    edited 2000-04-15 04:34
    Mark:
    Thanks for the info. From your readings, you should try:
    * both reds to plus, like you have.
    * brown to UDN pin 3.
    * orange to pin 1.
    * yellow to pin 8.
    * black to pin 6.
    Don' forget to try longer delays, like 40 if it's weird.
    Let me know how you make out,
    Ray McArthur
    Sent: Friday, April 14, 2000 10:50 PM
    > Sure Ray:
    > Here's what I got:
    > red-red1 0
    > yel-org 0
    > yel-red 59
    > yel-red1 0
    > yel-blk 120
    > yel-brn 0
    > org-brn 116
    > org-red 0
    > org-red1 57
    > org-brn 116
    > org-blk 0
    > brn-red 0
    > brn-red1 59
    > brn-blk 0
    > blk-red1 0
    > blk-red 60
    wires
    > red1.
    > 8232
    > Mark
    > >Mark:
    of
    interested
    > >Thanks,
    > >Ray McArthur
    > >> Hi Ray:
    every
    what
    > >> you suggested.
    > >them
    > >zigzag
    > >running
    > >> decently.
    > >its
    > >unit)
    > >> is 0.
    > >> Mark
    > >> >Mark:
    your
    V1.9
    > the
    > >> >yellow to UDN pin 1
    > >> >orange to pin 3
    > >> >brown to pin 8
    > >> >black to pin 6
    You
    > >can
    > stamp
    > >> >manual, page 43.
    > >> >Good luck,
    > >> >Ray McArthur
    > >> >> Mark:
    > at
    > >> incorrect
    > >check
    > >resistance.
    but
    > >> >yours
    > >would
    seen
    > >> >were
    > >> >> decent quality.
    > >> >> Ray
    > >> >> > Hi Ray:
    > >don't
    > >> >> know
    > >read
    > get
    > >> >the
    > at
    > >> >> other
    steps
    > >> and
    the
    more
    for
    > >the
    > >> >> > UND2544B.
    > been
    > >a
    > >all
    > >> >> > pretty interesting.
    > >> >> > Mark
    > >delay=2
    > >> >in
    from
    > >> >> Airpax.
    > >> >torque
    that
    > >> >coil
    too
    > >> >high
    > >> >> a
    torque
    > >at
    > >> >> high
    will
    > >bet
    > >> >> that
    > >somewhat
    > >> >by
    > >> >> a
    > >> >> > >Ray McArthur
    > >> >> > >> Hi all:
    > >> actuators
    > >> >> > give
    > >> >> > >> me a holler please.
    > >low
    > >> >$9
    > >> >> > >buck
    > >back
    > >> >on
    > >> >> > >this
    1
    > >LBF
    > >> >or
    > >> >> > >so?
    > >(JAMECO
    > >> >P/N
    > >> >> > >> 162587)
    > >> >> > >> 'ORG PIN 8
    > >> >> > >> 'BLK PIN 6
    > >> >> > >> 'BRN PIN 3
    > >> >> > >> 'YEL PIN 1
    IT
    > >> >WON'T
    > >> >> > >PRINT
    > >> >> > >> CTR VAR WORD
    > >> >> > >> DELAY VAR WORD
    > >> >> > >> STEPS VAR WORD
    > >> >> > >> COIL1_2 CON 0
    > >> >> > >> COIL3_4 CON 1
    > >> >> > >> DELAY = 2
    > >> >> > >> STEPS = 50
    > >> >> > >> 'Retract
    > >> >> > >> LOW COIL1_2
    > >> >> > >> HIGH COIL3_4
    > >> >> > >> PAUSE DELAY
    > >> >> > >> LOW COIL1_2
    > >> >> > >> LOW COIL3_4
    > >> >> > >> PAUSE DELAY
    > >> >> > >> HIGH COIL1_2
    > >> >> > >> LOW COIL3_4
    > >> >> > >> PAUSE DELAY
    > >> >> > >> HIGH COIL1_2
    > >> >> > >> HIGH COIL3_4
    > >> >> > >> PAUSE DELAY
    > >> >> > >> NEXT
    > >> >> > >> 'EXTEND
    > >> >> > >> HIGH COIL1_2
    > >> >> > >> HIGH COIL3_4
    > >> >> > >> PAUSE DELAY
    > >> >> > >> HIGH COIL1_2
    > >> >> > >> LOW COIL3_4
    > >> >> > >> PAUSE DELAY
    > >> >> > >> LOW COIL1_2
    > >> >> > >> LOW COIL3_4
    > >> >> > >> PAUSE DELAY
    > >> >> > >> LOW COIL1_2
    > >> >> > >> HIGH COIL3_4
    > >> >> > >> PAUSE DELAY
    > >> >> > >> NEXT
    > >> >> > >> END
    edited 2000-04-15 06:43
    At 08:55 PM 4/14/00 -0400, rjmca promulgated:
    >Mark:
    >UDN.
