ULN2065 to BSC2 — Parallax Forums
ULN2065 to BSC2
edited 2000-03-28 01:08 in General Discussion
Hello all:
BSC app note#6 deals with a ULN2003 to drive a stepper, anyway I ordered a
ULN2065 seems you can get more current out of it and it is listed close by
the 2003, but neophyte that I am didn't realize the pin out and pin names
are kinda different.
So you hook the "B"'s to the stamp, and the "C"'s to the stepper coils?
Where do the "K"s get hooked up?
Also, my reading of the Allegro data sheet suggest that I can skip the
current limit resistors between the '2065 and the BS2.
Gosh, Allegro could really learn a lot by looking at a Burr Brown PDF
datasheet, those things are great.
I've searched up and down the web for the primer hook up schematic but no
luck.
Mark
    edited 2000-03-26 04:41
    I just looked at the Allegro site and agree; they sure could give more app
    notes. You are correct that the "B" s go to stamp pins, and the "C"s go to
    the stepper. The "K" terminals are protection diodes for inductive flyback
    voltage, and would go to the positive supply powering the stepper. It does
    appear from their "simplified" schematic that current limit resistors are
    internal to the chip inputs. However, I like to add some Stamp insurance
    against ULN chip failure, and would still use a small resistor, like 120-150
    ohms. I suspect the ULN has enough gain to afford this resistor.
    If you remember the "suppression diode" discussion on this site that caused
    much complaining, you can add a 40-50V zener between the "K" terminals and
    stepper positive if the motor is too sluggish.
    Good luck,
    Ray McArthur
    To: <basicstamps@egroups.com>
    Sent: Saturday, March 25, 2000 7:40 PM
    Subject: [noparse][[/noparse]basicstamps] ULN2065 to BSC2
    > Hello all:
    > luck.
    > Thanks,
    > Mark
    > eGroups.com Home: http://www.egroups.com/group/basicstamps/
    > http://www.egroups.com - Simplifying group communications
    edited 2000-03-26 07:11
    Thanks once again Ray, #8^]
    So now the way I figure it is that the K terminals are kinda like optional
    terminals you can use if you want to protect against inductive flyback,
    right?
    Trouble is there's only 2 "K"'s on this thing vs 4 "C"s.
    Mark
    inal Message
    To: basicstamps@egroups.com <basicstamps@egroups.com>
    Date: Saturday, March 25, 2000 8:47 PM
    Subject: [noparse][[/noparse]basicstamps] Re: ULN2065 to BSC2
    does
    120-150
    >Good luck,
    >Ray McArthur
    >From: techno_masai <plunkettm@e...>
    >> Hello all:
    a
    by
    >> luck.
    >> Thanks,
    >> Mark
    >-- 20 megs of disk space in your group's Document Vault
    >-- http://www.egroups.com/docvault/basicstamps/?m=1
    edited 2000-03-26 07:39
    Mark:
    If you look at their "simplified" circuit, there is one diode for each C, (4
    diodes), and they tied them internally together in pairs, since normally all
    the protect diode cathodes (Ks) are tied together anyway. I would
    definitely recommend tying the 2 Ks to stepper positive, since the flyback
    can be hundreds of volts without diodes. If I recall the data sheet
    correctly, the ULN2065 can only withstand 80 volts.
    Ray
    Sent: Sunday, March 26, 2000 1:11 AM
    > right?
    > Thanks,
    > Mark
    > inal Message
    > From: rjmca <rjmca@w...>
    app
    to
    flyback
    > does
    > 120-150
    caused
    and
    > >Good luck,
    > >Ray McArthur
    > >> Hello all:
    ordered
    > a
    > by
    names
    no
    > >> luck.
    > >> Thanks,
    > >> Mark
    > eGroups.com home: http://www.egroups.com/group/basicstamps
    edited 2000-03-26 07:53
    Ray:
    OK, guess I keep looking at Fig. 1 on p99 for the '2003, by stepper positive
    you mean the +12v, red & grn? Then the brwn, blk, yel, org (Airpax color
    code)
    would be hooked up to the "C"'s?
