Fire-Stick — Parallax Forums
Fire-Stick
edited 2000-03-23 15:48 in General Discussion
My compliments to Reynolds Electronics for an excellent kit. The
Fire-stick kits, (2), that I bought were of the higest quality, very
simple to assemble, and the suckers even worked! Me and a friend were
awe struck at the distance the I-R could be detected. Indoors it even
worked around corners due to reflection from the walls. We were only
using it as a "make/break" project using the VT pin to the STAMP 1,
and haven't figured how to send data between two stamps. Maybe someone
can offer some help.. To see the Fire-Stick go to
http://www.rentron.com ............ ==Mac== AG5F
    edited 2000-03-23 00:45
    I also bought 2 Firesticks and was favorably impressed. I tested them in
    the burst mode. You can lower any of the 4 data lines, resulting in four
    possible control commands. But if I remember correctly, I could also lower
    1 to 4 pins in any combination, which would yield 15 possible commands, (the
    all 0 command cannot be used because at least 1 pin must be lowered to
    xmit). Furthermore, even though the data sheet doesn't mention it, I
    suspect that different addresses can be used on 2 tx/rx sets by grounding
    combinations of the open address lines on the Holtek coders/decoders. I
    want to build a battery operated remote for our model RR with the Firestick
    when I get to it.
    Be careful running it for long pulses, like hundreds of ms. Read Bruce's
    data sheet carefully on this point. It appears that many long transmissions
    will cook R1, and/or suck down a 9V battery in no time.
    Good luck,
    Ray McArthur
    To: <basicstamps@egroups.com>
    Sent: Wednesday, March 22, 2000 6:11 PM
    Subject: [noparse][[/noparse]basicstamps] Fire-Stick
    > eGroups.com home: http://www.egroups.com/group/basicstamps
    > http://www.egroups.com - Simplifying group communications
    I have also had good results with the Fire-Stick and would like to send
    data. I would like to convert a analog voltage and send it to the receiver.
    Tom
    From: Robert McAtee [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LQY52t5rAsIdN6sdQOhoXpRyzKlK1yGxmi5TO9tyVKxpCZrkBhuJVQlgvryR9NjHKe4NKyMeQINME3jw]w5tnj@c...[/url
    To: basicstamps@egroups.com