    >it downloaded.
    Just as a matter of clarification, my comments were relative to the Jameco
    Airpax actuator unit, and ONLY if it's the same unit as pictured on the
    Thomson Mechatronics website.
    Bruce
    >Thanks,
    >Ray McArthur
    >> Hi Bruce:
    >sheet
    >> Stepper ASIC
    >> running.
    >> Mark
    >> > here in the US]
    >> >Mark and Ray:
    >mail
    >> >have -
    >> >labelled
    >> >center of
    >like,
    >> >you
    >> >and
    >> >have",
    >> >ordered like
    >> >determine that.
    >> >little
    >catalog.
    >> >for some
    >> site:
    >> >Chip.
    >> >Why ?
    >> >manufacturers.
    >required,
    >> >(hint, hint),
    >> >Actuators, relative
    >(or
    >> >other
    >so
    >> and
    >> >chips,
    >used
    >> >like
    >> >applications
    >but
    >> >Hope that helps.
    >> >Regards,
    >> >Bruce
    >> >>Hi Ray:
    >> know
    >the
    >> other
    >> >>UND2544B.
    >> >>pretty interesting.
    >> >>Mark
    >in
    >> Airpax.
    >torque
    >coil
    >high
    >> a
    >> high
    >> that
    >by
    >> a
    >> >>>Ray McArthur
    >> >>>> Hi all:
    >> >>give
    >> >>>> me a holler please.
    >$9
    >> >>>buck
    >on
    >> >>>this
    >or
    >> >>>so?
    >P/N
    >> >>>> 162587)
    >> >>>> 'ORG PIN 8
    >> >>>> 'BLK PIN 6
    >> >>>> 'BRN PIN 3
    >> >>>> 'YEL PIN 1
    >WON'T
    >> >>>PRINT
    >> >>>> CTR VAR WORD
    >> >>>> DELAY VAR WORD
    >> >>>> STEPS VAR WORD
    >> >>>> COIL1_2 CON 0
    >> >>>> COIL3_4 CON 1
    >> >>>> DELAY = 2
    >> >>>> STEPS = 50
    >> >>>> 'Retract
    >> >>>> LOW COIL1_2
    >> >>>> HIGH COIL3_4
    >> >>>> PAUSE DELAY
    >> >>>> LOW COIL1_2
    >> >>>> LOW COIL3_4
    >> >>>> PAUSE DELAY
    >> >>>> HIGH COIL1_2
    >> >>>> LOW COIL3_4
    >> >>>> PAUSE DELAY
    >> >>>> HIGH COIL1_2
    >> >>>> HIGH COIL3_4
    >> >>>> PAUSE DELAY
    >> >>>> NEXT
    >> >>>> 'EXTEND
    >> >>>> HIGH COIL1_2
    >> >>>> HIGH COIL3_4
    >> >>>> PAUSE DELAY
    >> >>>> HIGH COIL1_2
    >> >>>> LOW COIL3_4
    >> >>>> PAUSE DELAY
    >> >>>> LOW COIL1_2
    >> >>>> LOW COIL3_4
    >> >>>> PAUSE DELAY
    >> >>>> LOW COIL1_2
    >> >>>> HIGH COIL3_4
    >> >>>> PAUSE DELAY
    >> >>>> NEXT
    >> >>>> END
    edited 2000-04-15 06:59
    Ray:
    Wow, that was it, thing runs like a charm now, thank you very much!
    Darn and I must have gone thru that combo at least once, I'm not sure how I
    missed it.
    Funny thing is that it runs really fast and snappy at delay = 2 too, and
    like you said runs great at 40.
    Dogone this thing is neat now!
    Saw your post on the VFD, haven't worked on serial connections to these
    either, but there must be a Register Select command to get your characters
    into the 2nd 8 characters on the display, as you more than likely know its
    like %11000000 on the parallel driven Optrex.
    Guess I'm trying to offer up some probably rather pathetic help here since
    I'm pretty indebted to your assistance Ray.
    Thanks again,
    Mark
    Date: Friday, April 14, 2000 8:33 PM
    >Mark:
    >* orange to pin 1.
    >* yellow to pin 8.