    Somehow, this doesn't seem right.
    Apologies if this is getting tedious, guess I'm making a rather painful
    transition toward the hardware end of this business. #8^o
    Thank you,
    Mark
    Date: Saturday, March 25, 2000 10:38 PM
    >Mark:
    (4
    all
    >Regards,
    >Ray
    optional
    >> right?
    >> Thanks,
    >> Mark
    >> inal Message
    >app
    >to
    >flyback
    >> does
    are
    insurance
    >> 120-150
    >caused
    >and
    >> >Good luck,
    >> >Ray McArthur
    >> >> Hello all:
    >ordered
    >> a
    close
    >> by
    >names
    coils?
    >no
    >> >> luck.
    >> >> Thanks,
    >> >> Mark
    edited 2000-03-26 20:24
    Mark:
    > Somehow, this doesn't seem right.<< You are correct!
    I just looked at fig.1 in the stamp manual. They are using two sections of
    the ULN2003 as inverters. The ULN2003 has 7 drivers vs 4 for the 2065.
    Note that the stamp drives in2, in3, in6 and in7. Then out6 drives in1, and
    out7 drives in4. Out 1 thru 4 then drive the stepper. Your problem is that
    the ULN2065 only has four drivers, so you don't have the spare sections to
    use as inverters. This means that you will have to add your own inverters to
    two of the '2065 inputs. You could use CMOS or 74HC types. Just follow
    fig.1, but add your inverters to the inputs of the drivers feeding the brown
    and orange stepper wires. Another fix would be to modify the program so
    that two additional stamp pins are used to drive the '2065. These two pins
    would be programmed as the inverse of the first two pins.
    Sorry I didn't check fig.1 sooner.
    Ray
    Sent: Sunday, March 26, 2000 1:53 AM
    > Ray:
    positive
    > code)
    > Thank you,
    > Mark
    > >Mark:
    > (4
    > all
    flyback
    > >Regards,
    > >Ray
    > optional
    > >> right?
    > >> Thanks,
    > >> Mark
    > >> inal Message
    > >app
    go
    > >to
    > >flyback
    It
    > >> does
    > are
    > insurance
    > >> 120-150
    > >caused
    > >and
    > >> >Good luck,
    > >> >Ray McArthur
    > >> >> Hello all:
    > >ordered
    > >> a
    > close
    > >> by
    > >names
    > coils?
    the
    PDF
    but
    > >no
    > >> >> luck.
    > >> >> Thanks,
    > >> >> Mark
    > -- Easily schedule meetings and events using the group calendar!
    > -- http://www.egroups.com/cal?listname=basicstamps&m=1
    edited 2000-03-27 03:20
    Ray:
    I'm gonna admit defeat at this point and order a couple of '2003's in the
    morning from Digikey.
    Just wish they had something a little more powerful with an identical pinout
    as the '2003.
    Yep, that circuit on p99 of the Stamp book is kinda subtle. I need to hook
    it up and get my DVM on it to see how that inverter arrangement works.
    Actually that's the kind of thing I'm trying to stay away from. Would like
    to stick with a tinker toy approach to IC's, its great when the flyback
    diodes, pullup resistors, load limit resistors are all built-in to the IC.
    I'm thinking about a either a 2544 or a 5804 from Allegro, but as I said
    before their data sheets are a big turn off.
    Do you or anyone else reading this know of any stepper motor control IC's
    that you've had good luck with?
    Mark
    Date: Sunday, March 26, 2000 11:22 AM
    >Mark:
    and
    that
    to
    brown
    >Ray
    >> Ray:
    >positive
    >> code)
    >> Thank you,
    >> Mark
    >> >Mark:
    C,
    >> (4
    >> all
    >flyback
    >> >Regards,
    >> >Ray
    >> optional
    flyback,
    >> >> right?
    >> >> Thanks,
    >> >> Mark
    >> >> inal Message
    more
    >> >app
    >go
    >> >to
    >> >flyback
    >It
    >> >> does
    >> are
    >> insurance
    >> >> 120-150
    >> >caused
    terminals
    >> >and
    >> >> >Good luck,
    >> >> >Ray McArthur
    >> >> >> Hello all:
    >> >ordered
    >> >> a
    >> close
    >> >> by
    >> >names
    >> coils?
