Al''s excellent Toner transfer method — Parallax Forums
edited 2000-03-16 00:24 in General Discussion
Hello all,
I wanted to post regarding my success with Al Williams PCB etching
method described at:
http://www.al-williams.com/wd5gnr/pcb.htm
This really works...I just went from software to etched and drilled board
in <1 hour. If you've used the dyna art paper before (for toner transfer) I
must say that Al's method works much_better. It's also much less expensive.
Just follow the instructions carefully and it will work very well. Thanks Al!
Cheers, Duncan