    >* black to pin 6.
    >Ray McArthur
    >> Sure Ray:
    >> Here's what I got:
    >> red-red1 0
    >> yel-org 0
    >> yel-red 59
    >> yel-red1 0
    >> yel-blk 120
    >> yel-brn 0
    >> org-brn 116
    >> org-red 0
    >> org-red1 57
    >> org-brn 116
    >> org-blk 0
    >> brn-red 0
    >> brn-red1 59
    >> brn-blk 0
    >> blk-red1 0
    >> blk-red 60
    >wires
    >> red1.
    A92218,
    >> 8232
    >> Mark
    >> >Mark:
    >of
    >interested
    >> >Thanks,
    >> >Ray McArthur
    >> >> Hi Ray:
    >every
    >what
    >> >> you suggested.
    connected
    >> >them
    >> >zigzag
    >> >running
    >> >> decently.
    red
    >> >its
    >> >unit)
    >> >> is 0.
    >> >> Mark
    >> >> >Mark:
    >your
    >V1.9
    >> the
    >> >> >yellow to UDN pin 1
    >> >> >orange to pin 3
    >> >> >brown to pin 8
    >> >> >black to pin 6
    >You
    >> >can
    >> stamp
    >> >> >manual, page 43.
    >> >> >Good luck,
    >> >> >Ray McArthur
    >> >> >> Mark:
    occur
    >> at
    >> >> incorrect
    >> >check
    >> >resistance.
    >but
    >> >> >yours
    >> >would
    >seen
    >> >> >were
    >> >> >> decent quality.
    >> >> >> Ray
    >> >> >> > Hi Ray:
    >> >don't
    >> >> >> know
    to
    >> >read
    >> get
    >> >> >the
    steps,
    >> at
    >> >> >> other
    >steps
    >> >> and
    >the
    >more
    >for
    >> >the
    >> >> >> > UND2544B.
    >> been
    >> >a
    they're
    >> >all
    >> >> >> > pretty interesting.
    >> >> >> > Mark
    >> >delay=2
    >> >> >in
    >from
    >> >> >> Airpax.
    cases,
    >> >> >torque
    >that
    >> >> >coil
    >too
    >> >> >high
    >> >> >> a
    >torque
    >> >at
    >> >> >> high
    >will
    >> >bet
    >> >> >> that
    >> >somewhat
    >> >> >by
    >> >> >> a
    >> >> >> > >Ray McArthur
    >> >> >> > >> Hi all:
    >> >> actuators
    >> >> >> > give
    >> >> >> > >> me a holler please.
    the
    >> >low
    >> >> >$9
    >> >> >> > >buck
    feed
    >> >back
    >> >> >on
    >> >> >> > >this
    >1
    >> >LBF
    >> >> >or
    >> >> >> > >so?
    >> >(JAMECO
    >> >> >P/N
    >> >> >> > >> 162587)
    >> >> >> > >> 'ORG PIN 8
    >> >> >> > >> 'BLK PIN 6
    >> >> >> > >> 'BRN PIN 3
    >> >> >> > >> 'YEL PIN 1
    >IT
    >> >> >WON'T
    >> >> >> > >PRINT
    >> >> >> > >> CTR VAR WORD
    >> >> >> > >> DELAY VAR WORD
    >> >> >> > >> STEPS VAR WORD
    >> >> >> > >> COIL1_2 CON 0
    >> >> >> > >> COIL3_4 CON 1
    >> >> >> > >> DELAY = 2
    >> >> >> > >> STEPS = 50
    >> >> >> > >> 'Retract
    >> >> >> > >> LOW COIL1_2
    >> >> >> > >> HIGH COIL3_4
    >> >> >> > >> PAUSE DELAY
    >> >> >> > >> LOW COIL1_2
    >> >> >> > >> LOW COIL3_4
    >> >> >> > >> PAUSE DELAY
    >> >> >> > >> HIGH COIL1_2
    >> >> >> > >> LOW COIL3_4
    >> >> >> > >> PAUSE DELAY
    >> >> >> > >> HIGH COIL1_2
    >> >> >> > >> HIGH COIL3_4
    >> >> >> > >> PAUSE DELAY
    >> >> >> > >> NEXT
    >> >> >> > >> 'EXTEND
    >> >> >> > >> HIGH COIL1_2
    >> >> >> > >> HIGH COIL3_4
    >> >> >> > >> PAUSE DELAY
    >> >> >> > >> HIGH COIL1_2
    >> >> >> > >> LOW COIL3_4
    >> >> >> > >> PAUSE DELAY
    >> >> >> > >> LOW COIL1_2
    >> >> >> > >> LOW COIL3_4
    >> >> >> > >> PAUSE DELAY
    >> >> >> > >> LOW COIL1_2
    >> >> >> > >> HIGH COIL3_4
    >> >> >> > >> PAUSE DELAY
    >> >> >> > >> NEXT
    >> >> >> > >> END
    edited 2000-04-15 22:29
    Mark:
    Glad to hear it's working. How much thrust force does it have? Probably
    more thrust at low speeds. My display is working now using commands
    outlined in Scott Edwards docs, but I still have questions to post.
