AutoPilot using a stamp — Parallax Forums
edited 2000-03-21 18:06 in General Discussion
Hi all,
I want to use light sensors to control the movement of a model aircraft,
So if the aircraft dorps a wing, one light sensor will be darker since
it would be pointing to the ground, What sort of light sensors should I
used and will I use the RCtime command. I will then be checking to see
is a value in a certain range, if it is send out and appropiate pulse
to the servos
Thanks for any help in advance
Paul
    edited 2000-03-21 15:27
    Paul,
    > Hi all,
    > to the servos
    Why re-invent the wheel? Futaba has a very cheap inclinometer that "sort
    of" works with this reasoning, but it has its own light source. Look on
    http://www.towerhobbies.com for the Futaba attitude stablizer, and work on
    hooking that one up. It should be spiffy.
    DLC
    * Dennis Clark Aristocrat at heart dlc@v... www.verinet.com/~dlc *
    * Be well, do good work, and stay in touch -- Garrison Keillor *
    There's some stuff here that might make your life a bit simpler...
    www.u-nav.com
    >> to the servos
    Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
    Manufacturer of the famous BOB-II Serial Video Text Display Module!