    >the
    >PDF
    >but
    >> >no
    >> >> >> luck.
    >> >> >> Thanks,
    >> >> >> Mark
    edited 2000-03-27 04:24
    I've had good luck using the L293D to drive steppers. There is a great
    article dealing with hooking up a stepper with this chip and a Basic Stamp
    at:
    http://www.seattlerobotics.org/encoder/may98/steppers.html
    The L293D has the diodes and everything in the chip. I have one of these
    chips running a stepper from a PIC16F84 and the only extra component is a
    pair of 10K pullups to keep the enable pins high as I didn't have a need to
    disable them.
    hope this helps,
    Tim
    [noparse][[/noparse]Denver, CO]
    edited 2000-03-27 05:37
    Hi Tom:
    Hey thanks a lot, I'll buy a couple L293D's too if they're not too
    expensive, I'm just hoping their data sheets are better than Allegros'.
    Mark
    Date: Sunday, March 26, 2000 7:24 PM
    >at:
    >disable them.
    >hope this helps,
    >Tim
    >-- Check out your group's private Chat room
    >-- http://www.egroups.com/ChatPage?listName=basicstamps&m=1
    edited 2000-03-27 06:57
    To Tim:
    Thanks for the site reference. The simplicity is impressive, both hardware
    and software.
    To Mark:
    I just purchased a stepper controller chip from Elab digital engineering.
    It's an EDE1200 for unipolar steppers. I have not tried it yet. It does
    need coil drivers such as a ULN or transistors. It features:
    1) single pin coil drive-on/off control.
    2) single pin control of direction.
    3) single pin control for full or half step.
    4) single pin external pulse stepping, if desired.
    5) 3 bit speed control in self clocking mode.
    It's a PIC, so you need a resonator or crystal.
    They are at www.elabinc.com
    1 to 4 chips cost $8.30 ea. They also sell the L293D for $4 ea.
    Right now I am running a geared stepper for a model RR turntable. It's a
    low power motor running from a PIC16F84 driving 2N2219 transistors with
    suppressor diodes. Will eventually switch to a ULN2003 for drive. The
    software is an expansion of the code you are reading about in the Stamp
    manual on page 102.
    Good luck,
    Ray McArthur
    Sent: Sunday, March 26, 2000 11:37 PM
    > Hi Tom:
    > Mark
    > From: Tim Goldstein <timg@k...>
    IC's
    Stamp
    > >at:
    to
    > >disable them.
    > >hope this helps,
    > >Tim
    Try a UCN5804. Easy to use. It is from Allegro also.
    Roger
    At 06:20 PM 3/26/00 -0800, you wrote:
    >Ray:
    >as the '2003.
    >Thanks,
    >Mark
    >>Mark:
    >and
    >that
    >to
    >brown
    >>Ray
    >>> Ray:
    >>positive
    >>> code)
    >>> Thank you,
    >>> Mark
    >>> >Mark:
    >C,
    >>> (4
    >>> all
    >>flyback
    >>> >Regards,
    >>> >Ray
    >>> optional
    >flyback,
    >>> >> right?
    >>> >> Thanks,
    >>> >> Mark
    >>> >> inal Message
    >more
    >>> >app
    >>go
    >>> >to
    >>> >flyback
    >>It
    >>> >> does
    >>> are
    >>> insurance
    >>> >> 120-150
    >>> >caused
    >terminals
    >>> >and
    >>> >> >Good luck,
    >>> >> >Ray McArthur
    >>> >> >> Hello all:
    >>> >ordered
    >>> >> a
    >>> close
    >>> >> by
    >>> >names
    >>> coils?
    >>the
    >>PDF
    >>but
    >>> >no
    >>> >> >> luck.
    >>> >> >> Thanks,
    >>> >> >> Mark
    Roger Edberg
    rjedberg@c...
    http://www.cruzio.com/~pgraphic