    Ray McArthur
    Sent: Saturday, April 15, 2000 1:59 AM
    > Ray:
    I
    > missed it.
    > Thanks again,
    > Mark
    > >Mark:
    > >* orange to pin 1.
    > >* yellow to pin 8.
    > >* black to pin 6.
    > >Ray McArthur
    > >> Sure Ray:
    > >> Here's what I got:
    > >> red-red1 0
    > >> yel-org 0
    > >> yel-red 59
    > >> yel-red1 0
    > >> yel-blk 120
    > >> yel-brn 0
    > >> org-brn 116
    > >> org-red 0
    > >> org-red1 57
    > >> org-brn 116
    > >> org-blk 0
    > >> brn-red 0
    > >> brn-red1 59
    > >> brn-blk 0
    > >> blk-red1 0
    > >> blk-red 60
    > >wires
    > >> red1.
    > A92218,
    > >> 8232
    edited 2000-04-16 04:38
    Hi Ray:
    Probably getting a least a couple lbs force, maybe up to around 5, anyway a
    lot more force than I thought could be gotten out of this thing.
    On hold torque, I'm guessing the weak link would be the UND2544 or would the
    coils tend to overheat.
    Guess the UND would be OK since its rated for 1.8A continuous, the Airpax is
    running 12v/60ohms=200mA so seems like a good enough margin there.
    Took apart an old pen plotter I had, the bipolar steppers were very small
    but the power IC's and heat sinks were just huge, so I guess they figure a
    lot of heat build up, and the only loading is moving the pen around.
    Mark
    Date: Saturday, April 15, 2000 2:28 PM
    >Mark:
    >Regards,
    >Ray McArthur
    >> Ray:
    >I
    >> missed it.
    characters
    its
    since
    >> Thanks again,
    >> Mark
    >> >Mark:
    >> >* orange to pin 1.
    >> >* yellow to pin 8.
    >> >* black to pin 6.
    >> >Ray McArthur
    >> >> Sure Ray:
    >> >> Here's what I got:
    >> >> red-red1 0
    >> >> yel-org 0
    >> >> yel-red 59
    >> >> yel-red1 0
    >> >> yel-blk 120
    >> >> yel-brn 0
    >> >> org-brn 116
    >> >> org-red 0
    >> >> org-red1 57
    >> >> org-brn 116
    >> >> org-blk 0
    >> >> brn-red 0
    >> >> brn-red1 59
    >> >> brn-blk 0
    >> >> blk-red1 0
    >> >> blk-red 60
    >> >wires
    >> >> red1.
    >> A92218,
    >> >> 8232
    Sounds good. Guess I'll have to buy one next time we do a Jameco order.
    Ray
    Sent: Saturday, April 15, 2000 11:38 PM
    > Hi Ray:
    a
    the
    is
    > Mark
    > >Mark:
    > >Regards,
    > >Ray McArthur
    > >> Ray:
    how
    > >I
    > >> missed it.
    and
    > characters
    > its
    > since
    > >> Thanks again,
    > >> Mark
    > >> >Mark:
    > >> >* orange to pin 1.
    > >> >* yellow to pin 8.
    > >> >* black to pin 6.
    > >> >Ray McArthur
    > >> >> Sure Ray:
    > >> >> Here's what I got:
    > >> >> red-red1 0
    > >> >> yel-org 0
    > >> >> yel-red 59
    > >> >> yel-red1 0
    > >> >> yel-blk 120
    > >> >> yel-brn 0
    > >> >> org-brn 116
    > >> >> org-red 0
    > >> >> org-red1 57
    > >> >> org-brn 116
    > >> >> org-blk 0
    > >> >> brn-red 0
    > >> >> brn-red1 59
    > >> >> brn-blk 0
    > >> >> blk-red1 0
    > >> >> blk-red 60
    red
    > >> >wires
    > >> >> red1.
    > >> A92218,
    > >> >> 8232
