Circuit for 0-1 amp variable current — Parallax Forums
edited 2000-03-31 03:30 in General Discussion
Hi
I have a proportional valve that requires variable current to operate. At
approximately 800 mA the valve is fully open. It is proportional from approx
0 amps to 800 mA. I want to drive the valve with a pic or stamp.
Can anyone recommend a circuit that a pic or stamp can drive which can output
that range of variable current?
Maybe PWM at a high frequency?
Any help would be great.
Jon
    edited 2000-03-30 07:15
    At 01:09 AM 3/30/00 EST, Phxsys3@a... promulgated:
    >Hi
    output
    >Thanks
    >Jon
    Hi Jon -
    There was an <ahem> seminar on the old stamp list on this very topic <g>.
    I can probably strip it off my own Stamp List archives, and zip it
    for you ???
    I have NO idea what to tell you otherwise, since the off-site Stamp archive
    is quite out-of-date, and I'm not exactly sure of the status of the Parallax
    site, as regards archives.
    Honestly - I haven't even looked at the new Parallax website, I'm sorry to
    say;
    too darned busy. Don't need to for archives when ya keep yer own, though <g>.
    For you, the fee will be reasonable <grin>.
    Lemme know whatch wanna do, kind sir.
    Bruce
    >eGroups.com home: http://www.egroups.com/group/basicstamps
    >http://www.egroups.com - Simplifying group communications
    edited 2000-03-30 20:37
    Jon,
    You might want to check the National Semiconductor data books or web site.
    In App Note 31, there are many op-amp circuits including a current source
    and sink. Also, take a look at the LM675 power op-amp. The data sheet for
    this guy shows a high current source/sink. You could use the PWM output of
    the Stamp w/filter to drive the op-amp of the current source/sink.
    At 01:09 AM 30/3/00 -0500, you wrote:
    >Hi
    >Thanks
    >Jon
    258 Metals Development
    Ames Laboratory
    Iowa State University
    edited 2000-03-30 20:59
    approx
    output
    Hi Jon,
    Here is a classic voltage controlled current sink, 100% PWM at P0 gives
    800ma to the valve.
    Current proportional to %PWM.
    o
    +24 volts
    op-amp | |
    LM358 | valve 0->800ma
    P0--/\/\-o--- |+\ |/----'
    10k | | >--| NPN adequate power
    | ;--|-/ |\>-; or mosfet
    o
    1uf=== /
    | \ 6.25 ohms, 5 watt
    o
    o----Vss
    The stamp can come around once every few seconds to refresh the charge on
    the PWM capacitor.
    --Tracy Allen
    Electronically Monitored Ecosystems
    http://www.emesystems.com
    edited 2000-03-30 21:07
    Thanks for the information
    Jon
    In a message dated 3/30/00 12:41:10 PM US Mountain Standard Time,
    harker@a... writes:
    << Jon,
    the Stamp w/filter to drive the op-amp of the current source/sink >>
    edited 2000-03-31 01:41
    Hi Jon,
    That sounds like a neat valve! Could you tell me the make, model and price
    range?
    Roger
    >approx
    >output
    >Hi Jon,
    >800ma to the valve.
    o
    +24 volts
    > op-amp | |
    o
    > 1uf=== /
    > | \ 6.25 ohms, 5 watt
    o
    o----Vss
    >the PWM capacitor.
    > --Tracy Allen
    Roger Edberg
    rjedberg@c...
    http://www.cruzio.com/~pgraphic
    JON
    I am also interested in this valve. Can you tell me the orfice size along
    with everything below.
    Derek Barger
    >Hi Jon,
    >range?
    >Thanks,
    >Roger
    >>approx
    >>output
    >>Hi Jon,
    >>800ma to the valve.
    o
    +24 volts
    >> op-amp | |
    o
    >> 1uf=== /
    >> | \ 6.25 ohms, 5 watt
    o
    o----Vss
    >>the PWM capacitor.
    >> --Tracy Allen
    >Roger Edberg
    >rjedberg@c...
